root/Development/ray/src/rt/pmapparm.c
Revision: 2.9
Committed: Fri Feb 2 19:47:55 2018 UTC (7 years, 10 months ago) by rschregle
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, HEAD
Changes since 2.8: +6 -3 lines
Added -lr, -ld options to mkpmap, enabled -api
# User Rev Content
1 greg 2.5 #ifndef lint
2 rschregle 2.9 static const char RCSid[] = "$Id: pmapparm.c,v 2.8 2017/08/14 21:12:10 rschregle Exp $";
3 greg 2.5 #endif
4 rschregle 2.7
5 greg 2.1 /*
6 rschregle 2.7 ======================================================================
7     Parameters for photon map generation and rendering; used by mkpmap
8     and rpict/rvu/rtrace.
9 greg 2.1
10     Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
11     (c) Fraunhofer Institute for Solar Energy Systems,
12 rschregle 2.2 (c) Lucerne University of Applied Sciences and Arts,
13 rschregle 2.7 supported by the Swiss National Science Foundation (SNSF, #147053)
14     ======================================================================
15 greg 2.1
16 rschregle 2.9 $Id: pmapparm.c,v 2.8 2017/08/14 21:12:10 rschregle Exp $
17 greg 2.1 */
18
19
20     #include "pmapparm.h"
21     #include "pmapdata.h"
22     #include <ctype.h>
23
24
25 rschregle 2.7 float pdfSamples = 1000, /* PDF samples per steradian */
26
27     finalGather = 0.25, /* fraction of global photons for
28     irradiance precomputation */
29
30     preDistrib = 0.25, /* fraction of num photons for
31     distribution prepass */
32
33     gatherTolerance = 0.5, /* Photon map lookup tolerance;
34     lookups returning fewer than this
35     fraction of minGather/maxGather
36     are restarted with a larger
37     search radius */
38
39 rschregle 2.9 maxDistFix = 0, /* Static maximum photon search
40 rschregle 2.7 radius (radius is adaptive if
41     this is zero) */
42 rschregle 2.9
43     photonMaxDist = 0; /* Maximum cumulative distance of
44     photon path */
45 rschregle 2.7
46     #ifdef PMAP_OOC
47     float pmapCachePageSize = 8; /* OOC cache pagesize as multiple
48     * of maxGather */
49     unsigned long pmapCacheSize = 1e6; /* OOC cache size in photons */
50     #endif
51
52 greg 2.1
53 rschregle 2.8 /* Regions of interest */
54     unsigned pmapNumROI = 0;
55     PhotonMapROI *pmapROI = NULL;
56 greg 2.1
57 rschregle 2.7
58 rschregle 2.8 unsigned verbose = 0; /* Verbose console output */
59 rschregle 2.7 unsigned long photonMaxBounce = 5000; /* Runaway photon bounce limit */
60     unsigned photonRepTime = 0, /* Seconds between reports */
61     maxPreDistrib = 4, /* Max predistrib passes */
62     defaultGather = 40; /* Default num photons for lookup */
63
64 greg 2.1
65     /* Per photon map params */
66     PhotonMapParams pmapParams [NUM_PMAP_TYPES] = {
67     {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0},
68     {NULL, 0, 0, 0}, {NULL, 0, 0, 0}
69     };
70
71
72     int setPmapParam (PhotonMap** pm, const PhotonMapParams* parm)
73     {
74     if (parm && parm -> fileName) {
75     if (!(*pm = (PhotonMap*)malloc(sizeof(PhotonMap))))
76     error(INTERNAL, "failed to allocate photon map");
77
78     (*pm) -> fileName = parm -> fileName;
79     (*pm) -> minGather = parm -> minGather;
80     (*pm) -> maxGather = parm -> maxGather;
81     (*pm) -> distribTarget = parm -> distribTarget;
82     (*pm) -> maxDist0 = FHUGE;
83     (*pm) -> srcContrib = NULL;
84
85     return 1;
86     }
87
88     return 0;
89     }
90
91
92     unsigned long parseMultiplier (const char *num)
93     {
94     unsigned long mult = 1;
95     const int strEnd = strlen(num) - 1;
96
97     if (strEnd <= 0)
98     return 0;
99
100     if (!isdigit(num [strEnd]))
101     switch (toupper(num [strEnd])) {
102     case 'G': mult *= 1000;
103     case 'M': mult *= 1000;
104     case 'K': mult *= 1000;
105     break;
106     default : error(USER, "unknown multiplier");
107     }
108
109     return (unsigned long)(mult * atof(num));
110     }
