1 |
2 |
3 |
Photon map interface to out-of-core octree |
4 |
5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
6 |
(c) Lucerne University of Applied Sciences and Arts, |
7 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
8 |
9 |
10 |
$Id: pmapooc.h,v 1.2 2015/11/13 17:33:53 taschreg Exp taschreg $ |
11 |
12 |
13 |
14 |
15 |
#ifndef PMAPOOC_H |
16 |
#define PMAPOOC_H |
17 |
18 |
#include "oocnn.h" |
19 |
20 |
21 |
22 |
/* Suffixes for octree filenames */ |
23 |
/* #define PMAP_OOC_NODESUFFIX ".node" |
24 |
#define PMAP_OOC_HEAPSUFFIX ".heap" */ |
25 |
#define PMAP_OOC_LEAFSUFFIX ".leaf" |
26 |
27 |
/* Out-of-core octree constants */ |
28 |
#define PMAP_OOC_NUMBLK 32 /* Num blocks for external sort */ |
29 |
#define PMAP_OOC_BLKSIZE 1e8 /* Block size for external sort */ |
30 |
#define PMAP_OOC_LEAFMAX (OOC_OCTCNT_MAX) /* Max photons per leaf */ |
31 |
#define PMAP_OOC_MAXDEPTH (OOC_MORTON_BITS) /* Max octree depth */ |
32 |
33 |
34 |
35 |
typedef OOC_SearchQueueNode PhotonSearchQueueNode; |
36 |
typedef OOC_SearchQueue PhotonSearchQueue; |
37 |
typedef OOC_Octree PhotonStorage; |
38 |
typedef unsigned PhotonIdx; |
39 |
40 |
/* Forward declarations to break dependency loop with pmapdata.h */ |
41 |
struct PhotonMap; |
42 |
43 |
44 |
45 |
void OOC_BuildPhotonMap (struct PhotonMap *pmap, unsigned numProc); |
46 |
/* Build out-of-core octree pmap -> store from photons in unsorted |
47 |
* heapfile pmap -> heap and generate nodes and leaf file with prefix |
48 |
* pmap -> fileName. Photon map construction may be parallelised if |
49 |
* numProc > 1, if supported. The heap is destroyed on return. */ |
50 |
51 |
int OOC_SavePhotons (const struct PhotonMap *pmap, FILE *out); |
52 |
/* Save photons in out-of-core octree to file. Return -1 on error, |
53 |
* else 0 */ |
54 |
55 |
int OOC_LoadPhotons (struct PhotonMap *pmap, FILE *in); |
56 |
/* Load photons in out-of-core octree from file. Return -1 on error, |
57 |
* else 0 */ |
58 |
59 |
void OOC_InitFindPhotons (struct PhotonMap *pmap); |
60 |
/* Initialise NN search queue prior to calling kdT_FindPhotons() */ |
61 |
62 |
void OOC_FindPhotons (struct PhotonMap* pmap, const FVECT pos, |
63 |
const FVECT norm); |
64 |
/* Locate pmap -> squeue.len nearest photons to pos with similar normal |
65 |
* (NULL for volume photons) and return in search queue pmap -> squeue, |
66 |
* starting with the further photon at pmap -> squeue.node */ |
67 |
68 |
void OOC_Find1Photon (struct PhotonMap* pmap, const FVECT pos, |
69 |
const FVECT norm, Photon *photon); |
70 |
/* Locate single nearest photon to pos with similar normal */ |
71 |
72 |
int OOC_GetPhoton (struct PhotonMap *pmap, PhotonIdx idx, |
73 |
Photon *photon); |
74 |
/* Retrieve photon referenced by idx from leaf file and return 0 on |
75 |
* success, else -1. */ |
76 |
77 |
Photon *OOC_GetNearestPhoton (const PhotonSearchQueue *squeue, |
78 |
PhotonIdx idx); |
79 |
/* Retrieve photon from NN search queue after OOC_FindPhotons() */ |
80 |
81 |
PhotonIdx OOC_FirstPhoton (const struct PhotonMap* pmap); |
82 |
/* Return index to first photon in octree */ |
83 |
#endif |
