| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pmapparm.c,v 2.7 2016/05/17 17:39:47 rschregle Exp $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
| 7 |
Parameters for photon map generation and rendering; used by mkpmap
| 8 |
and rpict/rvu/rtrace.
| 9 |
| 10 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
| 11 |
(c) Fraunhofer Institute for Solar Energy Systems,
| 12 |
(c) Lucerne University of Applied Sciences and Arts,
| 13 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 14 |
| 15 |
| 16 |
| 17 |
| 18 |
| 19 |
| 20 |
#include "pmapparm.h"
| 21 |
#include "pmapdata.h"
| 22 |
#include <ctype.h>
| 23 |
| 24 |
| 25 |
float pdfSamples = 1000, /* PDF samples per steradian */
| 26 |
| 27 |
finalGather = 0.25, /* fraction of global photons for
| 28 |
irradiance precomputation */
| 29 |
| 30 |
preDistrib = 0.25, /* fraction of num photons for
| 31 |
distribution prepass */
| 32 |
| 33 |
gatherTolerance = 0.5, /* Photon map lookup tolerance;
| 34 |
lookups returning fewer than this
| 35 |
fraction of minGather/maxGather
| 36 |
are restarted with a larger
| 37 |
search radius */
| 38 |
| 39 |
maxDistFix = 0; /* Static maximum photon search
| 40 |
radius (radius is adaptive if
| 41 |
this is zero) */
| 42 |
| 43 |
#ifdef PMAP_OOC
| 44 |
float pmapCachePageSize = 8; /* OOC cache pagesize as multiple
| 45 |
* of maxGather */
| 46 |
unsigned long pmapCacheSize = 1e6; /* OOC cache size in photons */
| 47 |
#endif
| 48 |
| 49 |
| 50 |
/* Regions of interest */
| 51 |
unsigned pmapNumROI = 0;
| 52 |
PhotonMapROI *pmapROI = NULL;
| 53 |
| 54 |
| 55 |
unsigned verbose = 0; /* Verbose console output */
| 56 |
unsigned long photonMaxBounce = 5000; /* Runaway photon bounce limit */
| 57 |
unsigned photonRepTime = 0, /* Seconds between reports */
| 58 |
maxPreDistrib = 4, /* Max predistrib passes */
| 59 |
defaultGather = 40; /* Default num photons for lookup */
| 60 |
| 61 |
| 62 |
/* Per photon map params */
| 63 |
PhotonMapParams pmapParams [NUM_PMAP_TYPES] = {
| 64 |
{NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0},
| 65 |
| 66 |
| 67 |
| 68 |
| 69 |
int setPmapParam (PhotonMap** pm, const PhotonMapParams* parm)
| 70 |
| 71 |
if (parm && parm -> fileName) {
| 72 |
if (!(*pm = (PhotonMap*)malloc(sizeof(PhotonMap))))
| 73 |
error(INTERNAL, "failed to allocate photon map");
| 74 |
| 75 |
(*pm) -> fileName = parm -> fileName;
| 76 |
(*pm) -> minGather = parm -> minGather;
| 77 |
(*pm) -> maxGather = parm -> maxGather;
| 78 |
(*pm) -> distribTarget = parm -> distribTarget;
| 79 |
(*pm) -> maxDist0 = FHUGE;
| 80 |
(*pm) -> srcContrib = NULL;
| 81 |
| 82 |
return 1;
| 83 |
| 84 |
| 85 |
return 0;
| 86 |
| 87 |
| 88 |
| 89 |
unsigned long parseMultiplier (const char *num)
| 90 |
| 91 |
unsigned long mult = 1;
| 92 |
const int strEnd = strlen(num) - 1;
| 93 |
| 94 |
if (strEnd <= 0)
| 95 |
return 0;
| 96 |
| 97 |
if (!isdigit(num [strEnd]))
| 98 |
switch (toupper(num [strEnd])) {
| 99 |
case 'G': mult *= 1000;
| 100 |
case 'M': mult *= 1000;
| 101 |
case 'K': mult *= 1000;
| 102 |
break;
| 103 |
default : error(USER, "unknown multiplier");
| 104 |
| 105 |
| 106 |
return (unsigned long)(mult * atof(num));
| 107 |
