root/radiance/ray/src/rt/pmapparm.h
Revision: 2.9
Committed: Fri Feb 2 19:47:55 2018 UTC (7 years, 4 months ago) by rschregle
CVS Tags: rad5R2, rad5R3
Changes since 2.8: +4 -3 lines
Added -lr, -ld options to mkpmap, enabled -api
1 /* RCSid $Id: pmapparm.h,v 2.8 2017/08/14 21:12:10 rschregle Exp $ */
2
3 /*
4 ======================================================================
5 Parameters for photon map generation and rendering; used by mkpmap
6 and rpict/rvu/rtrace.
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ======================================================================
13
14 $Id: pmapparm.h,v 2.8 2017/08/14 21:12:10 rschregle Exp $
15 */
16
17
18 #ifndef PMAPPARAMS_H
19 #define PMAPPARAMS_H
20
21 #include "pmaptype.h"
22
23
24 /* Struct for passing params per photon map from rpict/rtrace/rvu */
25 typedef struct {
26 char *fileName; /* Photon map file */
27 unsigned minGather, maxGather; /* Num photons to gather */
28 unsigned long distribTarget; /* Num photons to store */
29 } PhotonMapParams;
30
31 /* Bounding box for region of interest */
32 typedef struct {
33 float min [3], max [3];
34 } PhotonMapROI;
35
36
37 extern PhotonMapParams pmapParams [NUM_PMAP_TYPES];
38
39 /* Macros for type specific photon map parameters */
40 #define globalPmapParams (pmapParams [PMAP_TYPE_GLOBAL])
41 #define preCompPmapParams (pmapParams [PMAP_TYPE_PRECOMP])
42 #define causticPmapParams (pmapParams [PMAP_TYPE_CAUSTIC])
43 #define volumePmapParams (pmapParams [PMAP_TYPE_VOLUME])
44 #define directPmapParams (pmapParams [PMAP_TYPE_DIRECT])
45 #define contribPmapParams (pmapParams [PMAP_TYPE_CONTRIB])
46
47
48 extern float pdfSamples, preDistrib, finalGather,
49 gatherTolerance, maxDistFix, pmapMaxDist,
50 photonMaxDist;
51 extern unsigned long photonHeapSizeInc, photonMaxBounce;
52 extern unsigned photonRepTime, maxPreDistrib, defaultGather,
53 verbose;
54
55 extern unsigned pmapNumROI;
56 extern PhotonMapROI *pmapROI;
57
58 #ifdef PMAP_OOC
59 extern float pmapCachePageSize;
60 extern unsigned long pmapCacheSize;
61 #endif
62
63
64 struct PhotonMap;
65
66 int setPmapParam (struct PhotonMap **pm, const PhotonMapParams *parm);
67 /* Allocate photon map and set its parameters from parm */
68
69 unsigned long parseMultiplier (const char *num);
70 /* Evaluate numeric parameter string with optional multiplier suffix
71 (G = 10^9, M = 10^6, K = 10^3). Returns 0 if parsing fails. */
72 #endif
