root/radiance/ray/src/rt/pmapsrc.c
Revision: 2.4
Committed: Thu May 21 13:54:59 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.3: +5 -4 lines
Added calls to findmaterial() and simplified photon map shadow check
1 /*
2 ==================================================================
3 Photon map support routines for emission from light sources
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmapsrc.c,v 2.3 2015/05/08 13:20:23 rschregle Exp $
12 */
13
14
15
16 #include "pmapsrc.h"
17 #include "pmap.h"
18 #include "pmaprand.h"
19 #include "otypes.h"
20
21
22
23 SRCREC *photonPorts = NULL; /* Photon port list */
24 unsigned numPhotonPorts = 0;
25
26 void (*photonPartition [NUMOTYPE]) (EmissionMap*);
27 void (*photonOrigin [NUMOTYPE]) (EmissionMap*);
28
29 extern OBJECT ambset [];
30
31
32
33 static int flatPhotonPartition2 (EmissionMap* emap, unsigned long mp,
34 FVECT cent, FVECT u, FVECT v,
35 double du2, double dv2)
36 /* Recursive part of flatPhotonPartition(..) */
37 {
38 FVECT newct, newax;
39 unsigned long npl, npu;
40
41 if (mp > emap -> maxPartitions) {
42 /* Enlarge partition array */
43 emap -> maxPartitions <<= 1;
44 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
45 emap -> maxPartitions >> 1);
46
47 if (!emap -> partitions)
48 error(USER, "can't allocate source partitions");
49
50 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
51 emap -> maxPartitions >> 2);
52 }
53
54 if (du2 * dv2 <= 1) { /* hit limit? */
55 setpart(emap -> partitions, emap -> partitionCnt, S0);
56 emap -> partitionCnt++;
57 return 1;
58 }
59
60 if (du2 > dv2) { /* subdivide in U */
61 setpart(emap -> partitions, emap -> partitionCnt, SU);
62 emap -> partitionCnt++;
63 newax [0] = 0.5 * u [0];
64 newax [1] = 0.5 * u [1];
65 newax [2] = 0.5 * u [2];
66 u = newax;
67 du2 *= 0.25;
68 }
69
70 else { /* subdivide in V */
71 setpart(emap -> partitions, emap -> partitionCnt, SV);
72 emap -> partitionCnt++;
73 newax [0] = 0.5 * v [0];
74 newax [1] = 0.5 * v [1];
75 newax [2] = 0.5 * v [2];
76 v = newax;
77 dv2 *= 0.25;
78 }
79
80 /* lower half */
81 newct [0] = cent [0] - newax [0];
82 newct [1] = cent [1] - newax [1];
83 newct [2] = cent [2] - newax [2];
84 npl = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
85
86 /* upper half */
87 newct [0] = cent [0] + newax [0];
88 newct [1] = cent [1] + newax [1];
89 newct [2] = cent [2] + newax [2];
90 npu = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
91
92 /* return total */
93 return npl + npu;
94 }
95
96
97
98 static void flatPhotonPartition (EmissionMap* emap)
99 /* Partition flat source for photon emission */
100 {
101 RREAL *vp;
102 double du2, dv2;
103
104 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
105 emap -> partArea = srcsizerat * thescene.cusize;
106 emap -> partArea *= emap -> partArea;
107 vp = emap -> src -> ss [SU];
108 du2 = DOT(vp, vp) / emap -> partArea;
109 vp = emap -> src -> ss [SV];
110 dv2 = DOT(vp, vp) / emap -> partArea;
111 emap -> partitionCnt = 0;
112 emap -> numPartitions = flatPhotonPartition2(emap, 1, emap -> src -> sloc,
113 emap -> src -> ss [SU],
114 emap -> src -> ss [SV],
115 du2, dv2);
116 emap -> partitionCnt = 0;
117 emap -> partArea = emap -> src -> ss2 / emap -> numPartitions;
118 }
119
120
121
122 static void sourcePhotonPartition (EmissionMap* emap)
123 /* Partition scene cube faces or photon port for photon emission from
124 distant source */
125 {
126 if (emap -> port) {
127 /* Partition photon port */
128 SRCREC *src = emap -> src;
129 emap -> src = emap -> port;
130 photonPartition [emap -> src -> so -> otype] (emap);
131 emap -> src = src;
132 }
133
134 else {
135 /* No photon ports defined, so partition scene cube faces */
136 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
137 setpart(emap -> partitions, 0, S0);
138 emap -> partitionCnt = 0;
139 emap -> numPartitions = 1 / srcsizerat;
140 emap -> numPartitions *= emap -> numPartitions;
141 emap -> partArea = sqr(thescene.cusize) / emap -> numPartitions;
142 emap -> numPartitions *= 6;
143 }
144 }
145
146
147
148 static void spherePhotonPartition (EmissionMap* emap)
149 /* Partition spherical source into equal solid angles using uniform
150 mapping for photon emission */
151 {
152 unsigned numTheta, numPhi;
153
154 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
155 setpart(emap -> partitions, 0, S0);
156 emap -> partArea = 4 * PI * sqr(emap -> src -> srad);
157 emap -> numPartitions = emap -> partArea /
158 sqr(srcsizerat * thescene.cusize);
159
160 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
161 numPhi = 0.5 * PI * numTheta + 0.5;
162
163 emap -> numPartitions = (unsigned long)numTheta * numPhi;
164 emap -> partitionCnt = 0;
165 emap -> partArea /= emap -> numPartitions;
166 }
167
168
169
170 static int cylPhotonPartition2 (EmissionMap* emap, unsigned long mp,
171 FVECT cent, FVECT axis, double d2)
172 /* Recursive part of cyPhotonPartition(..) */
173 {
174 FVECT newct, newax;
175 unsigned long npl, npu;
176
177 if (mp > emap -> maxPartitions) {
178 /* Enlarge partition array */
179 emap -> maxPartitions <<= 1;
180 emap -> partitions = (unsigned char*)realloc(emap -> partitions,
181 emap -> maxPartitions >> 1);
182 if (!emap -> partitions)
183 error(USER, "can't allocate source partitions");
184
185 memset(emap -> partitions + (emap -> maxPartitions >> 2), 0,
186 emap -> maxPartitions >> 2);
187 }
188
189 if (d2 <= 1) {
190 /* hit limit? */
191 setpart(emap -> partitions, emap -> partitionCnt, S0);
192 emap -> partitionCnt++;
193 return 1;
194 }
195
196 /* subdivide */
197 setpart(emap -> partitions, emap -> partitionCnt, SU);
198 emap -> partitionCnt++;
199 newax [0] = 0.5 * axis [0];
200 newax [1] = 0.5 * axis [1];
201 newax [2] = 0.5 * axis [2];
202 d2 *= 0.25;
203
204 /* lower half */
205 newct [0] = cent [0] - newax [0];
206 newct [1] = cent [1] - newax [1];
207 newct [2] = cent [2] - newax [2];
208 npl = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
209
210 /* upper half */
211 newct [0] = cent [0] + newax [0];
212 newct [1] = cent [1] + newax [1];
213 newct [2] = cent [2] + newax [2];
214 npu = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
215
216 /* return total */
217 return npl + npu;
218 }
219
220
221
222 static void cylPhotonPartition (EmissionMap* emap)
223 /* Partition cylindrical source for photon emission */
224 {
225 double d2;
226
227 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
228 d2 = srcsizerat * thescene.cusize;
229 d2 = PI * emap -> src -> ss2 / (2 * emap -> src -> srad * sqr(d2));
230 d2 *= d2 * DOT(emap -> src -> ss [SU], emap -> src -> ss [SU]);
231
232 emap -> partitionCnt = 0;
233 emap -> numPartitions = cylPhotonPartition2(emap, 1, emap -> src -> sloc,
234 emap -> src -> ss [SU], d2);
235 emap -> partitionCnt = 0;
236 emap -> partArea = PI * emap -> src -> ss2 / emap -> numPartitions;
237 }
238
239
240
241 static void flatPhotonOrigin (EmissionMap* emap)
242 /* Init emission map with photon origin and associated surface axes on
243 flat light source surface. Also sets source aperture and sampling
244 hemisphere axes at origin */
245 {
246 int i, cent[3], size[3], parr[2];
247 FVECT vpos;
248
249 cent [0] = cent [1] = cent [2] = 0;
250 size [0] = size [1] = size [2] = emap -> maxPartitions;
251 parr [0] = 0;
252 parr [1] = emap -> partitionCnt;
253
254 if (!skipparts(cent, size, parr, emap -> partitions))
255 error(CONSISTENCY, "bad source partition in flatPhotonOrigin");
256
257 vpos [0] = (1 - 2 * pmapRandom(partState)) * size [0] /
258 emap -> maxPartitions;
259 vpos [1] = (1 - 2 * pmapRandom(partState)) * size [1] /
260 emap -> maxPartitions;
261 vpos [2] = 0;
262
263 for (i = 0; i < 3; i++)
264 vpos [i] += (double)cent [i] / emap -> maxPartitions;
265
266 /* Get origin */
267 for (i = 0; i < 3; i++)
268 emap -> photonOrg [i] = emap -> src -> sloc [i] +
269 vpos [SU] * emap -> src -> ss [SU][i] +
270 vpos [SV] * emap -> src -> ss [SV][i] +
271 vpos [SW] * emap -> src -> ss [SW][i];
272
273 /* Get surface axes */
274 VCOPY(emap -> us, emap -> src -> ss [SU]);
275 normalize(emap -> us);
276 VCOPY(emap -> ws, emap -> src -> ss [SW]);
277
278 if (emap -> port)
279 /* Acts as a photon port; reverse normal as it points INSIDE per
280 * mkillum convention */
281 for (i = 0; i < 3; i++)
282 emap -> ws [i] = -emap -> ws [i];
283
284 fcross(emap -> vs, emap -> ws, emap -> us);
285
286 /* Get hemisphere axes & aperture */
287 if (emap -> src -> sflags & SSPOT) {
288 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
289 i = 0;
290
291 do {
292 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
293 emap -> vh [i++] = 1;
294 fcross(emap -> uh, emap -> vh, emap -> wh);
295 } while (normalize(emap -> uh) < FTINY);
296
297 fcross(emap -> vh, emap -> wh, emap -> uh);
298 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
299 }
300
301 else {
302 VCOPY(emap -> uh, emap -> us);
303 VCOPY(emap -> vh, emap -> vs);
304 VCOPY(emap -> wh, emap -> ws);
305 emap -> cosThetaMax = 0;
306 }
307 }
308
309
310
311 static void spherePhotonOrigin (EmissionMap* emap)
312 /* Init emission map with photon origin and associated surface axes on
313 spherical light source. Also sets source aperture and sampling
314 hemisphere axes at origin */
315 {
316 int i = 0;
317 unsigned numTheta, numPhi, t, p;
318 RREAL cosTheta, sinTheta, phi;
319
320 /* Get current partition */
321 numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
322 numPhi = 0.5 * PI * numTheta + 0.5;
323
324 t = emap -> partitionCnt / numPhi;
325 p = emap -> partitionCnt - t * numPhi;
326
327 emap -> ws [2] = cosTheta = 1 - 2 * (t + pmapRandom(partState)) / numTheta;
328 sinTheta = sqrt(1 - sqr(cosTheta));
329 phi = 2 * PI * (p + pmapRandom(partState)) / numPhi;
330 emap -> ws [0] = cos(phi) * sinTheta;
331 emap -> ws [1] = sin(phi) * sinTheta;
332
333 if (emap -> port)
334 /* Acts as a photon port; reverse normal as it points INSIDE per
335 * mkillum convention */
336 for (i = 0; i < 3; i++)
337 emap -> ws [i] = -emap -> ws [i];
338
339 /* Get surface axes us & vs perpendicular to ws */
340 do {
341 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
342 emap -> vs [i++] = 1;
343 fcross(emap -> us, emap -> vs, emap -> ws);
344 } while (normalize(emap -> us) < FTINY);
345
346 fcross(emap -> vs, emap -> ws, emap -> us);
347
348 /* Get origin */
349 for (i = 0; i < 3; i++)
350 emap -> photonOrg [i] = emap -> src -> sloc [i] +
351 emap -> src -> srad * emap -> ws [i];
352
353 /* Get hemisphere axes & aperture */
354 if (emap -> src -> sflags & SSPOT) {
355 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
356 i = 0;
357
358 do {
359 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
360 emap -> vh [i++] = 1;
361 fcross(emap -> uh, emap -> vh, emap -> wh);
362 } while (normalize(emap -> uh) < FTINY);
363
364 fcross(emap -> vh, emap -> wh, emap -> uh);
365 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
366 }
367
368 else {
369 VCOPY(emap -> uh, emap -> us);
370 VCOPY(emap -> vh, emap -> vs);
371 VCOPY(emap -> wh, emap -> ws);
372 emap -> cosThetaMax = 0;
373 }
374 }
375
376
377
378 static void sourcePhotonOrigin (EmissionMap* emap)
379 /* Init emission map with photon origin and associated surface axes
380 on scene cube face for distant light source. Also sets source
381 aperture (solid angle) and sampling hemisphere axes at origin */
382 {
383 unsigned long i, partsPerDim, partsPerFace;
384 unsigned face;
385 RREAL du, dv;
386
387 if (emap -> port) {
388 /* Get origin on photon port */
389 SRCREC *src = emap -> src;
390 emap -> src = emap -> port;
391 photonOrigin [emap -> src -> so -> otype] (emap);
392 emap -> src = src;
393 }
394
395 else {
396 /* No ports defined, so get origin on scene cube face and SUFFA! */
397 /* Get current face from partition number */
398 partsPerDim = 1 / srcsizerat;
399 partsPerFace = sqr(partsPerDim);
400 face = emap -> partitionCnt / partsPerFace;
401
402 if (!(emap -> partitionCnt % partsPerFace)) {
403 /* Skipped to a new face; get its normal */
404 emap -> ws [0] = emap -> ws [1] = emap -> ws [2] = 0;
405 emap -> ws [face >> 1] = face & 1 ? 1 : -1;
406
407 /* Get surface axes us & vs perpendicular to ws */
408 face >>= 1;
409 emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
410 emap -> vs [(face + (emap -> ws [face] > 0 ? 2 : 1)) % 3] = 1;
411 fcross(emap -> us, emap -> vs, emap -> ws);
412 }
413
414 /* Get jittered offsets within face from partition number
415 (in range [-0.5, 0.5]) */
416 i = emap -> partitionCnt % partsPerFace;
417 du = (i / partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
418 dv = (i % partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
419
420 /* Jittered destination point within partition */
421 for (i = 0; i < 3; i++)
422 emap -> photonOrg [i] = thescene.cuorg [i] +
423 thescene.cusize * (0.5 + du * emap -> us [i] +
424 dv * emap -> vs [i] +
425 0.5 * emap -> ws [i]);
426 }
427
428 /* Get hemisphere axes & aperture */
429 VCOPY(emap -> wh, emap -> src -> sloc);
430 i = 0;
431
432 do {
433 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
434 emap -> vh [i++] = 1;
435 fcross(emap -> uh, emap -> vh, emap -> wh);
436 } while (normalize(emap -> uh) < FTINY);
437
438 fcross(emap -> vh, emap -> wh, emap -> uh);
439
440 /* Get aperture */
441 emap -> cosThetaMax = 1 - emap -> src -> ss2 / (2 * PI);
442 emap -> cosThetaMax = min(1, max(-1, emap -> cosThetaMax));
443 }
444
445
446
447 static void cylPhotonOrigin (EmissionMap* emap)
448 /* Init emission map with photon origin and associated surface axes
449 on cylindrical light source surface. Also sets source aperture
450 and sampling hemisphere axes at origin */
451 {
452 int i, cent[3], size[3], parr[2];
453 FVECT v;
454
455 cent [0] = cent [1] = cent [2] = 0;
456 size [0] = size [1] = size [2] = emap -> maxPartitions;
457 parr [0] = 0;
458 parr [1] = emap -> partitionCnt;
459
460 if (!skipparts(cent, size, parr, emap -> partitions))
461 error(CONSISTENCY, "bad source partition in cylPhotonOrigin");
462
463 v [SU] = 0;
464 v [SV] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
465 emap -> maxPartitions;
466 v [SW] = (1 - 2 * pmapRandom(partState)) * (double)size [2] /
467 emap -> maxPartitions;
468 normalize(v);
469 v [SU] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
470 emap -> maxPartitions;
471
472 for (i = 0; i < 3; i++)
473 v [i] += (double)cent [i] / emap -> maxPartitions;
474
475 /* Get surface axes */
476 for (i = 0; i < 3; i++)
477 emap -> photonOrg [i] = emap -> ws [i] =
478 (v [SV] * emap -> src -> ss [SV][i] +
479 v [SW] * emap -> src -> ss [SW][i]) / 0.8559;
480
481 if (emap -> port)
482 /* Acts as a photon port; reverse normal as it points INSIDE per
483 * mkillum convention */
484 for (i = 0; i < 3; i++)
485 emap -> ws [i] = -emap -> ws [i];
486
487 normalize(emap -> ws);
488 VCOPY(emap -> us, emap -> src -> ss [SU]);
489 normalize(emap -> us);
490 fcross(emap -> vs, emap -> ws, emap -> us);
491
492 /* Get origin */
493 for (i = 0; i < 3; i++)
494 emap -> photonOrg [i] += v [SU] * emap -> src -> ss [SU][i] +
495 emap -> src -> sloc [i];
496
497 /* Get hemisphere axes & aperture */
498 if (emap -> src -> sflags & SSPOT) {
499 VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
500 i = 0;
501
502 do {
503 emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
504 emap -> vh [i++] = 1;
505 fcross(emap -> uh, emap -> vh, emap -> wh);
506 } while (normalize(emap -> uh) < FTINY);
507
508 fcross(emap -> vh, emap -> wh, emap -> uh);
509 emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
510 }
511
512 else {
513 VCOPY(emap -> uh, emap -> us);
514 VCOPY(emap -> vh, emap -> vs);
515 VCOPY(emap -> wh, emap -> ws);
516 emap -> cosThetaMax = 0;
517 }
518 }
519
520
521
522 void getPhotonPorts ()
523 /* Find geometry declared as photon ports */
524 {
525 OBJECT i;
526 OBJREC* obj;
527
528 /* Check for missing port modifiers */
529 if (!ambset [0])
530 error(USER, "no photon ports found");
531
532 for (i = 0; i < nobjects; i++) {
533 obj = objptr(i);
534
535 if (inset(ambset, obj -> omod)) {
536 /* Add photon port */
537 photonPorts = (SRCREC*)realloc(photonPorts,
538 (numPhotonPorts + 1) *
539 sizeof(SRCREC));
540 if (!photonPorts)
541 error(USER, "can't allocate photon ports");
542
543 photonPorts [numPhotonPorts].so = obj;
544 photonPorts [numPhotonPorts].sflags = 0;
545
546 if (!sfun [obj -> otype].of || !sfun[obj -> otype].of -> setsrc)
547 objerror(obj, USER, "illegal photon port");
548
549 setsource(photonPorts + numPhotonPorts, obj);
550 numPhotonPorts++;
551 }
552 }
553 }
554
555
556
557 static void defaultEmissionFunc (EmissionMap* emap)
558 /* Default behaviour when no emission funcs defined for this source type */
559 {
560 objerror(emap -> src -> so, INTERNAL,
561 "undefined photon emission function");
562 }
563
564
565
566 void initPhotonEmissionFuncs ()
567 /* Init photonPartition[] and photonOrigin[] dispatch tables */
568 {
569 int i;
570
571 for (i = 0; i < NUMOTYPE; i++)
572 photonPartition [i] = photonOrigin [i] = defaultEmissionFunc;
573
574 photonPartition [OBJ_FACE] = photonPartition [OBJ_RING] = flatPhotonPartition;
575 photonPartition [OBJ_SOURCE] = sourcePhotonPartition;
576 photonPartition [OBJ_SPHERE] = spherePhotonPartition;
577 photonPartition [OBJ_CYLINDER] = cylPhotonPartition;
578 photonOrigin [OBJ_FACE] = photonOrigin [OBJ_RING] = flatPhotonOrigin;
579 photonOrigin [OBJ_SOURCE] = sourcePhotonOrigin;
580 photonOrigin [OBJ_SPHERE] = spherePhotonOrigin;
581 photonOrigin [OBJ_CYLINDER] = cylPhotonOrigin;
582 }
583
584
585
586 void initPhotonEmission (EmissionMap *emap, float numPdfSamples)
587 /* Initialize photon emission from partitioned light source emap -> src;
588 * this involves integrating the flux emitted from the current photon
589 * origin emap -> photonOrg and setting up a PDF to sample the emission
590 * distribution with numPdfSamples samples */
591 {
592 unsigned i, t, p;
593 double phi, cosTheta, sinTheta, du, dv, dOmega, thetaScale;
594 EmissionSample* sample;
595 const OBJREC* mod = findmaterial(emap -> src -> so);
596 static RAY r;
597 #if 0
598 static double lastCosNorm = FHUGE;
599 static SRCREC *lastSrc = NULL, *lastPort = NULL;
600 #endif
601
602 setcolor(emap -> partFlux, 0, 0, 0);
603
604 photonOrigin [emap -> src -> so -> otype] (emap);
605 cosTheta = DOT(emap -> ws, emap -> wh);
606
607 #if 0
608 if (emap -> src == lastSrc && emap -> port == lastPort &&
609 (emap -> src -> sflags & SDISTANT || mod -> omod == OVOID) &&
610 cosTheta == lastCosNorm)
611 /* Same source, port, and aperture-normal angle, and source is
612 either distant (and thus translationally invariant) or has
613 no modifier --> flux unchanged */
614 /* BUG: this optimisation ignores partial occlusion of ports and
615 can lead to erroneous "zero emission" bailouts.
616 It can also lead to bias with modifiers exhibiting high variance!
617 Disabled for now -- RS 12/13 */
618 return;
619
620 lastSrc = emap -> src;
621 lastPort = emap -> port;
622 lastCosNorm = cosTheta;
623 #endif
624
625 /* Need to recompute flux & PDF */
626 emap -> cdf = 0;
627 emap -> numSamples = 0;
628
629 if (cosTheta <= 0 &&
630 sqrt(1 - sqr(cosTheta)) <= emap -> cosThetaMax + FTINY)
631 /* Aperture below surface; no emission from current origin */
632 return;
633
634 if (mod -> omod == OVOID && !emap -> port &&
635 (cosTheta >= 1 - FTINY || (emap -> src -> sflags & SDISTANT &&
636 acos(cosTheta) + acos(emap -> cosThetaMax) <= 0.5 * PI))) {
637 /* Source is unmodified and has no port (which requires testing for
638 occlusion), and is either local with normal aligned aperture or
639 distant with aperture above surface; analytical flux & PDF */
640 setcolor(emap -> partFlux, mod -> oargs.farg [0],
641 mod -> oargs.farg [1], mod -> oargs.farg [2]);
642
643 /* Multiply radiance by Omega * dA to get flux */
644 scalecolor(emap -> partFlux,
645 PI * cosTheta * (1 - sqr(max(emap -> cosThetaMax, 0))) *
646 emap -> partArea);
647 }
648
649 else {
650 /* Source is either modified, has a port, is local with off-normal
651 aperture, or distant with aperture partly below surface; get flux
652 via numerical integration */
653 thetaScale = (1 - emap -> cosThetaMax);
654
655 /* Figga out numba of aperture samples for integration;
656 numTheta / numPhi ratio is 1 / PI */
657 du = sqrt(pdfSamples * 2 * thetaScale);
658 emap -> numTheta = max(du + 0.5, 1);
659 emap -> numPhi = max(PI * du + 0.5, 1);
660
661 dOmega = 2 * PI * thetaScale / (emap -> numTheta * emap -> numPhi);
662 thetaScale /= emap -> numTheta;
663
664 /* Allocate PDF, baby */
665 sample = emap -> samples = (EmissionSample*)
666 realloc(emap -> samples,
667 sizeof(EmissionSample) *
668 emap -> numTheta * emap -> numPhi);
669 if (!emap -> samples)
670 error(USER, "can't allocate emission PDF");
671
672 VCOPY(r.rorg, emap -> photonOrg);
673 VCOPY(r.rop, emap -> photonOrg);
674 r.rmax = FHUGE;
675
676 for (t = 0; t < emap -> numTheta; t++) {
677 for (p = 0; p < emap -> numPhi; p++) {
678 /* This uniform mapping handles 0 <= thetaMax <= PI */
679 cosTheta = 1 - (t + pmapRandom(emitState)) * thetaScale;
680 sinTheta = sqrt(1 - sqr(cosTheta));
681 phi = 2 * PI * (p + pmapRandom(emitState)) / emap -> numPhi;
682 du = cos(phi) * sinTheta;
683 dv = sin(phi) * sinTheta;
684 rayorigin(&r, PRIMARY, NULL, NULL);
685
686 for (i = 0; i < 3; i++)
687 r.rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
688 cosTheta * emap -> wh [i];
689
690 /* Sample behind surface? */
691 VCOPY(r.ron, emap -> ws);
692 if ((r.rod = DOT(r.rdir, r.ron)) <= 0)
693 continue;
694
695 /* Get radiance emitted in this direction; to get flux we
696 multiply by cos(theta_surface), dOmega, and dA. Ray
697 is directed towards light source for raytexture(). */
698 if (!(emap -> src -> sflags & SDISTANT))
699 for (i = 0; i < 3; i++)
700 r.rdir [i] = -r.rdir [i];
701
702 /* Port occluded in this direction? */
703 if (emap -> port && localhit(&r, &thescene))
704 continue;
705
706 raytexture(&r, mod -> omod);
707 setcolor(r.rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
708 mod -> oargs.farg [2]);
709 multcolor(r.rcol, r.pcol);
710
711 /* Multiply by cos(theta_surface) */
712 scalecolor(r.rcol, r.rod);
713
714 /* Add PDF sample if nonzero; importance info for photon emission
715 * could go here... */
716 if (colorAvg(r.rcol)) {
717 copycolor(sample -> pdf, r.rcol);
718 sample -> cdf = emap -> cdf += colorAvg(sample -> pdf);
719 sample -> theta = t;
720 sample++ -> phi = p;
721 emap -> numSamples++;
722 addcolor(emap -> partFlux, r.rcol);
723 }
724 }
725 }
726
727 /* Multiply by dOmega * dA */
728 scalecolor(emap -> partFlux, dOmega * emap -> partArea);
729 }
730 }
731
732
733
734 #define vomitPhoton emitPhoton
735 #define bluarrrghPhoton vomitPhoton
736
737 void emitPhoton (const EmissionMap* emap, RAY* ray)
738 /* Emit photon from current partition emap -> partitionCnt based on
739 emission distribution. Returns new photon ray. */
740 {
741 unsigned long i, lo, hi;
742 const EmissionSample* sample = emap -> samples;
743 RREAL du, dv, cosTheta, cosThetaSqr, sinTheta, phi;
744 const OBJREC* mod = findmaterial(emap -> src -> so);
745
746 /* Choose a new origin within current partition for every
747 emitted photon to break up clustering artifacts */
748 photonOrigin [emap -> src -> so -> otype] ((EmissionMap*)emap);
749 rayorigin(ray, PRIMARY, NULL, NULL);
750 ray -> rmax = FHUGE;
751
752 if (!emap -> numSamples) {
753 /* Source is unmodified and has no port, and either local with
754 normal aligned aperture, or distant with aperture above surface;
755 use cosine weighted distribution */
756 cosThetaSqr = 1 - pmapRandom(emitState) *
757 (1 - sqr(max(emap -> cosThetaMax, 0)));
758 cosTheta = sqrt(cosThetaSqr);
759 sinTheta = sqrt(1 - cosThetaSqr);
760 phi = 2 * PI * pmapRandom(emitState);
761 setcolor(ray -> rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
762 mod -> oargs.farg [2]);
763 }
764
765 else {
766 /* Source is either modified, has a port, is local with off-normal
767 aperture, or distant with aperture partly below surface; choose
768 direction from constructed cumulative distribution function with
769 Monte Carlo inversion using binary search. */
770 du = pmapRandom(emitState) * emap -> cdf;
771 lo = 1;
772 hi = emap -> numSamples;
773
774 while (hi > lo) {
775 i = (lo + hi) >> 1;
776 sample = emap -> samples + i - 1;
777
778 if (sample -> cdf >= du)
779 hi = i;
780 if (sample -> cdf < du)
781 lo = i + 1;
782 }
783
784 /* This is a uniform mapping, mon */
785 cosTheta = 1 - (sample -> theta + pmapRandom(emitState)) *
786 (1 - emap -> cosThetaMax) / emap -> numTheta;
787 sinTheta = sqrt(1 - sqr(cosTheta));
788 phi = 2 * PI * (sample -> phi + pmapRandom(emitState)) / emap -> numPhi;
789 copycolor(ray -> rcol, sample -> pdf);
790 }
791
792 /* Normalize photon flux so that average over RGB is 1 */
793 colorNorm(ray -> rcol);
794
795 VCOPY(ray -> rorg, emap -> photonOrg);
796 du = cos(phi) * sinTheta;
797 dv = sin(phi) * sinTheta;
798
799 for (i = 0; i < 3; i++)
800 ray -> rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
801 cosTheta * emap -> wh [i];
802
803 if (emap -> src -> sflags & SDISTANT)
804 /* Distant source; reverse ray direction to point into the scene. */
805 for (i = 0; i < 3; i++)
806 ray -> rdir [i] = -ray -> rdir [i];
807
808 if (emap -> port)
809 /* Photon emitted from port; move origin just behind port so it
810 will be scattered */
811 for (i = 0; i < 3; i++)
812 ray -> rorg [i] -= 2 * FTINY * ray -> rdir [i];
813
814 /* Assign emitting light source index */
815 ray -> rsrc = emap -> src - source;
816 }
817
818
819
820 void multDirectPmap (RAY *r)
821 /* Factor irradiance from direct photons into r -> rcol; interface to
822 * direct() */
823 {
824 COLOR photonIrrad;
825
826 /* Lookup direct photon irradiance */
827 (directPmap -> lookup)(directPmap, r, photonIrrad);
828
829 /* Multiply with coefficient in ray */
830 multcolor(r -> rcol, photonIrrad);
831
832 return;
833 }
834
835
836
837 void inscatterVolumePmap (RAY *r, COLOR inscatter)
838 /* Add inscattering from volume photon map; interface to srcscatter() */
839 {
840 /* Add ambient in-scattering via lookup callback */
841 (volumePmap -> lookup)(volumePmap, r, inscatter);
842 }
