root/Development/ray/src/rt/pmapsrc.c
Revision: 2.8
Committed: Tue Sep 1 16:27:53 2015 UTC (10 years, 4 months ago) by greg
2 static const char RCSid[] = "$Id: pmapsrc.c,v 2.7 2015/08/18 18:45:55 greg Exp $";
5 ==================================================================
6 Photon map support routines for emission from light sources
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ==================================================================
13
14 */
15
16
17
18 #include "pmapsrc.h"
19 #include "pmap.h"
20 #include "pmaprand.h"
21 #include "otypes.h"
22
23
24
25 SRCREC *photonPorts = NULL; /* Photon port list */
26 unsigned numPhotonPorts = 0;
27
28 void (*photonPartition [NUMOTYPE]) (EmissionMap*);
29 void (*photonOrigin [NUMOTYPE]) (EmissionMap*);
30
31 extern OBJECT ambset [];
32
33
34
35 static int flatPhotonPartition2 (EmissionMap* emap, unsigned long mp,
36 FVECT cent, FVECT u, FVECT v,
37 double du2, double dv2)
38 /* Recursive part of flatPhotonPartition(..) */
39 {
40 FVECT newct, newax;
41 unsigned long npl, npu;
42
43 if (mp > emap -> maxPartitions) {
44 /* Enlarge partition array */
45 emap -> maxPartitions <<= 1;
46 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
47 emap -> maxPartitions >> 1);
48
49 if (!emap -> partitions)
50 error(USER, "can't allocate source partitions");
51
52 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
53 emap -> maxPartitions >> 2);
54 }
55
56 if (du2 * dv2 <= 1) { /* hit limit? */
57 setpart(emap -> partitions, emap -> partitionCnt, S0);
58 emap -> partitionCnt++;
59 return 1;
60 }
61
62 if (du2 > dv2) { /* subdivide in U */
63 setpart(emap -> partitions, emap -> partitionCnt, SU);
64 emap -> partitionCnt++;
65 newax [0] = 0.5 * u [0];
66 newax [1] = 0.5 * u [1];
67 newax [2] = 0.5 * u [2];
68 u = newax;
69 du2 *= 0.25;
70 }
71
72 else { /* subdivide in V */
73 setpart(emap -> partitions, emap -> partitionCnt, SV);
74 emap -> partitionCnt++;
75 newax [0] = 0.5 * v [0];
76 newax [1] = 0.5 * v [1];
77 newax [2] = 0.5 * v [2];
78 v = newax;
79 dv2 *= 0.25;
80 }
81
82 /* lower half */
83 newct [0] = cent [0] - newax [0];
84 newct [1] = cent [1] - newax [1];
85 newct [2] = cent [2] - newax [2];
86 npl = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
87
88 /* upper half */
89 newct [0] = cent [0] + newax [0];
90 newct [1] = cent [1] + newax [1];
91 newct [2] = cent [2] + newax [2];
92 npu = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
93
94 /* return total */
95 return npl + npu;
96 }
97
98
99
100 static void flatPhotonPartition (EmissionMap* emap)
101 /* Partition flat source for photon emission */
102 {
103 RREAL *vp;
104 double du2, dv2;
105
106 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
107 emap -> partArea = srcsizerat * thescene.cusize;
108 emap -> partArea *= emap -> partArea;
109 vp = emap -> src -> ss [SU];
110 du2 = DOT(vp, vp) / emap -> partArea;
111 vp = emap -> src -> ss [SV];
112 dv2 = DOT(vp, vp) / emap -> partArea;
113 emap -> partitionCnt = 0;
114 emap -> numPartitions = flatPhotonPartition2(emap, 1, emap -> src -> sloc,
115 emap -> src -> ss [SU],
116 emap -> src -> ss [SV],
117 du2, dv2);
118 emap -> partitionCnt = 0;
119 emap -> partArea = emap -> src -> ss2 / emap -> numPartitions;
120 }
121
122
123
124 static void sourcePhotonPartition (EmissionMap* emap)
125 /* Partition scene cube faces or photon port for photon emission from
126 distant source */
127 {
128 if (emap -> port) {
129 /* Partition photon port */
130 SRCREC *src = emap -> src;
131 emap -> src = emap -> port;
132 photonPartition [emap -> src -> so -> otype] (emap);
133 emap -> src = src;
134 }
135
136 else {
137 /* No photon ports defined, so partition scene cube faces */
138 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
139 setpart(emap -> partitions, 0, S0);
140 emap -> partitionCnt = 0;
141 emap -> numPartitions = 1 / srcsizerat;
142 emap -> numPartitions *= emap -> numPartitions;
143 emap -> partArea = sqr(thescene.cusize) / emap -> numPartitions;
144 emap -> numPartitions *= 6;
145 }
146 }
147
148
149
150 static void spherePhotonPartition (EmissionMap* emap)
151 /* Partition spherical source into equal solid angles using uniform
152 mapping for photon emission */
153 {
154 unsigned numTheta, numPhi;
155
156 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
157 setpart(emap -> partitions, 0, S0);
158 emap -> partArea = 4 * PI * sqr(emap -> src -> srad);
159 emap -> numPartitions = emap -> partArea /
160 sqr(srcsizerat * thescene.cusize);
161
162 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
163 numPhi = 0.5 * PI * numTheta + 0.5;
164
165 emap -> numPartitions = (unsigned long)numTheta * numPhi;
166 emap -> partitionCnt = 0;
167 emap -> partArea /= emap -> numPartitions;
168 }
169
170
171
172 static int cylPhotonPartition2 (EmissionMap* emap, unsigned long mp,
173 FVECT cent, FVECT axis, double d2)
174 /* Recursive part of cyPhotonPartition(..) */
175 {
176 FVECT newct, newax;
177 unsigned long npl, npu;
178
179 if (mp > emap -> maxPartitions) {
180 /* Enlarge partition array */
181 emap -> maxPartitions <<= 1;
182 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
183 emap -> maxPartitions >> 1);
184 if (!emap -> partitions)
185 error(USER, "can't allocate source partitions");
186
187 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
188 emap -> maxPartitions >> 2);
189 }
190
191 if (d2 <= 1) {
192 /* hit limit? */
193 setpart(emap -> partitions, emap -> partitionCnt, S0);
194 emap -> partitionCnt++;
195 return 1;
196 }
197
198 /* subdivide */
199 setpart(emap -> partitions, emap -> partitionCnt, SU);
200 emap -> partitionCnt++;
201 newax [0] = 0.5 * axis [0];
202 newax [1] = 0.5 * axis [1];
203 newax [2] = 0.5 * axis [2];
204 d2 *= 0.25;
205
206 /* lower half */
207 newct [0] = cent [0] - newax [0];
208 newct [1] = cent [1] - newax [1];
209 newct [2] = cent [2] - newax [2];
210 npl = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
211
212 /* upper half */
213 newct [0] = cent [0] + newax [0];
214 newct [1] = cent [1] + newax [1];
215 newct [2] = cent [2] + newax [2];
216 npu = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
217
218 /* return total */
219 return npl + npu;
220 }
221
222
223
224 static void cylPhotonPartition (EmissionMap* emap)
225 /* Partition cylindrical source for photon emission */
226 {
227 double d2;
228
229 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
230 d2 = srcsizerat * thescene.cusize;
231 d2 = PI * emap -> src -> ss2 / (2 * emap -> src -> srad * sqr(d2));
232 d2 *= d2 * DOT(emap -> src -> ss [SU], emap -> src -> ss [SU]);
233
234 emap -> partitionCnt = 0;
235 emap -> numPartitions = cylPhotonPartition2(emap, 1, emap -> src -> sloc,
236 emap -> src -> ss [SU], d2);
237 emap -> partitionCnt = 0;
238 emap -> partArea = PI * emap -> src -> ss2 / emap -> numPartitions;
239 }
240
241
242
243 static void flatPhotonOrigin (EmissionMap* emap)
244 /* Init emission map with photon origin and associated surface axes on
245 flat light source surface. Also sets source aperture and sampling
246 hemisphere axes at origin */
247 {
248 int i, cent[3], size[3], parr[2];
249 FVECT vpos;
250
251 cent [0] = cent [1] = cent [2] = 0;
252 size [0] = size [1] = size [2] = emap -> maxPartitions;
253 parr [0] = 0;
254 parr [1] = emap -> partitionCnt;
255
256 if (!skipparts(cent, size, parr, emap -> partitions))
257 error(CONSISTENCY, "bad source partition in flatPhotonOrigin");
258
259 vpos [0] = (1 - 2 * pmapRandom(partState)) * size [0] /
260 emap -> maxPartitions;
261 vpos [1] = (1 - 2 * pmapRandom(partState)) * size [1] /
262 emap -> maxPartitions;
263 vpos [2] = 0;
264
265 for (i = 0; i < 3; i++)
266 vpos [i] += (double)cent [i] / emap -> maxPartitions;
267
268 /* Get origin */
269 for (i = 0; i < 3; i++)
270 emap -> photonOrg [i] = emap -> src -> sloc [i] +
271 vpos [SU] * emap -> src -> ss [SU][i] +
272 vpos [SV] * emap -> src -> ss [SV][i] +
273 vpos [SW] * emap -> src -> ss [SW][i];
274
275 /* Get surface axes */
276 VCOPY(emap -> us, emap -> src -> ss [SU]);
277 normalize(emap -> us);
278 VCOPY(emap -> ws, emap -> src -> ss [SW]);
279
280 if (emap -> port)
281 /* Acts as a photon port; reverse normal as it points INSIDE per
282 * mkillum convention */
283 for (i = 0; i < 3; i++)
284 emap -> ws [i] = -emap -> ws [i];
285
286 fcross(emap -> vs, emap -> ws, emap -> us);
287
288 /* Get hemisphere axes & aperture */
289 if (emap -> src -> sflags & SSPOT) {
290 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
291 i = 0;
292
293 do {
294 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
295 emap -> vh [i++] = 1;
296 fcross(emap -> uh, emap -> vh, emap -> wh);
297 } while (normalize(emap -> uh) < FTINY);
298
299 fcross(emap -> vh, emap -> wh, emap -> uh);
300 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
301 }
302
303 else {
304 VCOPY(emap -> uh, emap -> us);
305 VCOPY(emap -> vh, emap -> vs);
306 VCOPY(emap -> wh, emap -> ws);
307 emap -> cosThetaMax = 0;
308 }
309 }
310
311
312
313 static void spherePhotonOrigin (EmissionMap* emap)
314 /* Init emission map with photon origin and associated surface axes on
315 spherical light source. Also sets source aperture and sampling
316 hemisphere axes at origin */
317 {
318 int i = 0;
319 unsigned numTheta, numPhi, t, p;
320 RREAL cosTheta, sinTheta, phi;
321
322 /* Get current partition */
323 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
324 numPhi = 0.5 * PI * numTheta + 0.5;
325
326 t = emap -> partitionCnt / numPhi;
327 p = emap -> partitionCnt - t * numPhi;
328
329 emap -> ws [2] = cosTheta = 1 - 2 * (t + pmapRandom(partState)) / numTheta;
330 sinTheta = sqrt(1 - sqr(cosTheta));
331 phi = 2 * PI * (p + pmapRandom(partState)) / numPhi;
332 emap -> ws [0] = cos(phi) * sinTheta;
333 emap -> ws [1] = sin(phi) * sinTheta;
334
335 if (emap -> port)
336 /* Acts as a photon port; reverse normal as it points INSIDE per
337 * mkillum convention */
338 for (i = 0; i < 3; i++)
339 emap -> ws [i] = -emap -> ws [i];
340
341 /* Get surface axes us & vs perpendicular to ws */
342 do {
343 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
344 emap -> vs [i++] = 1;
345 fcross(emap -> us, emap -> vs, emap -> ws);
346 } while (normalize(emap -> us) < FTINY);
347
348 fcross(emap -> vs, emap -> ws, emap -> us);
349
350 /* Get origin */
351 for (i = 0; i < 3; i++)
352 emap -> photonOrg [i] = emap -> src -> sloc [i] +
353 emap -> src -> srad * emap -> ws [i];
354
355 /* Get hemisphere axes & aperture */
356 if (emap -> src -> sflags & SSPOT) {
357 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
358 i = 0;
359
360 do {
361 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
362 emap -> vh [i++] = 1;
363 fcross(emap -> uh, emap -> vh, emap -> wh);
364 } while (normalize(emap -> uh) < FTINY);
365
366 fcross(emap -> vh, emap -> wh, emap -> uh);
367 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
368 }
369
370 else {
371 VCOPY(emap -> uh, emap -> us);
372 VCOPY(emap -> vh, emap -> vs);
373 VCOPY(emap -> wh, emap -> ws);
374 emap -> cosThetaMax = 0;
375 }
376 }
377
378
379
380 static void sourcePhotonOrigin (EmissionMap* emap)
381 /* Init emission map with photon origin and associated surface axes
382 on scene cube face for distant light source. Also sets source
383 aperture (solid angle) and sampling hemisphere axes at origin */
384 {
385 unsigned long i, partsPerDim, partsPerFace;
386 unsigned face;
387 RREAL du, dv;
388
389 if (emap -> port) {
390 /* Get origin on photon port */
391 SRCREC *src = emap -> src;
392 emap -> src = emap -> port;
393 photonOrigin [emap -> src -> so -> otype] (emap);
394 emap -> src = src;
395 }
396
397 else {
398 /* No ports defined, so get origin on scene cube face and SUFFA! */
399 /* Get current face from partition number */
400 partsPerDim = 1 / srcsizerat;
401 partsPerFace = sqr(partsPerDim);
402 face = emap -> partitionCnt / partsPerFace;
403
404 if (!(emap -> partitionCnt % partsPerFace)) {
405 /* Skipped to a new face; get its normal */
406 emap -> ws [0] = emap -> ws [1] = emap -> ws [2] = 0;
407 emap -> ws [face >> 1] = face & 1 ? 1 : -1;
408
409 /* Get surface axes us & vs perpendicular to ws */
410 face >>= 1;
411 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
412 emap -> vs [(face + (emap -> ws [face] > 0 ? 2 : 1)) % 3] = 1;
413 fcross(emap -> us, emap -> vs, emap -> ws);
414 }
415
416 /* Get jittered offsets within face from partition number
417 (in range [-0.5, 0.5]) */
418 i = emap -> partitionCnt % partsPerFace;
419 du = (i / partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
420 dv = (i % partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
421
422 /* Jittered destination point within partition */
423 for (i = 0; i < 3; i++)
424 emap -> photonOrg [i] = thescene.cuorg [i] +
425 thescene.cusize * (0.5 + du * emap -> us [i] +
426 dv * emap -> vs [i] +
427 0.5 * emap -> ws [i]);
428 }
429
430 /* Get hemisphere axes & aperture */
431 VCOPY(emap -> wh, emap -> src -> sloc);
432 i = 0;
433
434 do {
435 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
436 emap -> vh [i++] = 1;
437 fcross(emap -> uh, emap -> vh, emap -> wh);
438 } while (normalize(emap -> uh) < FTINY);
439
440 fcross(emap -> vh, emap -> wh, emap -> uh);
441
442 /* Get aperture */
443 emap -> cosThetaMax = 1 - emap -> src -> ss2 / (2 * PI);
444 emap -> cosThetaMax = min(1, max(-1, emap -> cosThetaMax));
445 }
446
447
448
449 static void cylPhotonOrigin (EmissionMap* emap)
450 /* Init emission map with photon origin and associated surface axes
451 on cylindrical light source surface. Also sets source aperture
452 and sampling hemisphere axes at origin */
453 {
454 int i, cent[3], size[3], parr[2];
455 FVECT v;
456
457 cent [0] = cent [1] = cent [2] = 0;
458 size [0] = size [1] = size [2] = emap -> maxPartitions;
459 parr [0] = 0;
460 parr [1] = emap -> partitionCnt;
461
462 if (!skipparts(cent, size, parr, emap -> partitions))
463 error(CONSISTENCY, "bad source partition in cylPhotonOrigin");
464
465 v [SU] = 0;
466 v [SV] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
467 emap -> maxPartitions;
468 v [SW] = (1 - 2 * pmapRandom(partState)) * (double)size [2] /
469 emap -> maxPartitions;
470 normalize(v);
471 v [SU] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
472 emap -> maxPartitions;
473
474 for (i = 0; i < 3; i++)
475 v [i] += (double)cent [i] / emap -> maxPartitions;
476
477 /* Get surface axes */
478 for (i = 0; i < 3; i++)
479 emap -> photonOrg [i] = emap -> ws [i] =
480 (v [SV] * emap -> src -> ss [SV][i] +
481 v [SW] * emap -> src -> ss [SW][i]) / 0.8559;
482
483 if (emap -> port)
484 /* Acts as a photon port; reverse normal as it points INSIDE per
485 * mkillum convention */
486 for (i = 0; i < 3; i++)
487 emap -> ws [i] = -emap -> ws [i];
488
489 normalize(emap -> ws);
490 VCOPY(emap -> us, emap -> src -> ss [SU]);
491 normalize(emap -> us);
492 fcross(emap -> vs, emap -> ws, emap -> us);
493
494 /* Get origin */
495 for (i = 0; i < 3; i++)
496 emap -> photonOrg [i] += v [SU] * emap -> src -> ss [SU][i] +
497 emap -> src -> sloc [i];
498
499 /* Get hemisphere axes & aperture */
500 if (emap -> src -> sflags & SSPOT) {
501 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
502 i = 0;
503
504 do {
505 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
506 emap -> vh [i++] = 1;
507 fcross(emap -> uh, emap -> vh, emap -> wh);
508 } while (normalize(emap -> uh) < FTINY);
509
510 fcross(emap -> vh, emap -> wh, emap -> uh);
511 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
512 }
513
514 else {
515 VCOPY(emap -> uh, emap -> us);
516 VCOPY(emap -> vh, emap -> vs);
517 VCOPY(emap -> wh, emap -> ws);
518 emap -> cosThetaMax = 0;
519 }
520 }
521
522
523
524 void getPhotonPorts ()
525 /* Find geometry declared as photon ports */
526 {
527 OBJECT i;
528 OBJREC* obj;
529
530 /* Check for missing port modifiers */
531 if (!ambset [0])
532 error(USER, "no photon ports found");
533
534 for (i = 0; i < nobjects; i++) {
535 obj = objptr(i);
536
537 if (inset(ambset, obj -> omod)) {
538 /* Add photon port */
539 photonPorts = (SRCREC*)realloc(photonPorts,
540 (numPhotonPorts + 1) *
541 sizeof(SRCREC));
542 if (!photonPorts)
543 error(USER, "can't allocate photon ports");
544
545 photonPorts [numPhotonPorts].so = obj;
546 photonPorts [numPhotonPorts].sflags = 0;
547
548 if (!sfun [obj -> otype].of || !sfun[obj -> otype].of -> setsrc)
549 objerror(obj, USER, "illegal photon port");
550
551 setsource(photonPorts + numPhotonPorts, obj);
552 numPhotonPorts++;
553 }
554 }
555 }
556
557
558
559 static void defaultEmissionFunc (EmissionMap* emap)
560 /* Default behaviour when no emission funcs defined for this source type */
561 {
562 objerror(emap -> src -> so, INTERNAL,
563 "undefined photon emission function");
564 }
565
566
567
568 void initPhotonEmissionFuncs ()
569 /* Init photonPartition[] and photonOrigin[] dispatch tables */
570 {
571 int i;
572
573 for (i = 0; i < NUMOTYPE; i++)
574 photonPartition [i] = photonOrigin [i] = defaultEmissionFunc;
575
576 photonPartition [OBJ_FACE] = photonPartition [OBJ_RING] = flatPhotonPartition;
577 photonPartition [OBJ_SOURCE] = sourcePhotonPartition;
578 photonPartition [OBJ_SPHERE] = spherePhotonPartition;
579 photonPartition [OBJ_CYLINDER] = cylPhotonPartition;
580 photonOrigin [OBJ_FACE] = photonOrigin [OBJ_RING] = flatPhotonOrigin;
581 photonOrigin [OBJ_SOURCE] = sourcePhotonOrigin;
582 photonOrigin [OBJ_SPHERE] = spherePhotonOrigin;
583 photonOrigin [OBJ_CYLINDER] = cylPhotonOrigin;
584 }
585
586
587
588 void initPhotonEmission (EmissionMap *emap, float numPdfSamples)
589 /* Initialize photon emission from partitioned light source emap -> src;
590 * this involves integrating the flux emitted from the current photon
591 * origin emap -> photonOrg and setting up a PDF to sample the emission
592 * distribution with numPdfSamples samples */
593 {
594 unsigned i, t, p;
595 double phi, cosTheta, sinTheta, du, dv, dOmega, thetaScale;
596 EmissionSample* sample;
597 const OBJREC* mod = findmaterial(emap -> src -> so);
598 static RAY r;
599 #if 0
600 static double lastCosNorm = FHUGE;
601 static SRCREC *lastSrc = NULL, *lastPort = NULL;
602 #endif
603
604 setcolor(emap -> partFlux, 0, 0, 0);
605
606 photonOrigin [emap -> src -> so -> otype] (emap);
607 cosTheta = DOT(emap -> ws, emap -> wh);
608
609 #if 0
610 if (emap -> src == lastSrc && emap -> port == lastPort &&
611 (emap -> src -> sflags & SDISTANT || mod -> omod == OVOID) &&
612 cosTheta == lastCosNorm)
613 /* Same source, port, and aperture-normal angle, and source is
614 either distant (and thus translationally invariant) or has
615 no modifier --> flux unchanged */
616 /* BUG: this optimisation ignores partial occlusion of ports and
617 can lead to erroneous "zero emission" bailouts.
618 It can also lead to bias with modifiers exhibiting high variance!
619 Disabled for now -- RS 12/13 */
620 return;
621
622 lastSrc = emap -> src;
623 lastPort = emap -> port;
624 lastCosNorm = cosTheta;
625 #endif
626
627 /* Need to recompute flux & PDF */
628 emap -> cdf = 0;
629 emap -> numSamples = 0;
630
631 if (cosTheta <= 0 &&
632 sqrt(1 - sqr(cosTheta)) <= emap -> cosThetaMax + FTINY)
633 /* Aperture below surface; no emission from current origin */
634 return;
635
636 if (mod -> omod == OVOID && !emap -> port &&
637 (cosTheta >= 1 - FTINY || (emap -> src -> sflags & SDISTANT &&
638 acos(cosTheta) + acos(emap -> cosThetaMax) <= 0.5 * PI))) {
639 /* Source is unmodified and has no port (which requires testing for
640 occlusion), and is either local with normal aligned aperture or
641 distant with aperture above surface; analytical flux & PDF */
642 setcolor(emap -> partFlux, mod -> oargs.farg [0],
643 mod -> oargs.farg [1], mod -> oargs.farg [2]);
644
645 /* Multiply radiance by Omega * dA to get flux */
646 scalecolor(emap -> partFlux,
647 PI * cosTheta * (1 - sqr(max(emap -> cosThetaMax, 0))) *
648 emap -> partArea);
649 }
650
651 else {
652 /* Source is either modified, has a port, is local with off-normal
653 aperture, or distant with aperture partly below surface; get flux
654 via numerical integration */
655 thetaScale = (1 - emap -> cosThetaMax);
656
657 /* Figga out numba of aperture samples for integration;
658 numTheta / numPhi ratio is 1 / PI */
659 du = sqrt(pdfSamples * 2 * thetaScale);
660 emap -> numTheta = max(du + 0.5, 1);
661 emap -> numPhi = max(PI * du + 0.5, 1);
662
663 dOmega = 2 * PI * thetaScale / (emap -> numTheta * emap -> numPhi);
664 thetaScale /= emap -> numTheta;
665
666 /* Allocate PDF, baby */
667 sample = emap -> samples = (EmissionSample*)
668 realloc(emap -> samples,
669 sizeof(EmissionSample) *
670 emap -> numTheta * emap -> numPhi);
671 if (!emap -> samples)
672 error(USER, "can't allocate emission PDF");
673
674 VCOPY(r.rorg, emap -> photonOrg);
675 VCOPY(r.rop, emap -> photonOrg);
676 r.rmax = 0;
677
678 for (t = 0; t < emap -> numTheta; t++) {
679 for (p = 0; p < emap -> numPhi; p++) {
680 /* This uniform mapping handles 0 <= thetaMax <= PI */
681 cosTheta = 1 - (t + pmapRandom(emitState)) * thetaScale;
682 sinTheta = sqrt(1 - sqr(cosTheta));
683 phi = 2 * PI * (p + pmapRandom(emitState)) / emap -> numPhi;
684 du = cos(phi) * sinTheta;
685 dv = sin(phi) * sinTheta;
686 rayorigin(&r, PRIMARY, NULL, NULL);
687
688 for (i = 0; i < 3; i++)
689 r.rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
690 cosTheta * emap -> wh [i];
691
692 /* Sample behind surface? */
693 VCOPY(r.ron, emap -> ws);
694 if ((r.rod = DOT(r.rdir, r.ron)) <= 0)
695 continue;
696
697 /* Get radiance emitted in this direction; to get flux we
698 multiply by cos(theta_surface), dOmega, and dA. Ray
699 is directed towards light source for raytexture(). */
700 if (!(emap -> src -> sflags & SDISTANT))
701 for (i = 0; i < 3; i++)
702 r.rdir [i] = -r.rdir [i];
703
704 /* Port occluded in this direction? */
705 if (emap -> port && localhit(&r, &thescene))
706 continue;
707
708 raytexture(&r, mod -> omod);
709 setcolor(r.rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
710 mod -> oargs.farg [2]);
711 multcolor(r.rcol, r.pcol);
712
713 /* Multiply by cos(theta_surface) */
714 scalecolor(r.rcol, r.rod);
715
716 /* Add PDF sample if nonzero; importance info for photon emission
717 * could go here... */
718 if (colorAvg(r.rcol)) {
719 copycolor(sample -> pdf, r.rcol);
720 sample -> cdf = emap -> cdf += colorAvg(sample -> pdf);
721 sample -> theta = t;
722 sample++ -> phi = p;
723 emap -> numSamples++;
724 addcolor(emap -> partFlux, r.rcol);
725 }
726 }
727 }
728
729 /* Multiply by dOmega * dA */
730 scalecolor(emap -> partFlux, dOmega * emap -> partArea);
731 }
732 }
733
734
735
736 #define vomitPhoton emitPhoton
737 #define bluarrrghPhoton vomitPhoton
738
739 void emitPhoton (const EmissionMap* emap, RAY* ray)
740 /* Emit photon from current partition emap -> partitionCnt based on
741 emission distribution. Returns new photon ray. */
742 {
743 unsigned long i, lo, hi;
744 const EmissionSample* sample = emap -> samples;
745 RREAL du, dv, cosTheta, cosThetaSqr, sinTheta, phi;
746 const OBJREC* mod = findmaterial(emap -> src -> so);
747
748 /* Choose a new origin within current partition for every
749 emitted photon to break up clustering artifacts */
750 photonOrigin [emap -> src -> so -> otype] ((EmissionMap*)emap);
751 /* If we have a local glow source with a maximum radius, then
752 restrict our photon to the specified distance (otherwise no limit) */
753 if (mod -> otype == MAT_GLOW && !(emap -> src -> sflags & SDISTANT)
754 && mod -> oargs.farg[3] > FTINY)
755 ray -> rmax = mod -> oargs.farg[3];
756 else
757 ray -> rmax = 0;
758 rayorigin(ray, PRIMARY, NULL, NULL);
759
760 if (!emap -> numSamples) {
761 /* Source is unmodified and has no port, and either local with
762 normal aligned aperture, or distant with aperture above surface;
763 use cosine weighted distribution */
764 cosThetaSqr = 1 - pmapRandom(emitState) *
765 (1 - sqr(max(emap -> cosThetaMax, 0)));
766 cosTheta = sqrt(cosThetaSqr);
767 sinTheta = sqrt(1 - cosThetaSqr);
768 phi = 2 * PI * pmapRandom(emitState);
769 setcolor(ray -> rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
770 mod -> oargs.farg [2]);
771 }
772
773 else {
774 /* Source is either modified, has a port, is local with off-normal
775 aperture, or distant with aperture partly below surface; choose
776 direction from constructed cumulative distribution function with
777 Monte Carlo inversion using binary search. */
778 du = pmapRandom(emitState) * emap -> cdf;
779 lo = 1;
780 hi = emap -> numSamples;
781
782 while (hi > lo) {
783 i = (lo + hi) >> 1;
784 sample = emap -> samples + i - 1;
785
786 if (sample -> cdf >= du)
787 hi = i;
788 if (sample -> cdf < du)
789 lo = i + 1;
790 }
791
792 /* This is a uniform mapping, mon */
793 cosTheta = 1 - (sample -> theta + pmapRandom(emitState)) *
794 (1 - emap -> cosThetaMax) / emap -> numTheta;
795 sinTheta = sqrt(1 - sqr(cosTheta));
796 phi = 2 * PI * (sample -> phi + pmapRandom(emitState)) / emap -> numPhi;
797 copycolor(ray -> rcol, sample -> pdf);
798 }
799
800 /* Normalize photon flux so that average over RGB is 1 */
801 colorNorm(ray -> rcol);
802
803 VCOPY(ray -> rorg, emap -> photonOrg);
804 du = cos(phi) * sinTheta;
805 dv = sin(phi) * sinTheta;
806
807 for (i = 0; i < 3; i++)
808 ray -> rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
809 cosTheta * emap -> wh [i];
810
811 if (emap -> src -> sflags & SDISTANT)
812 /* Distant source; reverse ray direction to point into the scene. */
813 for (i = 0; i < 3; i++)
814 ray -> rdir [i] = -ray -> rdir [i];
815
816 if (emap -> port)
817 /* Photon emitted from port; move origin just behind port so it
818 will be scattered */
819 for (i = 0; i < 3; i++)
820 ray -> rorg [i] -= 2 * FTINY * ray -> rdir [i];
821
822 /* Assign emitting light source index */
823 ray -> rsrc = emap -> src - source;
824 }
825
826
827
828 void multDirectPmap (RAY *r)
829 /* Factor irradiance from direct photons into r -> rcol; interface to
830 * direct() */
831 {
832 COLOR photonIrrad;
833
834 /* Lookup direct photon irradiance */
835 (directPmap -> lookup)(directPmap, r, photonIrrad);
836
837 /* Multiply with coefficient in ray */
838 multcolor(r -> rcol, photonIrrad);
839
840 return;
841 }
842
843
844
845 void inscatterVolumePmap (RAY *r, COLOR inscatter)
846 /* Add inscattering from volume photon map; interface to srcscatter() */
847 {
848 /* Add ambient in-scattering via lookup callback */
849 (volumePmap -> lookup)(volumePmap, r, inscatter);
850 }
