root/radiance/ray/src/rt/pmapopt.c
Revision: 2.6
Committed: Tue Aug 18 18:45:55 2015 UTC (9 years, 9 months ago) by greg
5 ==================================================================
6 Photon map interface to RADIANCE render options
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 ==================================================================
13
14 $Id: pmapopt.c,v 2.5 2015/05/26 13:31:19 rschregle Exp $
15 */
16
17
18
19 #include "ray.h"
20 #include "pmapparm.h"
21
22
23
24 int getPmapRenderOpt (int ac, char *av [])
25 /* Parse next render option for photon map; interface to getrenderopt();
26 * return -1 if parsing failed, else number of parameters consumed */
27 {
28 #define check(ol,al) (av[0][ol] || badarg(ac-1,av+1,al))
29
30 static int t = -1; /* pmap parameter index */
31
32 if (ac < 1 || !av [0] || av [0][0] != '-')
33 return -1;
34
35 switch (av [0][1]) {
36 case 'a':
37 switch (av [0][2]) {
38 case 'p': /* photon map */
39 /* Asking for photon map, ergo ambounce != 0 */
40 ambounce += (ambounce == 0);
41 if (!check(3, "s")) {
42 /* File -> assume bwidth = 1 or precomputed pmap */
43 if (++t >= NUM_PMAP_TYPES)
44 error(USER, "too many photon maps");
45
46 pmapParams [t].fileName = savqstr(av [1]);
47 pmapParams [t].minGather = pmapParams [t].maxGather =
48 defaultGather;
49 }
50 else return -1;
51
52 if (!check(3, "si")) {
53 /* File + bandwidth */
54 pmapParams [t].minGather = pmapParams [t].maxGather =
55 atoi(av [2]);
56
57 if (!pmapParams [t].minGather)
58 return -1;
59 }
60 else {
61 sprintf(errmsg, "no photon lookup bandwidth specified, "
62 "using default %d", defaultGather);
63 error(WARNING, errmsg);
64 return 1;
65 }
66
67 if (!check(3, "sii")) {
68 /* File + min bwidth + max bwidth -> bias compensation */
69 pmapParams [t].maxGather = atoi(av [3]);
70
71 if (pmapParams [t].minGather >= pmapParams [t].maxGather)
72 return -1;
73
74 return 3;
75 }
76 else return 2;
77
78 case 'm': /* Fixed max photon search radius */
79 if (check(3, "f") || (maxDistFix = atof(av [1])) <= 0)
80 error(USER, "invalid max photon search radius coefficient");
81
82 return 1;
83 }
84 }
85 #undef check
86
87 /* Unknown option */
88 return -1;
89 }
90
91
92
93 void printPmapDefaults ()
94 /* Print defaults for photon map render options */
95 {
96 printf("-am %.1f\t\t\t\t# max photon search radius\n", maxDistFix);
97 }
