root/radiance/ray/src/rt/pmapparm.c
Revision: 2.4
Committed: Tue May 26 13:31:19 2015 UTC (10 years, 1 month ago) by rschregle
-am option to rpict/rvu/rtrace now sets fixed max photon search radius,
-overriding the adaptive max search radius
1 /*
2 ==================================================================
3 Parameters for photon map generation; used by MKPMAP
4 For inclusion in mkpmap.c
5
6 Roland Schregle (roland.schregle@{hslu.ch, gmail.com}
7 (c) Fraunhofer Institute for Solar Energy Systems,
8 (c) Lucerne University of Applied Sciences and Arts,
9 supported by the Swiss National Science Foundation (SNSF, #147053)
10 ==================================================================
11
12 $Id: pmapparm.c,v 2.3 2015/05/26 12:32:21 rschregle Exp $
13 */
14
15
16 #include "pmapparm.h"
17 #include "pmapdata.h"
18 #include "standard.h"
19 #include <ctype.h>
20
21
22 float pdfSamples = 1000, /* PDF samples per steradian */
23 finalGather = 0.25, /* fraction of global photons for
24 irradiance precomputation */
25 preDistrib = 0.25, /* fraction of num photons for
26 distribution prepass */
27 gatherTolerance = 0.5, /* Photon map lookup tolerance;
28 lookups returning fewer than this
29 fraction of minGather/maxGather
30 are restarted with a larger
31 search radius */
32 maxDistFix = 0; /* Static maximum photon search
33 radius (radius is adaptive if
34 this is zero) */
35
36 #ifdef PMAP_ROI
37 /* Region of interest bbox: {xmin, xmax, ymin, ymax, zmin, zmax} */
38 float pmapROI [6] = {-FHUGE, FHUGE, -FHUGE, FHUGE, -FHUGE, FHUGE};
39 #endif
40
41 unsigned long photonHeapSizeInc = 1000, /* Photon heap size increment */
42 photonMaxBounce = 5000; /* Runaway photon bounce limit */
43
44 unsigned photonRepTime = 0, /* Seconds between reports */
45 maxPreDistrib = 4, /* Max predistrib passes */
46 defaultGather = 40; /* Default num photons for lookup */
47
48 /* Per photon map params */
49 PhotonMapParams pmapParams [NUM_PMAP_TYPES] = {
50 {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0}, {NULL, 0, 0, 0},
51 {NULL, 0, 0, 0}, {NULL, 0, 0, 0}
52 };
53
54
55 int setPmapParam (PhotonMap** pm, const PhotonMapParams* parm)
56 {
57 if (parm && parm -> fileName) {
58 if (!(*pm = (PhotonMap*)malloc(sizeof(PhotonMap))))
59 error(INTERNAL, "failed to allocate photon map");
60
61 (*pm) -> fileName = parm -> fileName;
62 (*pm) -> minGather = parm -> minGather;
63 (*pm) -> maxGather = parm -> maxGather;
64 (*pm) -> distribTarget = parm -> distribTarget;
65 (*pm) -> heapSizeInc = photonHeapSizeInc;
66 (*pm) -> maxDist0 = FHUGE;
67 (*pm) -> srcContrib = NULL;
68
69 return 1;
70 }
71
72 return 0;
73 }
74
75
76 unsigned long parseMultiplier (const char *num)
77 {
78 unsigned long mult = 1;
79 const int strEnd = strlen(num) - 1;
80
81 if (strEnd <= 0)
82 return 0;
83
84 if (!isdigit(num [strEnd]))
85 switch (toupper(num [strEnd])) {
86 case 'G': mult *= 1000;
87 case 'M': mult *= 1000;
88 case 'K': mult *= 1000;
89 break;
90 default : error(USER, "unknown multiplier");
91 }
92
93 return (unsigned long)(mult * atof(num));
94 }
