root/radiance/ray/src/rt/pmapooc.h
Revision: 1.2
Committed: Wed Apr 8 15:14:21 2020 UTC (4 years, 1 month ago) by rschregle
CVS Tags: rad5R4, rad5R3, HEAD
Changes since 1.1: +12 -10 lines
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
1 /*
2 ==================================================================
3 Photon map interface to out-of-core octree
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 ==================================================================
9
10 $Id: pmapooc.h,v 1.1 2016/05/18 08:22:45 rschregle Exp $
11 */
12
13
14
15 #ifndef PMAPOOC_H
16 #define PMAPOOC_H
17
18 #include "oocnn.h"
19
20
21
22 /* Suffixes for octree filenames */
23 /* #define PMAP_OOC_NODESUFFIX ".node"
24 #define PMAP_OOC_HEAPSUFFIX ".heap" */
25 #define PMAP_OOC_LEAFSUFFIX ".leaf"
26
27 /* Out-of-core octree constants */
28 #define PMAP_OOC_NUMBLK 32 /* Num blocks for external sort */
29 #define PMAP_OOC_BLKSIZE 1e8 /* Block size for external sort */
30 #define PMAP_OOC_LEAFMAX (OOC_OCTCNT_MAX) /* Max photons per leaf */
31 #define PMAP_OOC_MAXDEPTH (OOC_MORTON_BITS) /* Max octree depth */
32
33
34
35 typedef OOC_SearchQueueNode PhotonSearchQueueNode;
36 typedef OOC_SearchQueue PhotonSearchQueue;
37 typedef OOC_Octree PhotonStorage;
38 typedef unsigned PhotonIdx;
39
40 /* Forward declarations to break dependency loop with pmapdata.h */
41 struct PhotonMap;
42
43
44
45 void OOC_BuildPhotonMap (struct PhotonMap *pmap, unsigned numProc);
46 /* Build out-of-core octree pmap -> store from photons in unsorted
47 * heapfile pmap -> heap and generate nodes and leaf file with prefix
48 * pmap -> fileName. Photon map construction may be parallelised if
49 * numProc > 1, if supported. The heap is destroyed on return. */
50
51 int OOC_SavePhotons (const struct PhotonMap *pmap, FILE *out);
52 /* Save photons in out-of-core octree to file. Return -1 on error,
53 * else 0 */
54
55 int OOC_LoadPhotons (struct PhotonMap *pmap, FILE *in);
56 /* Load photons in out-of-core octree from file. Return -1 on error,
57 * else 0 */
58
59 void OOC_InitFindPhotons (struct PhotonMap *pmap);
60 /* Initialise NN search queue prior to calling kdT_FindPhotons() */
61
62 int OOC_FindPhotons (struct PhotonMap* pmap, const FVECT pos,
63 const FVECT norm);
64 /* Locate pmap -> squeue.len nearest photons to pos with similar normal
65 * (NULL for volume photons) and return in search queue pmap -> squeue,
66 * starting with the further photon at pmap -> squeue.node. Return -1
67 * if none found, else 0. */
68
69 int OOC_Find1Photon (struct PhotonMap* pmap, const FVECT pos,
70 const FVECT norm, Photon *photon);
71 /* Locate single nearest photon to pos with similar normal. Return -1
72 * if none found, else 0. */
73
74 int OOC_GetPhoton (struct PhotonMap *pmap, PhotonIdx idx,
75 Photon *photon);
76 /* Retrieve photon referenced by idx from leaf file and return -1 on
77 * error, else 0. */
78
79 Photon *OOC_GetNearestPhoton (const PhotonSearchQueue *squeue,
80 PhotonIdx idx);
81 /* Retrieve photon from NN search queue after OOC_FindPhotons() */
82
83 PhotonIdx OOC_FirstPhoton (const struct PhotonMap* pmap);
84 /* Return index to first photon in octree */
85 #endif
