root/radiance/ray/src/rt/pmapsrc.c
Revision: 2.20
Committed: Fri Apr 9 17:42:34 2021 UTC (4 years, 4 months ago) by rschregle
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 2.19: +8 -4 lines
fix(mkpmap): CDF inversion binary search bug in emitPhoton().
# User Rev Content
1 greg 2.7 #ifndef lint
2 rschregle 2.20 static const char RCSid[] = "$Id: pmapsrc.c,v 2.19 2020/08/10 19:51:20 rschregle Exp $";
3 greg 2.7 #endif
4 greg 2.1 /*
5 rschregle 2.18 ======================================================================
6 greg 2.1 Photon map support routines for emission from light sources
7
8     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9     (c) Fraunhofer Institute for Solar Energy Systems,
10 rschregle 2.18 supported by the German Research Foundation (DFG)
11     under the FARESYS project.
12 rschregle 2.3 (c) Lucerne University of Applied Sciences and Arts,
13 rschregle 2.18 supported by the Swiss National Science Foundation (SNSF #147053).
14     (c) Tokyo University of Science,
15     supported by the JSPS KAKENHI Grant Number JP19KK0115.
16     ======================================================================
17
18 rschregle 2.20 $Id: pmapsrc.c,v 2.19 2020/08/10 19:51:20 rschregle Exp $"
19 greg 2.1 */
20
21
22
23     #include "pmapsrc.h"
24     #include "pmap.h"
25     #include "pmaprand.h"
26     #include "otypes.h"
27 greg 2.17 #include "otspecial.h"
28 greg 2.1
29 rschregle 2.18
30
31 rschregle 2.15 /* List of photon port modifier names */
32     char *photonPortList [MAXSET + 1] = {NULL};
33     /* Photon port objects (with modifiers in photonPortMods) */
34     SRCREC *photonPorts = NULL;
35 greg 2.1 unsigned numPhotonPorts = 0;
36
37     void (*photonPartition [NUMOTYPE]) (EmissionMap*);
38     void (*photonOrigin [NUMOTYPE]) (EmissionMap*);
39
40 rschregle 2.18
41
42     /* PHOTON PORT SUPPORT ROUTINES ------------------------------------------ */
43
44
45
46     /* Get/set photon port orientation flags from/in source flags.
47     * HACK: the port orientation flags are embedded in the source flags and
48     * shifted so they won't clobber the latter, since these are interpreted
49     * by the *PhotonPartition() and *PhotonOrigin() routines! */
50     #define PMAP_SETPORTFLAGS(portdir) ((int)(portdir) << 14)
51     #define PMAP_GETPORTFLAGS(sflags) ((sflags) >> 14)
52
53     /* Set number of source partitions.
54     * HACK: this is doubled if the source acts as a bidirectionally
55     * emitting photon port, resulting in alternating front/backside partitions,
56     * although essentially each partition is just used twice with opposing
57     * normals. */
58     #define PMAP_SETNUMPARTITIONS(emap) ( \
59     (emap) -> numPartitions <<= ( \
60     (emap) -> port && \
61     PMAP_GETPORTFLAGS((emap) -> port -> sflags) == PMAP_PORTBI \
62     ) \
63     )
64
65     /* Get current source partition and numer of partitions
66     * HACK: halve the number partitions if the source acts as a bidrectionally
67     * emitting photon port, since each partition is used twice with opposing
68     * normals. */
69     #define PMAP_GETNUMPARTITIONS(emap) (\
70     (emap) -> numPartitions >> ( \
71     (emap) -> port && \
72     PMAP_GETPORTFLAGS((emap) -> port -> sflags) == PMAP_PORTBI \
73     ) \
74     )
75     #define PMAP_GETPARTITION(emap) ( \
76     (emap) -> partitionCnt >> ( \
77     (emap) -> port && \
78     PMAP_GETPORTFLAGS((emap) -> port -> sflags) == PMAP_PORTBI \
79     ) \
80     )
81
82
83
84     void getPhotonPorts (char **portList)
85     /* Find geometry declared as photon ports from modifiers in portList */
86     {
87     OBJECT i;
88     OBJREC *obj, *mat;
89     int mLen;
90     char **lp;
91 greg 2.1
92 rschregle 2.18 /* Init photon port objects */
93     photonPorts = NULL;
94
95     if (!portList [0])
96     return;
97
98     for (i = numPhotonPorts = 0; i < nobjects; i++) {
99     obj = objptr(i);
100     mat = findmaterial(obj);
101
102     /* Check if object is a surface and NOT a light source (duh) and
103     * resolve its material (if any) via any aliases, then check for
104     * inclusion in modifier list; note use of strncmp() to ignore port
105     * flags */
106     if (issurface(obj -> otype) && mat && !islight(mat -> otype)) {
107     mLen = strlen(mat -> oname);
108     for (lp = portList; *lp && strncmp(mat -> oname, *lp, mLen); lp++);
109
110     if (*lp) {
111     /* Add photon port */
112     photonPorts = (SRCREC*)realloc(
113     photonPorts, (numPhotonPorts + 1) * sizeof(SRCREC)
114     );
115     if (!photonPorts)
116     error(USER, "can't allocate photon ports");
117
118     photonPorts [numPhotonPorts].so = obj;
119     /* Extract port orientation flags and embed in source flags.
120     * Note setsource() combines (i.e. ORs) these with the actual
121     * source flags below. */
122     photonPorts [numPhotonPorts].sflags =
123     PMAP_SETPORTFLAGS((*lp) [mLen]);
124
125     if (!sfun [obj -> otype].of || !sfun[obj -> otype].of -> setsrc)
126     objerror(obj, USER, "illegal photon port");
127
128     setsource(photonPorts + numPhotonPorts, obj);
129     numPhotonPorts++;
130     }
131     }
132     }
133     if (!numPhotonPorts)
134     error(USER, "no valid photon ports found");
135     }
136 greg 2.1
137 rschregle 2.18
138
139     static void setPhotonPortNormal (EmissionMap* emap)
140 rschregle 2.19 /* Set normal for current photon port partition (if defined) based on its
141     * orientation */
142 rschregle 2.18 {
143
144 rschregle 2.19 int i, portFlags;
145
146     if (emap -> port) {
147     /* Extract photon port orientation flags, set surface normal as follows:
148     -- Port oriented forwards --> flip surface normal to point outwards,
149     since normal points inwards per mkillum convention)
150     -- Port oriented backwards --> surface normal is NOT flipped, since
151     it already points inwards.
152     -- Port is bidirectionally/bilaterally oriented --> flip normal based
153     on the parity of the current partition emap -> partitionCnt. In
154     this case, photon emission alternates between port front/back
155     faces for consecutive partitions.
156     */
157     portFlags = PMAP_GETPORTFLAGS(emap -> port -> sflags);
158
159     if (
160     portFlags == PMAP_PORTFWD ||
161     portFlags == PMAP_PORTBI && !(emap -> partitionCnt & 1)
162     )
163     for (i = 0; i < 3; i++)
164     emap -> ws [i] = -emap -> ws [i];
165     }
166 rschregle 2.18 }
167
168
169
170     /* SOURCE / PHOTON PORT PARTITIONING ROUTINES----------------------------- */
171
172
173
174     static int flatPhotonPartition2 (
175     EmissionMap* emap, unsigned long mp, FVECT cent, FVECT u, FVECT v,
176     double du2, double dv2
177     )
178 greg 2.1 /* Recursive part of flatPhotonPartition(..) */
179     {
180     FVECT newct, newax;
181     unsigned long npl, npu;
182
183     if (mp > emap -> maxPartitions) {
184     /* Enlarge partition array */
185     emap -> maxPartitions <<= 1;
186 rschregle 2.18 emap -> partitions = (unsigned char*)realloc(
187     emap -> partitions, emap -> maxPartitions >> 1
188     );
189 greg 2.1
190     if (!emap -> partitions)
191     error(USER, "can't allocate source partitions");
192
193 rschregle 2.18 memset(
194     emap -> partitions + (emap -> maxPartitions >> 2), 0,
195     emap -> maxPartitions >> 2
196     );
197 greg 2.1 }
198
199     if (du2 * dv2 <= 1) { /* hit limit? */
200     setpart(emap -> partitions, emap -> partitionCnt, S0);
201     emap -> partitionCnt++;
202     return 1;
203     }
204
205     if (du2 > dv2) { /* subdivide in U */
206     setpart(emap -> partitions, emap -> partitionCnt, SU);
207     emap -> partitionCnt++;
208     newax [0] = 0.5 * u [0];
209     newax [1] = 0.5 * u [1];
210     newax [2] = 0.5 * u [2];
211     u = newax;
212     du2 *= 0.25;
213     }
214
215     else { /* subdivide in V */
216     setpart(emap -> partitions, emap -> partitionCnt, SV);
217     emap -> partitionCnt++;
218     newax [0] = 0.5 * v [0];
219     newax [1] = 0.5 * v [1];
220     newax [2] = 0.5 * v [2];
221     v = newax;
222     dv2 *= 0.25;
223     }
224
225     /* lower half */
226     newct [0] = cent [0] - newax [0];
227     newct [1] = cent [1] - newax [1];
228     newct [2] = cent [2] - newax [2];
229     npl = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
230
231     /* upper half */
232     newct [0] = cent [0] + newax [0];
233     newct [1] = cent [1] + newax [1];
234     newct [2] = cent [2] + newax [2];
235     npu = flatPhotonPartition2(emap, mp << 1, newct, u, v, du2, dv2);
236
237     /* return total */
238     return npl + npu;
239     }
240
241
242
243     static void flatPhotonPartition (EmissionMap* emap)
244     /* Partition flat source for photon emission */
245     {
246     RREAL *vp;
247     double du2, dv2;
248
249 greg 2.2 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
250 greg 2.1 emap -> partArea = srcsizerat * thescene.cusize;
251     emap -> partArea *= emap -> partArea;
252     vp = emap -> src -> ss [SU];
253     du2 = DOT(vp, vp) / emap -> partArea;
254     vp = emap -> src -> ss [SV];
255     dv2 = DOT(vp, vp) / emap -> partArea;
256     emap -> partitionCnt = 0;
257 rschregle 2.18 emap -> numPartitions = flatPhotonPartition2(
258     emap, 1, emap -> src -> sloc,
259     emap -> src -> ss [SU], emap -> src -> ss [SV], du2, dv2
260     );
261 greg 2.1 emap -> partitionCnt = 0;
262     emap -> partArea = emap -> src -> ss2 / emap -> numPartitions;
263     }
264
265
266
267     static void sourcePhotonPartition (EmissionMap* emap)
268     /* Partition scene cube faces or photon port for photon emission from
269     distant source */
270     {
271     if (emap -> port) {
272 rschregle 2.18 /* Relay partitioning to photon port */
273 greg 2.1 SRCREC *src = emap -> src;
274     emap -> src = emap -> port;
275     photonPartition [emap -> src -> so -> otype] (emap);
276 rschregle 2.18 PMAP_SETNUMPARTITIONS(emap);
277 greg 2.1 emap -> src = src;
278     }
279
280     else {
281 rschregle 2.18 /* No photon ports defined; partition scene cube faces (SUBOPTIMAL) */
282 greg 2.2 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
283 greg 2.1 setpart(emap -> partitions, 0, S0);
284     emap -> partitionCnt = 0;
285     emap -> numPartitions = 1 / srcsizerat;
286     emap -> numPartitions *= emap -> numPartitions;
287     emap -> partArea = sqr(thescene.cusize) / emap -> numPartitions;
288     emap -> numPartitions *= 6;
289     }
290     }
291
292
293
294     static void spherePhotonPartition (EmissionMap* emap)
295     /* Partition spherical source into equal solid angles using uniform
296     mapping for photon emission */
297     {
298     unsigned numTheta, numPhi;
299
300 greg 2.2 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
301 greg 2.1 setpart(emap -> partitions, 0, S0);
302     emap -> partArea = 4 * PI * sqr(emap -> src -> srad);
303 rschregle 2.18 emap -> numPartitions =
304     emap -> partArea / sqr(srcsizerat * thescene.cusize);
305 greg 2.1
306     numTheta = max(sqrt(2 * emap -> numPartitions / PI) + 0.5, 1);
307     numPhi = 0.5 * PI * numTheta + 0.5;
308
309     emap -> numPartitions = (unsigned long)numTheta * numPhi;
310     emap -> partitionCnt = 0;
311     emap -> partArea /= emap -> numPartitions;
312     }
313
314
315
316 rschregle 2.18 static int cylPhotonPartition2 (
317     EmissionMap* emap, unsigned long mp, FVECT cent, FVECT axis, double d2
318     )
319 greg 2.1 /* Recursive part of cyPhotonPartition(..) */
320     {
321     FVECT newct, newax;
322     unsigned long npl, npu;
323
324     if (mp > emap -> maxPartitions) {
325     /* Enlarge partition array */
326     emap -> maxPartitions <<= 1;
327 rschregle 2.18 emap -> partitions = (unsigned char*)realloc(
328     emap -> partitions, emap -> maxPartitions >> 1
329     );
330 greg 2.1 if (!emap -> partitions)
331     error(USER, "can't allocate source partitions");
332 greg 2.2
333 rschregle 2.18 memset(
334     emap -> partitions + (emap -> maxPartitions >> 2), 0,
335     emap -> maxPartitions >> 2
336     );
337 greg 2.1 }
338
339     if (d2 <= 1) {
340     /* hit limit? */
341     setpart(emap -> partitions, emap -> partitionCnt, S0);
342     emap -> partitionCnt++;
343     return 1;
344     }
345
346     /* subdivide */
347     setpart(emap -> partitions, emap -> partitionCnt, SU);
348     emap -> partitionCnt++;
349     newax [0] = 0.5 * axis [0];
350     newax [1] = 0.5 * axis [1];
351     newax [2] = 0.5 * axis [2];
352     d2 *= 0.25;
353
354     /* lower half */
355     newct [0] = cent [0] - newax [0];
356     newct [1] = cent [1] - newax [1];
357     newct [2] = cent [2] - newax [2];
358     npl = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
359
360     /* upper half */
361     newct [0] = cent [0] + newax [0];
362     newct [1] = cent [1] + newax [1];
363     newct [2] = cent [2] + newax [2];
364     npu = cylPhotonPartition2(emap, mp << 1, newct, newax, d2);
365
366     /* return total */
367     return npl + npu;
368     }
369
370
371
372     static void cylPhotonPartition (EmissionMap* emap)
373     /* Partition cylindrical source for photon emission */
374     {
375     double d2;
376
377 greg 2.2 memset(emap -> partitions, 0, emap -> maxPartitions >> 1);
378 greg 2.1 d2 = srcsizerat * thescene.cusize;
379     d2 = PI * emap -> src -> ss2 / (2 * emap -> src -> srad * sqr(d2));
380     d2 *= d2 * DOT(emap -> src -> ss [SU], emap -> src -> ss [SU]);
381
382     emap -> partitionCnt = 0;
383 rschregle 2.18 emap -> numPartitions = cylPhotonPartition2(
384     emap, 1, emap -> src -> sloc, emap -> src -> ss [SU], d2
385     );
386 greg 2.1 emap -> partitionCnt = 0;
387     emap -> partArea = PI * emap -> src -> ss2 / emap -> numPartitions;
388     }
389
390
391
392 rschregle 2.18 /* PHOTON ORIGIN ROUTINES ------------------------------------------------ */
393
394
395
396 greg 2.1 static void flatPhotonOrigin (EmissionMap* emap)
397     /* Init emission map with photon origin and associated surface axes on
398     flat light source surface. Also sets source aperture and sampling
399     hemisphere axes at origin */
400     {
401     int i, cent[3], size[3], parr[2];
402     FVECT vpos;
403
404     cent [0] = cent [1] = cent [2] = 0;
405     size [0] = size [1] = size [2] = emap -> maxPartitions;
406     parr [0] = 0;
407 rschregle 2.18 parr [1] = PMAP_GETPARTITION(emap);
408 greg 2.1
409     if (!skipparts(cent, size, parr, emap -> partitions))
410     error(CONSISTENCY, "bad source partition in flatPhotonOrigin");
411
412     vpos [0] = (1 - 2 * pmapRandom(partState)) * size [0] /
413     emap -> maxPartitions;
414     vpos [1] = (1 - 2 * pmapRandom(partState)) * size [1] /
415     emap -> maxPartitions;
416     vpos [2] = 0;
417
418     for (i = 0; i < 3; i++)
419     vpos [i] += (double)cent [i] / emap -> maxPartitions;
420
421     /* Get origin */
422     for (i = 0; i < 3; i++)
423 rschregle 2.18 emap -> photonOrg [i] =
424     emap -> src -> sloc [i] +
425     vpos [SU] * emap -> src -> ss [SU][i] +
426     vpos [SV] * emap -> src -> ss [SV][i] +
427     vpos [SW] * emap -> src -> ss [SW][i];
428 greg 2.1
429     /* Get surface axes */
430     VCOPY(emap -> us, emap -> src -> ss [SU]);
431     normalize(emap -> us);
432     VCOPY(emap -> ws, emap -> src -> ss [SW]);
433 rschregle 2.18 /* Flip normal emap -> ws if port and required by its orientation */
434     setPhotonPortNormal(emap);
435 greg 2.1 fcross(emap -> vs, emap -> ws, emap -> us);
436
437     /* Get hemisphere axes & aperture */
438     if (emap -> src -> sflags & SSPOT) {
439     VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
440     i = 0;
441
442     do {
443     emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
444     emap -> vh [i++] = 1;
445     fcross(emap -> uh, emap -> vh, emap -> wh);
446     } while (normalize(emap -> uh) < FTINY);
447
448     fcross(emap -> vh, emap -> wh, emap -> uh);
449     emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
450     }
451
452     else {
453     VCOPY(emap -> uh, emap -> us);
454     VCOPY(emap -> vh, emap -> vs);
455     VCOPY(emap -> wh, emap -> ws);
456     emap -> cosThetaMax = 0;
457     }
458     }
459
460
461
462     static void spherePhotonOrigin (EmissionMap* emap)
463     /* Init emission map with photon origin and associated surface axes on
464     spherical light source. Also sets source aperture and sampling
465     hemisphere axes at origin */
466     {
467     int i = 0;
468     unsigned numTheta, numPhi, t, p;
469     RREAL cosTheta, sinTheta, phi;
470
471     /* Get current partition */
472 rschregle 2.18 numTheta = max(sqrt(2 * PMAP_GETNUMPARTITIONS(emap) / PI) + 0.5, 1);
473 greg 2.1 numPhi = 0.5 * PI * numTheta + 0.5;
474
475 rschregle 2.18 t = PMAP_GETPARTITION(emap) / numPhi;
476     p = PMAP_GETPARTITION(emap) - t * numPhi;
477 greg 2.1
478     emap -> ws [2] = cosTheta = 1 - 2 * (t + pmapRandom(partState)) / numTheta;
479     sinTheta = sqrt(1 - sqr(cosTheta));
480     phi = 2 * PI * (p + pmapRandom(partState)) / numPhi;
481     emap -> ws [0] = cos(phi) * sinTheta;
482     emap -> ws [1] = sin(phi) * sinTheta;
483 rschregle 2.18 /* Flip normal emap -> ws if port and required by its orientation */
484     setPhotonPortNormal(emap);
485 greg 2.1
486     /* Get surface axes us & vs perpendicular to ws */
487     do {
488     emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
489     emap -> vs [i++] = 1;
490     fcross(emap -> us, emap -> vs, emap -> ws);
491     } while (normalize(emap -> us) < FTINY);
492
493     fcross(emap -> vs, emap -> ws, emap -> us);
494
495     /* Get origin */
496     for (i = 0; i < 3; i++)
497     emap -> photonOrg [i] = emap -> src -> sloc [i] +
498     emap -> src -> srad * emap -> ws [i];
499
500     /* Get hemisphere axes & aperture */
501     if (emap -> src -> sflags & SSPOT) {
502     VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
503     i = 0;
504
505     do {
506     emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
507     emap -> vh [i++] = 1;
508     fcross(emap -> uh, emap -> vh, emap -> wh);
509     } while (normalize(emap -> uh) < FTINY);
510
511     fcross(emap -> vh, emap -> wh, emap -> uh);
512     emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
513     }
514
515     else {
516     VCOPY(emap -> uh, emap -> us);
517     VCOPY(emap -> vh, emap -> vs);
518     VCOPY(emap -> wh, emap -> ws);
519     emap -> cosThetaMax = 0;
520     }
521     }
522
523
524
525     static void sourcePhotonOrigin (EmissionMap* emap)
526     /* Init emission map with photon origin and associated surface axes
527     on scene cube face for distant light source. Also sets source
528     aperture (solid angle) and sampling hemisphere axes at origin */
529     {
530     unsigned long i, partsPerDim, partsPerFace;
531     unsigned face;
532     RREAL du, dv;
533
534     if (emap -> port) {
535 rschregle 2.18 /* Relay to photon port; get origin on its surface */
536 greg 2.1 SRCREC *src = emap -> src;
537     emap -> src = emap -> port;
538     photonOrigin [emap -> src -> so -> otype] (emap);
539     emap -> src = src;
540     }
541
542     else {
543 rschregle 2.18 /* No ports defined, so get origin on scene cube face (SUBOPTIMAL) */
544 greg 2.1 /* Get current face from partition number */
545     partsPerDim = 1 / srcsizerat;
546     partsPerFace = sqr(partsPerDim);
547     face = emap -> partitionCnt / partsPerFace;
548     if (!(emap -> partitionCnt % partsPerFace)) {
549     /* Skipped to a new face; get its normal */
550     emap -> ws [0] = emap -> ws [1] = emap -> ws [2] = 0;
551     emap -> ws [face >> 1] = face & 1 ? 1 : -1;
552
553     /* Get surface axes us & vs perpendicular to ws */
554     face >>= 1;
555     emap -> vs [0] = emap -> vs [1] = emap -> vs [2] = 0;
556     emap -> vs [(face + (emap -> ws [face] > 0 ? 2 : 1)) % 3] = 1;
557     fcross(emap -> us, emap -> vs, emap -> ws);
558     }
559
560     /* Get jittered offsets within face from partition number
561     (in range [-0.5, 0.5]) */
562     i = emap -> partitionCnt % partsPerFace;
563     du = (i / partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
564     dv = (i % partsPerDim + pmapRandom(partState)) / partsPerDim - 0.5;
565
566     /* Jittered destination point within partition */
567     for (i = 0; i < 3; i++)
568 rschregle 2.18 emap -> photonOrg [i] = thescene.cuorg [i] + thescene.cusize * (
569     0.5 + du * emap -> us [i] + dv * emap -> vs [i] +
570     0.5 * emap -> ws [i]
571     );
572 greg 2.1 }
573
574     /* Get hemisphere axes & aperture */
575     VCOPY(emap -> wh, emap -> src -> sloc);
576     i = 0;
577
578     do {
579     emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
580     emap -> vh [i++] = 1;
581     fcross(emap -> uh, emap -> vh, emap -> wh);
582     } while (normalize(emap -> uh) < FTINY);
583
584     fcross(emap -> vh, emap -> wh, emap -> uh);
585
586     /* Get aperture */
587     emap -> cosThetaMax = 1 - emap -> src -> ss2 / (2 * PI);
588     emap -> cosThetaMax = min(1, max(-1, emap -> cosThetaMax));
589     }
590
591
592
593     static void cylPhotonOrigin (EmissionMap* emap)
594     /* Init emission map with photon origin and associated surface axes
595     on cylindrical light source surface. Also sets source aperture
596     and sampling hemisphere axes at origin */
597     {
598     int i, cent[3], size[3], parr[2];
599     FVECT v;
600
601     cent [0] = cent [1] = cent [2] = 0;
602     size [0] = size [1] = size [2] = emap -> maxPartitions;
603     parr [0] = 0;
604 rschregle 2.18 parr [1] = PMAP_GETPARTITION(emap);
605 greg 2.1
606     if (!skipparts(cent, size, parr, emap -> partitions))
607     error(CONSISTENCY, "bad source partition in cylPhotonOrigin");
608
609     v [SU] = 0;
610     v [SV] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
611     emap -> maxPartitions;
612     v [SW] = (1 - 2 * pmapRandom(partState)) * (double)size [2] /
613     emap -> maxPartitions;
614     normalize(v);
615     v [SU] = (1 - 2 * pmapRandom(partState)) * (double)size [1] /
616     emap -> maxPartitions;
617
618     for (i = 0; i < 3; i++)
619     v [i] += (double)cent [i] / emap -> maxPartitions;
620
621     /* Get surface axes */
622     for (i = 0; i < 3; i++)
623 rschregle 2.18 emap -> photonOrg [i] = emap -> ws [i] = (
624     v [SV] * emap -> src -> ss [SV][i] +
625     v [SW] * emap -> src -> ss [SW][i]
626     ) / 0.8559;
627
628     /* Flip normal emap -> ws if port and required by its orientation */
629     setPhotonPortNormal(emap);
630 greg 2.1
631     normalize(emap -> ws);
632     VCOPY(emap -> us, emap -> src -> ss [SU]);
633     normalize(emap -> us);
634     fcross(emap -> vs, emap -> ws, emap -> us);
635
636     /* Get origin */
637     for (i = 0; i < 3; i++)
638 rschregle 2.18 emap -> photonOrg [i] +=
639     v [SU] * emap -> src -> ss [SU][i] + emap -> src -> sloc [i];
640 greg 2.1
641     /* Get hemisphere axes & aperture */
642     if (emap -> src -> sflags & SSPOT) {
643     VCOPY(emap -> wh, emap -> src -> sl.s -> aim);
644     i = 0;
645
646     do {
647     emap -> vh [0] = emap -> vh [1] = emap -> vh [2] = 0;
648     emap -> vh [i++] = 1;
649     fcross(emap -> uh, emap -> vh, emap -> wh);
650     } while (normalize(emap -> uh) < FTINY);
651
652     fcross(emap -> vh, emap -> wh, emap -> uh);
653     emap -> cosThetaMax = 1 - emap -> src -> sl.s -> siz / (2 * PI);
654     }
655
656     else {
657     VCOPY(emap -> uh, emap -> us);
658     VCOPY(emap -> vh, emap -> vs);
659     VCOPY(emap -> wh, emap -> ws);
660     emap -> cosThetaMax = 0;
661     }
662     }
663
664
665
666 rschregle 2.18 /* PHOTON EMISSION ROUTINES ---------------------------------------------- */
667 greg 2.1
668
669
670     static void defaultEmissionFunc (EmissionMap* emap)
671     /* Default behaviour when no emission funcs defined for this source type */
672     {
673     objerror(emap -> src -> so, INTERNAL,
674     "undefined photon emission function");
675     }
676
677
678
679     void initPhotonEmissionFuncs ()
680     /* Init photonPartition[] and photonOrigin[] dispatch tables */
681     {
682     int i;
683
684     for (i = 0; i < NUMOTYPE; i++)
685     photonPartition [i] = photonOrigin [i] = defaultEmissionFunc;
686
687     photonPartition [OBJ_FACE] = photonPartition [OBJ_RING] = flatPhotonPartition;
688     photonPartition [OBJ_SOURCE] = sourcePhotonPartition;
689     photonPartition [OBJ_SPHERE] = spherePhotonPartition;
690     photonPartition [OBJ_CYLINDER] = cylPhotonPartition;
691     photonOrigin [OBJ_FACE] = photonOrigin [OBJ_RING] = flatPhotonOrigin;
692     photonOrigin [OBJ_SOURCE] = sourcePhotonOrigin;
693     photonOrigin [OBJ_SPHERE] = spherePhotonOrigin;
694     photonOrigin [OBJ_CYLINDER] = cylPhotonOrigin;
695     }
696
697
698
699     void initPhotonEmission (EmissionMap *emap, float numPdfSamples)
700 rschregle 2.18 /* Initialise photon emission from partitioned light source emap -> src;
701 greg 2.1 * this involves integrating the flux emitted from the current photon
702     * origin emap -> photonOrg and setting up a PDF to sample the emission
703     * distribution with numPdfSamples samples */
704     {
705     unsigned i, t, p;
706     double phi, cosTheta, sinTheta, du, dv, dOmega, thetaScale;
707     EmissionSample* sample;
708 greg 2.4 const OBJREC* mod = findmaterial(emap -> src -> so);
709 rschregle 2.18 static RAY r;
710 greg 2.4
711 greg 2.1 photonOrigin [emap -> src -> so -> otype] (emap);
712 rschregle 2.18 setcolor(emap -> partFlux, 0, 0, 0);
713 greg 2.1 emap -> cdf = 0;
714     emap -> numSamples = 0;
715 rschregle 2.18 cosTheta = DOT(emap -> ws, emap -> wh);
716 greg 2.1
717 rschregle 2.18 if (cosTheta <= 0 && sqrt(1-sqr(cosTheta)) <= emap -> cosThetaMax + FTINY)
718     /* Aperture completely below surface; no emission from current origin */
719 greg 2.1 return;
720
721 rschregle 2.18 if (
722     mod -> omod == OVOID && !emap -> port && (
723     cosTheta >= 1 - FTINY || (
724     emap -> src -> sflags & SDISTANT &&
725     acos(cosTheta) + acos(emap -> cosThetaMax) <= 0.5 * PI
726     )
727     )
728     ) {
729 greg 2.1 /* Source is unmodified and has no port (which requires testing for
730     occlusion), and is either local with normal aligned aperture or
731 rschregle 2.18 distant with aperture above surface
732     --> get flux & PDF via analytical solution */
733     setcolor(
734     emap -> partFlux, mod -> oargs.farg [0], mod -> oargs.farg [1],
735     mod -> oargs.farg [2]
736     );
737
738     /* Multiply radiance by projected Omega * dA to get flux */
739     scalecolor(
740     emap -> partFlux,
741     PI * cosTheta * (1 - sqr(max(emap -> cosThetaMax, 0))) *
742     emap -> partArea
743     );
744 greg 2.1 }
745
746     else {
747     /* Source is either modified, has a port, is local with off-normal
748 rschregle 2.18 aperture, or distant with aperture partly below surface
749     --> get flux via numerical integration */
750 greg 2.1 thetaScale = (1 - emap -> cosThetaMax);
751
752     /* Figga out numba of aperture samples for integration;
753     numTheta / numPhi ratio is 1 / PI */
754     du = sqrt(pdfSamples * 2 * thetaScale);
755     emap -> numTheta = max(du + 0.5, 1);
756     emap -> numPhi = max(PI * du + 0.5, 1);
757
758     dOmega = 2 * PI * thetaScale / (emap -> numTheta * emap -> numPhi);
759     thetaScale /= emap -> numTheta;
760
761     /* Allocate PDF, baby */
762 rschregle 2.18 sample = emap -> samples = (EmissionSample*)realloc(
763     emap -> samples,
764     sizeof(EmissionSample) * emap -> numTheta * emap -> numPhi
765     );
766 greg 2.1 if (!emap -> samples)
767 rschregle 2.20 error(USER, "can't allocate emission PDF");
768 greg 2.1
769     VCOPY(r.rorg, emap -> photonOrg);
770     VCOPY(r.rop, emap -> photonOrg);
771 greg 2.5 r.rmax = 0;
772 greg 2.1
773     for (t = 0; t < emap -> numTheta; t++) {
774     for (p = 0; p < emap -> numPhi; p++) {
775     /* This uniform mapping handles 0 <= thetaMax <= PI */
776     cosTheta = 1 - (t + pmapRandom(emitState)) * thetaScale;
777     sinTheta = sqrt(1 - sqr(cosTheta));
778     phi = 2 * PI * (p + pmapRandom(emitState)) / emap -> numPhi;
779     du = cos(phi) * sinTheta;
780     dv = sin(phi) * sinTheta;
781     rayorigin(&r, PRIMARY, NULL, NULL);
782
783     for (i = 0; i < 3; i++)
784 rschregle 2.18 r.rdir [i] = (
785     du * emap -> uh [i] + dv * emap -> vh [i] +
786     cosTheta * emap -> wh [i]
787     );
788 greg 2.1
789     /* Sample behind surface? */
790     VCOPY(r.ron, emap -> ws);
791     if ((r.rod = DOT(r.rdir, r.ron)) <= 0)
792     continue;
793
794     /* Get radiance emitted in this direction; to get flux we
795     multiply by cos(theta_surface), dOmega, and dA. Ray
796     is directed towards light source for raytexture(). */
797     if (!(emap -> src -> sflags & SDISTANT))
798     for (i = 0; i < 3; i++)
799     r.rdir [i] = -r.rdir [i];
800
801     /* Port occluded in this direction? */
802     if (emap -> port && localhit(&r, &thescene))
803     continue;
804
805     raytexture(&r, mod -> omod);
806 rschregle 2.18 setcolor(
807     r.rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
808     mod -> oargs.farg [2]
809     );
810 greg 2.1 multcolor(r.rcol, r.pcol);
811
812     /* Multiply by cos(theta_surface) */
813     scalecolor(r.rcol, r.rod);
814
815     /* Add PDF sample if nonzero; importance info for photon emission
816     * could go here... */
817     if (colorAvg(r.rcol)) {
818     copycolor(sample -> pdf, r.rcol);
819     sample -> cdf = emap -> cdf += colorAvg(sample -> pdf);
820     sample -> theta = t;
821     sample++ -> phi = p;
822     emap -> numSamples++;
823     addcolor(emap -> partFlux, r.rcol);
824     }
825     }
826     }
827
828     /* Multiply by dOmega * dA */
829     scalecolor(emap -> partFlux, dOmega * emap -> partArea);
830     }
831     }
832
833
834
835     #define vomitPhoton emitPhoton
836     #define bluarrrghPhoton vomitPhoton
837
838     void emitPhoton (const EmissionMap* emap, RAY* ray)
839     /* Emit photon from current partition emap -> partitionCnt based on
840     emission distribution. Returns new photon ray. */
841     {
842     unsigned long i, lo, hi;
843     const EmissionSample* sample = emap -> samples;
844     RREAL du, dv, cosTheta, cosThetaSqr, sinTheta, phi;
845 greg 2.4 const OBJREC* mod = findmaterial(emap -> src -> so);
846 greg 2.1
847     /* Choose a new origin within current partition for every
848     emitted photon to break up clustering artifacts */
849     photonOrigin [emap -> src -> so -> otype] ((EmissionMap*)emap);
850 greg 2.5 /* If we have a local glow source with a maximum radius, then
851 rschregle 2.14 restrict our photon to the specified distance, otherwise we set
852     the limit imposed by photonMaxDist (or no limit if 0) */
853 rschregle 2.18 if (
854     mod -> otype == MAT_GLOW &&
855     !(emap -> src -> sflags & SDISTANT) && mod -> oargs.farg[3] > FTINY
856     )
857 greg 2.5 ray -> rmax = mod -> oargs.farg[3];
858     else
859 rschregle 2.14 ray -> rmax = photonMaxDist;
860 greg 2.1 rayorigin(ray, PRIMARY, NULL, NULL);
861
862     if (!emap -> numSamples) {
863     /* Source is unmodified and has no port, and either local with
864 rschregle 2.18 normal aligned aperture, or distant with aperture above surface
865     --> use cosine weighted distribution */
866     cosThetaSqr = (1 -
867     pmapRandom(emitState) * (1 - sqr(max(emap -> cosThetaMax, 0)))
868     );
869 greg 2.1 cosTheta = sqrt(cosThetaSqr);
870     sinTheta = sqrt(1 - cosThetaSqr);
871     phi = 2 * PI * pmapRandom(emitState);
872 rschregle 2.18 setcolor(
873     ray -> rcol, mod -> oargs.farg [0], mod -> oargs.farg [1],
874     mod -> oargs.farg [2]
875     );
876 greg 2.1 }
877
878     else {
879     /* Source is either modified, has a port, is local with off-normal
880 rschregle 2.18 aperture, or distant with aperture partly below surface
881     --> choose direction from constructed cumulative distribution
882     function with Monte Carlo inversion using binary search. */
883 greg 2.1 du = pmapRandom(emitState) * emap -> cdf;
884     lo = 1;
885     hi = emap -> numSamples;
886
887     while (hi > lo) {
888     i = (lo + hi) >> 1;
889     sample = emap -> samples + i - 1;
890
891     if (sample -> cdf >= du)
892     hi = i;
893     if (sample -> cdf < du)
894     lo = i + 1;
895     }
896 rschregle 2.20
897     /* Finalise found sample */
898     i = (lo + hi) >> 1;
899     sample = emap -> samples + i - 1;
900
901 greg 2.1 /* This is a uniform mapping, mon */
902 rschregle 2.18 cosTheta = (1 -
903     (sample -> theta + pmapRandom(emitState)) *
904     (1 - emap -> cosThetaMax) / emap -> numTheta
905     );
906 greg 2.1 sinTheta = sqrt(1 - sqr(cosTheta));
907     phi = 2 * PI * (sample -> phi + pmapRandom(emitState)) / emap -> numPhi;
908     copycolor(ray -> rcol, sample -> pdf);
909     }
910
911     /* Normalize photon flux so that average over RGB is 1 */
912     colorNorm(ray -> rcol);
913
914     VCOPY(ray -> rorg, emap -> photonOrg);
915     du = cos(phi) * sinTheta;
916     dv = sin(phi) * sinTheta;
917
918     for (i = 0; i < 3; i++)
919     ray -> rdir [i] = du * emap -> uh [i] + dv * emap -> vh [i] +
920     cosTheta * emap -> wh [i];
921
922     if (emap -> src -> sflags & SDISTANT)
923     /* Distant source; reverse ray direction to point into the scene. */
924     for (i = 0; i < 3; i++)
925     ray -> rdir [i] = -ray -> rdir [i];
926
927     if (emap -> port)
928     /* Photon emitted from port; move origin just behind port so it
929     will be scattered */
930     for (i = 0; i < 3; i++)
931     ray -> rorg [i] -= 2 * FTINY * ray -> rdir [i];
932
933     /* Assign emitting light source index */
934     ray -> rsrc = emap -> src - source;
935     }
936
937
938
939 rschregle 2.18 /* SOURCE CONTRIBS FROM DIRECT / VOLUME PHOTONS -------------------------- */
940
941
942
943 greg 2.1 void multDirectPmap (RAY *r)
944     /* Factor irradiance from direct photons into r -> rcol; interface to
945     * direct() */
946     {
947     COLOR photonIrrad;
948
949     /* Lookup direct photon irradiance */
950     (directPmap -> lookup)(directPmap, r, photonIrrad);
951
952     /* Multiply with coefficient in ray */
953     multcolor(r -> rcol, photonIrrad);
954
955     return;
956     }
957
958
959
960     void inscatterVolumePmap (RAY *r, COLOR inscatter)
961     /* Add inscattering from volume photon map; interface to srcscatter() */
962     {
963     /* Add ambient in-scattering via lookup callback */
964     (volumePmap -> lookup)(volumePmap, r, inscatter);
965     }
966 rschregle 2.18
