root/radiance/ray/src/rt/pmaprand.h
Mon Aug 14 21:12:10 2017 UTC (7 years, 9 months ago) by rschregle
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.7: +26 -19 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (9 years ago) by rschregle
Changes since 2.6: +16 -15 lines
Sun Mar 6 01:13:18 2016 UTC (9 years, 3 months ago) by schorsch
Tue Sep 1 16:27:53 2015 UTC (9 years, 9 months ago) by greg
Tue Aug 18 18:45:55 2015 UTC (9 years, 9 months ago) by greg
Fri May 8 13:20:23 2015 UTC (10 years, 1 month ago) by rschregle
Tue Apr 21 19:16:51 2015 UTC (10 years, 1 month ago) by greg
Changes since 2.1: +14 -5 lines
Diff to previous 2.1
Fixes for Windows and photon map
Tue Feb 24 19:39:27 2015 UTC (10 years, 3 months ago) by greg
