root/radiance/ray/src/rt/pmapopt.c
Mon Jun 15 22:18:57 2020 UTC (5 years, 1 month ago) by rschregle
CVS Tags: HEAD, rad5R3, rad5R4, rad6R0
Changes since 2.9: +3 -3 lines
Revised error msg for -am option
Thu Jan 23 18:24:47 2020 UTC (5 years, 6 months ago) by rschregle
Changes since 2.8: +4 -4 lines
Shortened warning for default pmap bandwidth
Tue May 17 17:39:47 2016 UTC (9 years, 2 months ago) by rschregle
CVS Tags: rad5R1, rad5R2
Changes since 2.7: +28 -3 lines
Tue Sep 1 16:27:52 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.6: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (9 years, 11 months ago) by greg
Tue May 26 13:31:19 2015 UTC (10 years, 2 months ago) by rschregle
Changes since 2.4: +4 -4 lines
-am option to rpict/rvu/rtrace now sets fixed max photon search radius,
-overriding the adaptive max search radius
Fri May 22 14:12:11 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.3: +1 -2 lines
Removed extraneous default for photon map
Thu May 21 15:26:35 2015 UTC (10 years, 2 months ago) by greg
Set ambient bounces to 1 if set to 0 when photon map specified
Fri May 8 13:20:23 2015 UTC (10 years, 3 months ago) by rschregle
Tue Feb 24 19:39:27 2015 UTC (10 years, 5 months ago) by greg
Diff to selected 2.7
