Fixed NULL material SEGFAULTs when checking photon ports
Fixed SEGFAULTS when declaring light sources as photon ports!
Improved handling of mixtures and photon ports with photon mapping
Improved photon port handling -- only actual surfaces are accepted
Bug fix for uninitialized sources set to -1
Added test for local glow lights
Added calls to findmaterial() and simplified photon map shadow check
Fixes for Windows and photon map
