root/radiance/ray/src/rt/pmapray.h
Wed Nov 2 22:09:14 2016 UTC (7 years, 7 months ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.5: +5 -2 lines
Fixed bug in ranimove introduced with photon map
Tue May 17 17:39:47 2016 UTC (8 years ago) by rschregle
Tue Sep 1 16:27:53 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.3: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (8 years, 9 months ago) by greg
Fri May 8 13:20:23 2015 UTC (9 years, 1 month ago) by rschregle
Diff to previous 2.1
Tue Feb 24 19:39:27 2015 UTC (9 years, 3 months ago) by greg
