root/radiance/ray/src/rt/pmapooc.h
Revision: 1.3
Committed: Tue Sep 17 16:36:05 2024 UTC (7 months, 2 weeks ago) by greg
Changes since 1.2: +11 -3 lines
Error occurred while calculating annotation data.
chore: Added extern "C" to headers to avoid C++ name mangling
1 /*
2 ==================================================================
3 Photon map interface to out-of-core octree
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 ==================================================================
9
10 $Id: pmapooc.h,v 1.2 2020/04/08 15:14:21 rschregle Exp $
11 */
12
13
14
15 #ifndef PMAPOOC_H
16 #define PMAPOOC_H
17
18 #include "oocnn.h"
19
20 #ifdef __cplusplus
21 extern "C" {
22 #endif
23
24
25 /* Suffixes for octree filenames */
26 /* #define PMAP_OOC_NODESUFFIX ".node"
27 #define PMAP_OOC_HEAPSUFFIX ".heap" */
28 #define PMAP_OOC_LEAFSUFFIX ".leaf"
29
30 /* Out-of-core octree constants */
31 #define PMAP_OOC_NUMBLK 32 /* Num blocks for external sort */
32 #define PMAP_OOC_BLKSIZE 1e8 /* Block size for external sort */
33 #define PMAP_OOC_LEAFMAX (OOC_OCTCNT_MAX) /* Max photons per leaf */
34 #define PMAP_OOC_MAXDEPTH (OOC_MORTON_BITS) /* Max octree depth */
35
36
37
38 typedef OOC_SearchQueueNode PhotonSearchQueueNode;
39 typedef OOC_SearchQueue PhotonSearchQueue;
40 typedef OOC_Octree PhotonStorage;
41 typedef unsigned PhotonIdx;
42
43 /* Forward declarations to break dependency loop with pmapdata.h */
44 struct PhotonMap;
45
46
47
48 void OOC_BuildPhotonMap (struct PhotonMap *pmap, unsigned numProc);
49 /* Build out-of-core octree pmap -> store from photons in unsorted
50 * heapfile pmap -> heap and generate nodes and leaf file with prefix
51 * pmap -> fileName. Photon map construction may be parallelised if
52 * numProc > 1, if supported. The heap is destroyed on return. */
53
54 int OOC_SavePhotons (const struct PhotonMap *pmap, FILE *out);
55 /* Save photons in out-of-core octree to file. Return -1 on error,
56 * else 0 */
57
58 int OOC_LoadPhotons (struct PhotonMap *pmap, FILE *in);
59 /* Load photons in out-of-core octree from file. Return -1 on error,
60 * else 0 */
61
62 void OOC_InitFindPhotons (struct PhotonMap *pmap);
63 /* Initialise NN search queue prior to calling kdT_FindPhotons() */
64
65 int OOC_FindPhotons (struct PhotonMap* pmap, const FVECT pos,
66 const FVECT norm);
67 /* Locate pmap -> squeue.len nearest photons to pos with similar normal
68 * (NULL for volume photons) and return in search queue pmap -> squeue,
69 * starting with the further photon at pmap -> squeue.node. Return -1
70 * if none found, else 0. */
71
72 int OOC_Find1Photon (struct PhotonMap* pmap, const FVECT pos,
73 const FVECT norm, Photon *photon);
74 /* Locate single nearest photon to pos with similar normal. Return -1
75 * if none found, else 0. */
76
77 int OOC_GetPhoton (struct PhotonMap *pmap, PhotonIdx idx,
78 Photon *photon);
79 /* Retrieve photon referenced by idx from leaf file and return -1 on
80 * error, else 0. */
81
82 Photon *OOC_GetNearestPhoton (const PhotonSearchQueue *squeue,
83 PhotonIdx idx);
84 /* Retrieve photon from NN search queue after OOC_FindPhotons() */
85
86 PhotonIdx OOC_FirstPhoton (const struct PhotonMap* pmap);
87 /* Return index to first photon in octree */
88
89 #ifdef __cplusplus
90 }
91 #endif
92
93 #endif
