root/Development/ray/src/rt/pmapparm.h
Revision: 2.10
Committed: Wed Apr 14 11:26:25 2021 UTC (4 years, 8 months ago) by rschregle
Changes since 2.9: +13 -6 lines
feat(mkpmap): Added -apI option for spherical ROI
1 /* RCSid $Id: pmapparm.h,v 2.9 2018/02/02 19:47:55 rschregle Exp $ */
2
3 /*
4 ======================================================================
5 Parameters for photon map generation and rendering; used by mkpmap
6 and rpict/rvu/rtrace.
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 supported by the German Research Foundation
11 (DFG LU-204/10-2, "Fassadenintegrierte Regelsysteme" (FARESYS))
12 (c) Lucerne University of Applied Sciences and Arts,
13 supported by the Swiss National Science Foundation
14 (SNSF #147053, "Daylight Redirecting Components")
15 ======================================================================
16
17 $Id: pmapparm.h,v 2.9 2018/02/02 19:47:55 rschregle Exp $
18 */
19
20
21 #ifndef PMAPPARAMS_H
22 #define PMAPPARAMS_H
23
24 #include "pmaptype.h"
25
26
27 /* Struct for passing params per photon map from rpict/rtrace/rvu */
28 typedef struct {
29 char *fileName; /* Photon map file */
30 unsigned minGather, maxGather; /* Num photons to gather */
31 unsigned long distribTarget; /* Num photons to store */
32 } PhotonMapParams;
33
34 /* Region of interest */
35 typedef struct {
36 /* siz [1], siz [2] <= 0 --> sphere, else rectangle */
37 float pos [3], siz [3];
38 } PhotonMapROI;
39
40 #define PMAP_ROI_ISSPHERE(roi) ((roi)->siz[1] <= 0 && (roi)->siz[2] <= 0)
41 #define PMAP_ROI_SETSPHERE(roi) ((roi)->siz[1] = (roi)->siz[2] = -1)
42
43
44 extern PhotonMapParams pmapParams [NUM_PMAP_TYPES];
45
46 /* Macros for type specific photon map parameters */
47 #define globalPmapParams (pmapParams [PMAP_TYPE_GLOBAL])
48 #define preCompPmapParams (pmapParams [PMAP_TYPE_PRECOMP])
49 #define causticPmapParams (pmapParams [PMAP_TYPE_CAUSTIC])
50 #define volumePmapParams (pmapParams [PMAP_TYPE_VOLUME])
51 #define directPmapParams (pmapParams [PMAP_TYPE_DIRECT])
52 #define contribPmapParams (pmapParams [PMAP_TYPE_CONTRIB])
53
54
55 extern float pdfSamples, preDistrib, finalGather,
56 gatherTolerance, maxDistFix, pmapMaxDist,
57 photonMaxDist;
58 extern unsigned long photonHeapSizeInc, photonMaxBounce;
59 extern unsigned photonRepTime, maxPreDistrib, defaultGather,
60 verbose;
61
62 extern unsigned pmapNumROI;
63 extern PhotonMapROI *pmapROI;
64
65 #ifdef PMAP_OOC
66 extern float pmapCachePageSize;
67 extern unsigned long pmapCacheSize;
68 #endif
69
70
71 struct PhotonMap;
72
73 int setPmapParam (struct PhotonMap **pm, const PhotonMapParams *parm);
74 /* Allocate photon map and set its parameters from parm */
75
76 unsigned long parseMultiplier (const char *num);
77 /* Evaluate numeric parameter string with optional multiplier suffix
78 (G = 10^9, M = 10^6, K = 10^3). Returns 0 if parsing fails. */
79 #endif
