root/radiance/ray/src/rt/pmapray.c
Sat Mar 23 16:40:52 2024 UTC (16 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
fix: Needed to move test for it to work!
Fri Mar 22 16:54:16 2024 UTC (16 months, 1 week ago) by greg
Changes since 2.7: +6 -2 lines
fix: added check for > 3 spectral samples with photon-mapping
Wed Nov 2 22:09:14 2016 UTC (8 years, 9 months ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.6: +17 -2 lines
Fixed bug in ranimove introduced with photon map
Tue May 17 17:39:47 2016 UTC (9 years, 2 months ago) by rschregle
Tue Sep 1 16:27:53 2015 UTC (9 years, 11 months ago) by greg
Tue Aug 18 18:45:55 2015 UTC (9 years, 11 months ago) by greg
Fri May 22 14:09:01 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.2: +4 -6 lines
Removed redundant photon map type parameter
Fri May 8 13:20:23 2015 UTC (10 years, 2 months ago) by rschregle
Tue Feb 24 19:39:27 2015 UTC (10 years, 5 months ago) by greg
Diff to selected 2.5
