root/radiance/ray/src/rt/pmapparm.h
Revision: 2.8
Committed: Mon Aug 14 21:12:10 2017 UTC (7 years, 9 months ago) by rschregle
Changes since 2.7: +12 -7 lines
Updated photon map code for Windows; no multproc or ooC for now
# User Rev Content
1 rschregle 2.8 /* RCSid $Id: pmapparm.h,v 2.7 2016/05/17 17:39:47 rschregle Exp $ */
2 rschregle 2.7
3 greg 2.1 /*
4 rschregle 2.7 ======================================================================
5     Parameters for photon map generation and rendering; used by mkpmap
6     and rpict/rvu/rtrace.
7 greg 2.1
8     Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
9     (c) Fraunhofer Institute for Solar Energy Systems,
10 rschregle 2.2 (c) Lucerne University of Applied Sciences and Arts,
11 rschregle 2.7 supported by the Swiss National Science Foundation (SNSF, #147053)
12     ======================================================================
13
14 rschregle 2.8 $Id: pmapparm.h,v 2.7 2016/05/17 17:39:47 rschregle Exp $
15 greg 2.1 */
16
17
18     #ifndef PMAPPARAMS_H
19     #define PMAPPARAMS_H
20
21     #include "pmaptype.h"
22
23
24     /* Struct for passing params per photon map from rpict/rtrace/rvu */
25     typedef struct {
26     char *fileName; /* Photon map file */
27     unsigned minGather, maxGather; /* Num photons to gather */
28     unsigned long distribTarget; /* Num photons to store */
29     } PhotonMapParams;
30 rschregle 2.8
31     /* Bounding box for region of interest */
32     typedef struct {
33     float min [3], max [3];
34     } PhotonMapROI;
35 greg 2.1
36
37     extern PhotonMapParams pmapParams [NUM_PMAP_TYPES];
38
39     /* Macros for type specific photon map parameters */
40     #define globalPmapParams (pmapParams [PMAP_TYPE_GLOBAL])
41     #define preCompPmapParams (pmapParams [PMAP_TYPE_PRECOMP])
42     #define causticPmapParams (pmapParams [PMAP_TYPE_CAUSTIC])
43     #define volumePmapParams (pmapParams [PMAP_TYPE_VOLUME])
44     #define directPmapParams (pmapParams [PMAP_TYPE_DIRECT])
45     #define contribPmapParams (pmapParams [PMAP_TYPE_CONTRIB])
46
47
48 rschregle 2.7 extern float pdfSamples, preDistrib, finalGather,
49     gatherTolerance, maxDistFix;
50     extern unsigned long photonHeapSizeInc, photonMaxBounce;
51 rschregle 2.8 extern unsigned photonRepTime, maxPreDistrib, defaultGather,
52     verbose;
53
54     extern unsigned pmapNumROI;
55     extern PhotonMapROI *pmapROI;
56 greg 2.1
57 rschregle 2.7 #ifdef PMAP_OOC
58     extern float pmapCachePageSize;
59     extern unsigned long pmapCacheSize;
60     #endif
61
62
63 greg 2.1 struct PhotonMap;
64
65     int setPmapParam (struct PhotonMap **pm, const PhotonMapParams *parm);
66     /* Allocate photon map and set its parameters from parm */
67
68     unsigned long parseMultiplier (const char *num);
69     /* Evaluate numeric parameter string with optional multiplier suffix
70     (G = 10^9, M = 10^6, K = 10^3). Returns 0 if parsing fails. */
71     #endif
