root/radiance/ray/src/rt/pmapparm.c
Revision: 2.5
Committed: Tue Aug 18 18:45:55 2015 UTC (9 years, 8 months ago) by greg
5 ==================================================================
6 Parameters for photon map generation; used by MKPMAP
7 For inclusion in mkpmap.c
8
9 Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
10 (c) Fraunhofer Institute for Solar Energy Systems,
11 (c) Lucerne University of Applied Sciences and Arts,
12 supported by the Swiss National Science Foundation (SNSF, #147053)
13 ==================================================================
14
15 $Id: pmapparm.c,v 2.4 2015/05/26 13:31:19 rschregle Exp $
16 */
17
18
19 #include "pmapparm.h"
20 #include "pmapdata.h"
21 #include "standard.h"
22 #include <ctype.h>
23
24
25 float pdfSamples = 1000, /* PDF samples per steradian */
26 finalGather = 0.25, /* fraction of global photons for
27 irradiance precomputation */
28 preDistrib = 0.25, /* fraction of num photons for
29 distribution prepass */
30 gatherTolerance = 0.5, /* Photon map lookup tolerance;
31 lookups returning fewer than this
32 fraction of minGather/maxGather
33 are restarted with a larger
34 search radius */
35 maxDistFix = 0; /* Static maximum photon search
36 radius (radius is adaptive if
37 this is zero) */
38
39 #ifdef PMAP_ROI
40 /* Region of interest bbox: {xmin, xmax, ymin, ymax, zmin, zmax} */
41 float pmapROI [6] = {-FHUGE, FHUGE, -FHUGE, FHUGE, -FHUGE, FHUGE};
42 #endif
43
44 unsigned long photonHeapSizeInc = 1000, /* Photon heap size increment */
45 photonMaxBounce = 5000; /* Runaway photon bounce limit */
46
47 unsigned photonRepTime = 0, /* Seconds between reports */
48 maxPreDistrib = 4, /* Max predistrib passes */
49 defaultGather = 40; /* Default num photons for lookup */
50
51 /* Per photon map params */
52 PhotonMapParams pmapParams [NUM_PMAP_TYPES] = {
53 {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0},
54 {NULL, 0, 0, 0}, {NULL, 0, 0, 0}
55 };
56
57
58 int setPmapParam (PhotonMap** pm, const PhotonMapParams* parm)
59 {
60 if (parm && parm -> fileName) {
61 if (!(*pm = (PhotonMap*)malloc(sizeof(PhotonMap))))
62 error(INTERNAL, "failed to allocate photon map");
63
64 (*pm) -> fileName = parm -> fileName;
65 (*pm) -> minGather = parm -> minGather;
66 (*pm) -> maxGather = parm -> maxGather;
67 (*pm) -> distribTarget = parm -> distribTarget;
68 (*pm) -> heapSizeInc = photonHeapSizeInc;
69 (*pm) -> maxDist0 = FHUGE;
70 (*pm) -> srcContrib = NULL;
71
72 return 1;
73 }
74
75 return 0;
76 }
77
78
79 unsigned long parseMultiplier (const char *num)
80 {
81 unsigned long mult = 1;
82 const int strEnd = strlen(num) - 1;
83
84 if (strEnd <= 0)
85 return 0;
86
87 if (!isdigit(num [strEnd]))
88 switch (toupper(num [strEnd])) {
89 case 'G': mult *= 1000;
90 case 'M': mult *= 1000;
91 case 'K': mult *= 1000;
92 break;
93 default : error(USER, "unknown multiplier");
94 }
95
96 return (unsigned long)(mult * atof(num));
97 }
