root/radiance/ray/src/rt/pmapparm.c
Revision: 2.8
Committed: Mon Aug 14 21:12:10 2017 UTC (7 years, 8 months ago) by rschregle
Changes since 2.7: +6 -7 lines
Updated photon map code for Windows; no multproc or ooC for now
2 static const char RCSid[] = "$Id: pmapparm.c,v 2.7 2016/05/17 17:39:47 rschregle Exp $";
4
5 /*
6 ======================================================================
7 Parameters for photon map generation and rendering; used by mkpmap
8 and rpict/rvu/rtrace.
9
10 Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
11 (c) Fraunhofer Institute for Solar Energy Systems,
12 (c) Lucerne University of Applied Sciences and Arts,
13 supported by the Swiss National Science Foundation (SNSF, #147053)
14 ======================================================================
15
16 $Id: pmapparm.c,v 2.7 2016/05/17 17:39:47 rschregle Exp $
17 */
18
19
20 #include "pmapparm.h"
21 #include "pmapdata.h"
22 #include <ctype.h>
23
24
25 float pdfSamples = 1000, /* PDF samples per steradian */
26
27 finalGather = 0.25, /* fraction of global photons for
28 irradiance precomputation */
29
30 preDistrib = 0.25, /* fraction of num photons for
31 distribution prepass */
32
33 gatherTolerance = 0.5, /* Photon map lookup tolerance;
34 lookups returning fewer than this
35 fraction of minGather/maxGather
36 are restarted with a larger
37 search radius */
38
39 maxDistFix = 0; /* Static maximum photon search
40 radius (radius is adaptive if
41 this is zero) */
42
43 #ifdef PMAP_OOC
44 float pmapCachePageSize = 8; /* OOC cache pagesize as multiple
45 * of maxGather */
46 unsigned long pmapCacheSize = 1e6; /* OOC cache size in photons */
47 #endif
48
49
50 /* Regions of interest */
51 unsigned pmapNumROI = 0;
52 PhotonMapROI *pmapROI = NULL;
53
54
55 unsigned verbose = 0; /* Verbose console output */
56 unsigned long photonMaxBounce = 5000; /* Runaway photon bounce limit */
57 unsigned photonRepTime = 0, /* Seconds between reports */
58 maxPreDistrib = 4, /* Max predistrib passes */
59 defaultGather = 40; /* Default num photons for lookup */
60
61
62 /* Per photon map params */
63 PhotonMapParams pmapParams [NUM_PMAP_TYPES] = {
64 {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0},
65 {NULL, 0, 0, 0}, {NULL, 0, 0, 0}
66 };
67
68
69 int setPmapParam (PhotonMap** pm, const PhotonMapParams* parm)
70 {
71 if (parm && parm -> fileName) {
72 if (!(*pm = (PhotonMap*)malloc(sizeof(PhotonMap))))
73 error(INTERNAL, "failed to allocate photon map");
74
75 (*pm) -> fileName = parm -> fileName;
76 (*pm) -> minGather = parm -> minGather;
77 (*pm) -> maxGather = parm -> maxGather;
78 (*pm) -> distribTarget = parm -> distribTarget;
79 (*pm) -> maxDist0 = FHUGE;
80 (*pm) -> srcContrib = NULL;
81
82 return 1;
83 }
84
85 return 0;
86 }
87
88
89 unsigned long parseMultiplier (const char *num)
90 {
91 unsigned long mult = 1;
92 const int strEnd = strlen(num) - 1;
93
94 if (strEnd <= 0)
95 return 0;
96
97 if (!isdigit(num [strEnd]))
98 switch (toupper(num [strEnd])) {
99 case 'G': mult *= 1000;
100 case 'M': mult *= 1000;
101 case 'K': mult *= 1000;
102 break;
103 default : error(USER, "unknown multiplier");
104 }
105
106 return (unsigned long)(mult * atof(num));
107 }
