root/Development/ray/src/rt/pmapray.h
Tue Sep 17 16:36:05 2024 UTC (13 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.7: +12 -4 lines
chore: Added extern "C" to headers to avoid C++ name mangling
Fri Mar 22 16:54:16 2024 UTC (19 months, 1 week ago) by greg
Changes since 2.6: +3 -5 lines
fix: added check for > 3 spectral samples with photon-mapping
Wed Nov 2 22:09:14 2016 UTC (9 years ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.5: +5 -2 lines
Fixed bug in ranimove introduced with photon map
Tue May 17 17:39:47 2016 UTC (9 years, 5 months ago) by rschregle
Tue Sep 1 16:27:53 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.3: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (10 years, 2 months ago) by greg
Fri May 8 13:20:23 2015 UTC (10 years, 5 months ago) by rschregle
Diff to previous 2.1
Tue Feb 24 19:39:27 2015 UTC (10 years, 8 months ago) by greg
