1 |
2 |
3 |
Photon map interface to RADIANCE render options |
4 |
5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
6 |
(c) Fraunhofer Institute for Solar Energy Systems, |
7 |
(c) Lucerne University of Applied Sciences and Arts, |
8 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
9 |
10 |
11 |
$Id: pmapopt.c,v 2.3 2015/05/21 15:26:35 greg Exp $ |
12 |
13 |
14 |
15 |
16 |
#include "ray.h" |
17 |
#include "pmapparm.h" |
18 |
19 |
20 |
21 |
int getPmapRenderOpt (int ac, char *av []) |
22 |
/* Parse next render option for photon map; interface to getrenderopt(); |
23 |
* return -1 if parsing failed, else number of parameters consumed */ |
24 |
25 |
#define check(ol,al) (av[0][ol] || badarg(ac-1,av+1,al)) |
26 |
27 |
static int t = -1; /* pmap parameter index */ |
28 |
29 |
if (ac < 1 || !av [0] || av [0][0] != '-') |
30 |
return -1; |
31 |
32 |
switch (av [0][1]) { |
33 |
case 'a': |
34 |
switch (av [0][2]) { |
35 |
case 'p': /* photon map */ |
36 |
/* Asking for photon map, ergo ambounce != 0 */ |
37 |
ambounce += (ambounce == 0); |
38 |
if (!check(3, "s")) { |
39 |
/* File -> assume bwidth = 1 or precomputed pmap */ |
40 |
if (++t >= NUM_PMAP_TYPES) |
41 |
error(USER, "too many photon maps"); |
42 |
43 |
pmapParams [t].fileName = savqstr(av [1]); |
44 |
pmapParams [t].minGather = pmapParams [t].maxGather = |
45 |
defaultGather; |
46 |
47 |
else return -1; |
48 |
49 |
if (!check(3, "si")) { |
50 |
/* File + bandwidth */ |
51 |
52 |
atoi(av [2]); |
53 |
54 |
if (!pmapParams [t].minGather) |
55 |
return -1; |
56 |
57 |
else { |
58 |
sprintf(errmsg, "no photon lookup bandwidth specified, " |
59 |
"using default %d", defaultGather); |
60 |
error(WARNING, errmsg); |
61 |
return 1; |
62 |
63 |
64 |
if (!check(3, "sii")) { |
65 |
/* File + min bwidth + max bwidth -> bias compensation */ |
66 |
pmapParams [t].maxGather = atoi(av [3]); |
67 |
68 |
if (pmapParams [t].minGather >= pmapParams [t].maxGather) |
69 |
return -1; |
70 |
71 |
return 3; |
72 |
73 |
else return 2; |
74 |
75 |
case 'm': /* max photon search radius coefficient */ |
76 |
if (check(3, "f") || (maxDistCoeff = atof(av [1])) <= 0) |
77 |
error(USER, "invalid max photon search radius coefficient"); |
78 |
79 |
return 1; |
80 |
81 |
82 |
#undef check |
83 |
84 |
/* Unknown option */ |
85 |
return -1; |
86 |
87 |
88 |
89 |
90 |
void printPmapDefaults () |
91 |
/* Print defaults for photon map render options */ |
92 |
93 |
printf("-am %.1f\t\t\t# max photon search radius coeff\n", maxDistCoeff); |
94 |
