| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pmapparm.c,v 2.5 2015/08/18 18:45:55 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
Parameters for photon map generation; used by MKPMAP
| 7 |
For inclusion in mkpmap.c
| 8 |
| 9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
| 10 |
(c) Fraunhofer Institute for Solar Energy Systems,
| 11 |
(c) Lucerne University of Applied Sciences and Arts,
| 12 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 13 |
| 14 |
| 15 |
| 16 |
| 17 |
| 18 |
#include "pmapparm.h"
| 19 |
#include "pmapdata.h"
| 20 |
#include "standard.h"
| 21 |
#include <ctype.h>
| 22 |
| 23 |
| 24 |
float pdfSamples = 1000, /* PDF samples per steradian */
| 25 |
finalGather = 0.25, /* fraction of global photons for
| 26 |
irradiance precomputation */
| 27 |
preDistrib = 0.25, /* fraction of num photons for
| 28 |
distribution prepass */
| 29 |
gatherTolerance = 0.5, /* Photon map lookup tolerance;
| 30 |
lookups returning fewer than this
| 31 |
fraction of minGather/maxGather
| 32 |
are restarted with a larger
| 33 |
search radius */
| 34 |
maxDistFix = 0; /* Static maximum photon search
| 35 |
radius (radius is adaptive if
| 36 |
this is zero) */
| 37 |
| 38 |
#ifdef PMAP_ROI
| 39 |
/* Region of interest bbox: {xmin, xmax, ymin, ymax, zmin, zmax} */
| 40 |
float pmapROI [6] = {-FHUGE, FHUGE, -FHUGE, FHUGE, -FHUGE, FHUGE};
| 41 |
#endif
| 42 |
| 43 |
unsigned long photonHeapSizeInc = 1000, /* Photon heap size increment */
| 44 |
photonMaxBounce = 5000; /* Runaway photon bounce limit */
| 45 |
| 46 |
unsigned photonRepTime = 0, /* Seconds between reports */
| 47 |
maxPreDistrib = 4, /* Max predistrib passes */
| 48 |
defaultGather = 40; /* Default num photons for lookup */
| 49 |
| 50 |
/* Per photon map params */
| 51 |
PhotonMapParams pmapParams [NUM_PMAP_TYPES] = {
| 52 |
{NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0},
| 53 |
| 54 |
| 55 |
| 56 |
| 57 |
int setPmapParam (PhotonMap** pm, const PhotonMapParams* parm)
| 58 |
| 59 |
if (parm && parm -> fileName) {
| 60 |
if (!(*pm = (PhotonMap*)malloc(sizeof(PhotonMap))))
| 61 |
error(INTERNAL, "failed to allocate photon map");
| 62 |
| 63 |
(*pm) -> fileName = parm -> fileName;
| 64 |
(*pm) -> minGather = parm -> minGather;
| 65 |
(*pm) -> maxGather = parm -> maxGather;
| 66 |
(*pm) -> distribTarget = parm -> distribTarget;
| 67 |
(*pm) -> heapSizeInc = photonHeapSizeInc;
| 68 |
(*pm) -> maxDist0 = FHUGE;
| 69 |
(*pm) -> srcContrib = NULL;
| 70 |
| 71 |
return 1;
| 72 |
| 73 |
| 74 |
return 0;
| 75 |
| 76 |
| 77 |
| 78 |
unsigned long parseMultiplier (const char *num)
| 79 |
| 80 |
unsigned long mult = 1;
| 81 |
const int strEnd = strlen(num) - 1;
| 82 |
| 83 |
if (strEnd <= 0)
| 84 |
return 0;
| 85 |
| 86 |
if (!isdigit(num [strEnd]))
| 87 |
switch (toupper(num [strEnd])) {
| 88 |
case 'G': mult *= 1000;
| 89 |
case 'M': mult *= 1000;
| 90 |
case 'K': mult *= 1000;
| 91 |
break;
| 92 |
default : error(USER, "unknown multiplier");
| 93 |
| 94 |
| 95 |
return (unsigned long)(mult * atof(num));
| 96 |
