root/Development/ray/src/rt/pmapopt.c
Revision: 2.8
Committed: Tue May 17 17:39:47 2016 UTC (9 years, 6 months ago) by rschregle
CVS Tags: rad5R2, rad5R1
Changes since 2.7: +28 -3 lines
# User Rev Content
1 greg 2.6 #ifndef lint
2 rschregle 2.8 static const char RCSid[] = "$Id: pmapopt.c,v 1.9 2015/10/24 20:42:20 u-no-hoo Exp $";
3 greg 2.6 #endif
4 rschregle 2.8
5 greg 2.1 /*
6     ==================================================================
7     Photon map interface to RADIANCE render options
8
9     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
10     (c) Fraunhofer Institute for Solar Energy Systems,
11 rschregle 2.2 (c) Lucerne University of Applied Sciences and Arts,
12     supported by the Swiss National Science Foundation (SNSF, #147053)
13 greg 2.1 ==================================================================
14
15 rschregle 2.8 $Id: pmapopt.c,v 1.9 2015/10/24 20:42:20 u-no-hoo Exp $
16 greg 2.1 */
17
18
19
20 greg 2.3 #include "ray.h"
21 greg 2.1 #include "pmapparm.h"
22
23
24
25     int getPmapRenderOpt (int ac, char *av [])
26     /* Parse next render option for photon map; interface to getrenderopt();
27     * return -1 if parsing failed, else number of parameters consumed */
28     {
29     #define check(ol,al) (av[0][ol] || badarg(ac-1,av+1,al))
30
31     static int t = -1; /* pmap parameter index */
32
33     if (ac < 1 || !av [0] || av [0][0] != '-')
34     return -1;
35
36     switch (av [0][1]) {
37     case 'a':
38     switch (av [0][2]) {
39     case 'p': /* photon map */
40 rschregle 2.8 /* Asking for photon map, ergo ambounce != 0 */
41     ambounce += (ambounce == 0);
42
43 greg 2.1 if (!check(3, "s")) {
44     /* File -> assume bwidth = 1 or precomputed pmap */
45     if (++t >= NUM_PMAP_TYPES)
46     error(USER, "too many photon maps");
47
48     pmapParams [t].fileName = savqstr(av [1]);
49     pmapParams [t].minGather = pmapParams [t].maxGather =
50     defaultGather;
51     }
52     else return -1;
53
54     if (!check(3, "si")) {
55     /* File + bandwidth */
56     pmapParams [t].minGather = pmapParams [t].maxGather =
57     atoi(av [2]);
58
59     if (!pmapParams [t].minGather)
60     return -1;
61     }
62     else {
63     sprintf(errmsg, "no photon lookup bandwidth specified, "
64     "using default %d", defaultGather);
65     error(WARNING, errmsg);
66     return 1;
67     }
68
69     if (!check(3, "sii")) {
70     /* File + min bwidth + max bwidth -> bias compensation */
71     pmapParams [t].maxGather = atoi(av [3]);
72
73     if (pmapParams [t].minGather >= pmapParams [t].maxGather)
74     return -1;
75
76     return 3;
77     }
78     else return 2;
79
80 rschregle 2.5 case 'm': /* Fixed max photon search radius */
81     if (check(3, "f") || (maxDistFix = atof(av [1])) <= 0)
82 greg 2.1 error(USER, "invalid max photon search radius coefficient");
83
84     return 1;
85 rschregle 2.8
86     #ifdef PMAP_OOC
87     case 'c': /* OOC pmap cache page size ratio */
88     if (check(3, "f") || (pmapCachePageSize = atof(av [1])) <= 0)
89     error(USER, "invalid photon cache page size ratio");
90
91     return 1;
92
93     case 'C': /* OOC pmap cache size (in photons); 0 = no caching */
94     if (check(3, "s"))
95     error(USER, "invalid number of cached photons");
96
97     /* Parsing failure sets to zero and disables caching */
98     pmapCacheSize = parseMultiplier(av [1]);
99
100     return 1;
101     #endif
102 greg 2.1 }
103     }
104     #undef check
105
106     /* Unknown option */
107     return -1;
108     }
109
110
111
112     void printPmapDefaults ()
113     /* Print defaults for photon map render options */
114     {
115 rschregle 2.5 printf("-am %.1f\t\t\t\t# max photon search radius\n", maxDistFix);
116 rschregle 2.8 #ifdef PMAP_OOC
117     printf("-ac %.1f\t\t\t\t# photon cache page size ratio\n",
118     pmapCachePageSize);
119     printf("-aC %ld\t\t\t# num cached photons\n", pmapCacheSize);
120     #endif
121 greg 2.1 }
