root/radiance/ray/src/rt/pmapparm.h
Tue Sep 17 16:36:05 2024 UTC (7 months, 2 weeks ago) by greg
Changes since 2.10: +11 -3 lines
chore: Added extern "C" to headers to avoid C++ name mangling
Wed Apr 14 11:26:25 2021 UTC (4 years ago) by rschregle
Changes since 2.9: +13 -6 lines
feat(mkpmap): Added -apI option for spherical ROI
Fri Feb 2 19:47:55 2018 UTC (7 years, 3 months ago) by rschregle
CVS Tags: rad5R2, rad5R3
Changes since 2.8: +4 -3 lines
Added -lr, -ld options to mkpmap, enabled -api
Mon Aug 14 21:12:10 2017 UTC (7 years, 8 months ago) by rschregle
Changes since 2.7: +12 -7 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (8 years, 11 months ago) by rschregle
Changes since 2.6: +20 -11 lines
Tue Sep 1 16:27:52 2015 UTC (9 years, 8 months ago) by greg
Changes since 2.5: +2 -3 lines
Tue Aug 18 18:45:55 2015 UTC (9 years, 8 months ago) by greg
Tue May 26 13:31:19 2015 UTC (9 years, 11 months ago) by rschregle
-am option to rpict/rvu/rtrace now sets fixed max photon search radius,
-overriding the adaptive max search radius
Tue May 26 12:32:21 2015 UTC (9 years, 11 months ago) by rschregle
Revised header of pmapparm.{h,c} to clarify its primary use with mkpmap
Fri May 8 13:20:22 2015 UTC (9 years, 11 months ago) by rschregle
Tue Feb 24 19:39:27 2015 UTC (10 years, 2 months ago) by greg
