root/Development/ray/src/rt/pmapparm.c
Fri Feb 2 19:47:55 2018 UTC (7 years, 11 months ago) by rschregle
Changes since 2.8: +6 -3 lines
Added -lr, -ld options to mkpmap, enabled -api
Mon Aug 14 21:12:10 2017 UTC (8 years, 4 months ago) by rschregle
Changes since 2.7: +6 -7 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (9 years, 7 months ago) by rschregle
Changes since 2.6: +40 -28 lines
Tue Sep 1 16:27:52 2015 UTC (10 years, 4 months ago) by greg
Changes since 2.5: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (10 years, 4 months ago) by greg
Tue May 26 13:31:19 2015 UTC (10 years, 7 months ago) by rschregle
-am option to rpict/rvu/rtrace now sets fixed max photon search radius,
-overriding the adaptive max search radius
Tue May 26 12:32:21 2015 UTC (10 years, 7 months ago) by rschregle
Revised header of pmapparm.{h,c} to clarify its primary use with mkpmap
Fri May 8 13:20:23 2015 UTC (10 years, 7 months ago) by rschregle
Tue Feb 24 19:39:27 2015 UTC (10 years, 10 months ago) by greg
Diff to selected 2.7
