1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
6 |
Parameters for photon map generation; used by MKPMAP |
7 |
For inclusion in mkpmap.c |
8 |
9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com} |
10 |
(c) Fraunhofer Institute for Solar Energy Systems, |
11 |
(c) Lucerne University of Applied Sciences and Arts, |
12 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
13 |
14 |
15 |
$Id: pmapparm.c,v 2.4 2015/05/26 13:31:19 rschregle Exp $ |
16 |
17 |
18 |
19 |
#include "pmapparm.h" |
20 |
#include "pmapdata.h" |
21 |
#include "standard.h" |
22 |
#include <ctype.h> |
23 |
24 |
25 |
float pdfSamples = 1000, /* PDF samples per steradian */ |
26 |
finalGather = 0.25, /* fraction of global photons for |
27 |
irradiance precomputation */ |
28 |
preDistrib = 0.25, /* fraction of num photons for |
29 |
distribution prepass */ |
30 |
gatherTolerance = 0.5, /* Photon map lookup tolerance; |
31 |
lookups returning fewer than this |
32 |
fraction of minGather/maxGather |
33 |
are restarted with a larger |
34 |
search radius */ |
35 |
maxDistFix = 0; /* Static maximum photon search |
36 |
radius (radius is adaptive if |
37 |
this is zero) */ |
38 |
39 |
#ifdef PMAP_ROI |
40 |
/* Region of interest bbox: {xmin, xmax, ymin, ymax, zmin, zmax} */ |
41 |
float pmapROI [6] = {-FHUGE, FHUGE, -FHUGE, FHUGE, -FHUGE, FHUGE}; |
42 |
#endif |
43 |
44 |
unsigned long photonHeapSizeInc = 1000, /* Photon heap size increment */ |
45 |
photonMaxBounce = 5000; /* Runaway photon bounce limit */ |
46 |
47 |
unsigned photonRepTime = 0, /* Seconds between reports */ |
48 |
maxPreDistrib = 4, /* Max predistrib passes */ |
49 |
defaultGather = 40; /* Default num photons for lookup */ |
50 |
51 |
/* Per photon map params */ |
52 |
PhotonMapParams pmapParams [NUM_PMAP_TYPES] = { |
53 |
{NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, |
54 |
{NULL, 0, 0, 0}, {NULL, 0, 0, 0} |
55 |
56 |
57 |
58 |
int setPmapParam (PhotonMap** pm, const PhotonMapParams* parm) |
59 |
60 |
if (parm && parm -> fileName) { |
61 |
if (!(*pm = (PhotonMap*)malloc(sizeof(PhotonMap)))) |
62 |
error(INTERNAL, "failed to allocate photon map"); |
63 |
64 |
(*pm) -> fileName = parm -> fileName; |
65 |
(*pm) -> minGather = parm -> minGather; |
66 |
(*pm) -> maxGather = parm -> maxGather; |
67 |
(*pm) -> distribTarget = parm -> distribTarget; |
68 |
(*pm) -> heapSizeInc = photonHeapSizeInc; |
69 |
(*pm) -> maxDist0 = FHUGE; |
70 |
(*pm) -> srcContrib = NULL; |
71 |
72 |
return 1; |
73 |
74 |
75 |
return 0; |
76 |
77 |
78 |
79 |
unsigned long parseMultiplier (const char *num) |
80 |
81 |
unsigned long mult = 1; |
82 |
const int strEnd = strlen(num) - 1; |
83 |
84 |
if (strEnd <= 0) |
85 |
return 0; |
86 |
87 |
if (!isdigit(num [strEnd])) |
88 |
switch (toupper(num [strEnd])) { |
89 |
case 'G': mult *= 1000; |
90 |
case 'M': mult *= 1000; |
91 |
case 'K': mult *= 1000; |
92 |
break; |
93 |
default : error(USER, "unknown multiplier"); |
94 |
95 |
96 |
return (unsigned long)(mult * atof(num)); |
97 |
