root/radiance/ray/src/rt/pmapooc.c
Mon Mar 22 23:00:00 2021 UTC (4 years, 1 month ago) by rschregle
CVS Tags: HEAD, rad5R4
Changes since 1.6: +11 -2 lines
Diff to previous 1.6
Added optional consistency check of loaded out-of-core photon map in
OOC_LoadPhotons() when compiling for debugging mode (DEBUG_OOC).
Revision 1.6 - (view) (download) (annotate) - [selected]
Wed Apr 8 15:14:21 2020 UTC (5 years ago) by rschregle
Changes since 1.5: +24 -12 lines
Diff to previous 1.5
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
Thu Nov 8 00:54:07 2018 UTC (6 years, 5 months ago) by greg
Changes since 1.4: +2 -1 lines
Diff to previous 1.4 , to selected 1.6
Thu May 31 12:34:16 2018 UTC (6 years, 11 months ago) by rschregle
Changes since 1.3: +7 -5 lines
Diff to previous 1.3 , to selected 1.6
Fixed volume photon lookup bug (dereferenced NULL normal)
Wed Jan 24 19:39:05 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 1.2: +16 -12 lines
Diff to previous 1.2 , to selected 1.6
Hack to render contrib pmap as regular global pmap with rpict/rtrace/rvu
Mon Aug 14 21:12:10 2017 UTC (7 years, 8 months ago) by rschregle
Changes since 1.1: +5 -8 lines
Diff to previous 1.1 , to selected 1.6
Updated photon map code for Windows; no multproc or ooC for now
Wed May 18 08:22:45 2016 UTC (8 years, 11 months ago) by rschregle
Diff to selected 1.6
Added missing sources of iC and ooC pmap
