root/radiance/ray/src/rt/pmapparm.h
Revision: 2.4
Committed: Tue May 26 13:31:19 2015 UTC (10 years, 2 months ago) by rschregle
-am option to rpict/rvu/rtrace now sets fixed max photon search radius,
-overriding the adaptive max search radius
1 /*
2 ==================================================================
3 Parameters for photon map generation; used by MKPMAP
4 For inclusion in mkpmap.c
5
6 Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
7 (c) Fraunhofer Institute for Solar Energy Systems,
8 (c) Lucerne University of Applied Sciences and Arts,
9 supported by the Swiss National Science Foundation (SNSF, #147053)
10 ==================================================================
11
12 $Id: pmapparm.h,v 2.3 2015/05/26 12:32:21 rschregle Exp $
13 */
14
15
16 #ifndef PMAPPARAMS_H
17 #define PMAPPARAMS_H
18
19 #include "pmaptype.h"
20
21
22 /* Struct for passing params per photon map from rpict/rtrace/rvu */
23 typedef struct {
24 char *fileName; /* Photon map file */
25 unsigned minGather, maxGather; /* Num photons to gather */
26 unsigned long distribTarget; /* Num photons to store */
27 } PhotonMapParams;
28
29
30 extern PhotonMapParams pmapParams [NUM_PMAP_TYPES];
31
32 /* Macros for type specific photon map parameters */
33 #define globalPmapParams (pmapParams [PMAP_TYPE_GLOBAL])
34 #define preCompPmapParams (pmapParams [PMAP_TYPE_PRECOMP])
35 #define causticPmapParams (pmapParams [PMAP_TYPE_CAUSTIC])
36 #define volumePmapParams (pmapParams [PMAP_TYPE_VOLUME])
37 #define directPmapParams (pmapParams [PMAP_TYPE_DIRECT])
38 #define contribPmapParams (pmapParams [PMAP_TYPE_CONTRIB])
39
40
41 extern float pdfSamples, preDistrib, finalGather, gatherTolerance,
42 maxDistFix;
43 extern unsigned long photonHeapSizeInc, photonMaxBounce;
44 extern unsigned photonRepTime, maxPreDistrib, defaultGather;
45 #ifdef PMAP_ROI
46 extern float pmapROI [6];
47 #endif
48
49 struct PhotonMap;
50
51 int setPmapParam (struct PhotonMap **pm, const PhotonMapParams *parm);
52 /* Allocate photon map and set its parameters from parm */
53
54 unsigned long parseMultiplier (const char *num);
55 /* Evaluate numeric parameter string with optional multiplier suffix
56 (G = 10^9, M = 10^6, K = 10^3). Returns 0 if parsing fails. */
57 #endif
