1 |
/* RCSid $Id: pmapparm.h,v 2.7 2016/05/17 17:39:47 rschregle Exp $ */ |
2 |
3 |
4 |
5 |
Parameters for photon map generation and rendering; used by mkpmap |
6 |
and rpict/rvu/rtrace. |
7 |
8 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com} |
9 |
(c) Fraunhofer Institute for Solar Energy Systems, |
10 |
(c) Lucerne University of Applied Sciences and Arts, |
11 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
12 |
13 |
14 |
$Id: pmapparm.h,v 2.7 2016/05/17 17:39:47 rschregle Exp $ |
15 |
16 |
17 |
18 |
#ifndef PMAPPARAMS_H |
19 |
#define PMAPPARAMS_H |
20 |
21 |
#include "pmaptype.h" |
22 |
23 |
24 |
/* Struct for passing params per photon map from rpict/rtrace/rvu */ |
25 |
typedef struct { |
26 |
char *fileName; /* Photon map file */ |
27 |
unsigned minGather, maxGather; /* Num photons to gather */ |
28 |
unsigned long distribTarget; /* Num photons to store */ |
29 |
} PhotonMapParams; |
30 |
31 |
/* Bounding box for region of interest */ |
32 |
typedef struct { |
33 |
float min [3], max [3]; |
34 |
} PhotonMapROI; |
35 |
36 |
37 |
extern PhotonMapParams pmapParams [NUM_PMAP_TYPES]; |
38 |
39 |
/* Macros for type specific photon map parameters */ |
40 |
#define globalPmapParams (pmapParams [PMAP_TYPE_GLOBAL]) |
41 |
#define preCompPmapParams (pmapParams [PMAP_TYPE_PRECOMP]) |
42 |
#define causticPmapParams (pmapParams [PMAP_TYPE_CAUSTIC]) |
43 |
#define volumePmapParams (pmapParams [PMAP_TYPE_VOLUME]) |
44 |
#define directPmapParams (pmapParams [PMAP_TYPE_DIRECT]) |
45 |
#define contribPmapParams (pmapParams [PMAP_TYPE_CONTRIB]) |
46 |
47 |
48 |
extern float pdfSamples, preDistrib, finalGather, |
49 |
gatherTolerance, maxDistFix; |
50 |
extern unsigned long photonHeapSizeInc, photonMaxBounce; |
51 |
extern unsigned photonRepTime, maxPreDistrib, defaultGather, |
52 |
verbose; |
53 |
54 |
extern unsigned pmapNumROI; |
55 |
extern PhotonMapROI *pmapROI; |
56 |
57 |
#ifdef PMAP_OOC |
58 |
extern float pmapCachePageSize; |
59 |
extern unsigned long pmapCacheSize; |
60 |
#endif |
61 |
62 |
63 |
struct PhotonMap; |
64 |
65 |
int setPmapParam (struct PhotonMap **pm, const PhotonMapParams *parm); |
66 |
/* Allocate photon map and set its parameters from parm */ |
67 |
68 |
unsigned long parseMultiplier (const char *num); |
69 |
/* Evaluate numeric parameter string with optional multiplier suffix |
70 |
(G = 10^9, M = 10^6, K = 10^3). Returns 0 if parsing fails. */ |
71 |
#endif |
