root/Development/ray/src/rt/pmapooc.c
Revision: 1.7
Committed: Mon Mar 22 23:00:00 2021 UTC (4 years, 9 months ago) by rschregle
CVS Tags: rad6R0, rad5R4, HEAD
Changes since 1.6: +11 -2 lines
Added optional consistency check of loaded out-of-core photon map in
OOC_LoadPhotons() when compiling for debugging mode (DEBUG_OOC).
# User Rev Content
1 rschregle 1.1 /*
2 rschregle 1.2 ======================================================================
3 rschregle 1.1 Photon map interface to out-of-core octree
4
5     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6     (c) Lucerne University of Applied Sciences and Arts,
7 rschregle 1.2 supported by the Swiss National Science Foundation (SNSF, #147053)
8     ======================================================================
9 rschregle 1.1
10 rschregle 1.7 $Id: pmapooc.c,v 1.6 2020/04/08 15:14:21 rschregle Exp $
11 rschregle 1.1 */
12
13
14 rschregle 1.2
15 rschregle 1.1 #include "pmapdata.h" /* Includes pmapooc.h */
16     #include "source.h"
17 greg 1.5 #include "otspecial.h"
18 rschregle 1.1 #include "oocsort.h"
19     #include "oocbuild.h"
20
21
22
23     /* Returns photon position as sorting key for OOC_Octree & friends (notably
24     * for Morton code generation).
25     * !!! Uses type conversion from float via TEMPORARY storage;
26     * !!! THIS IS NOT THREAD SAFE!
27     * !!! RETURNED KEY PERSISTS ONLY IF COPIED BEFORE NEXT CALL! */
28     RREAL *OOC_PhotonKey (const void *p)
29     {
30     static FVECT photonPos; /* Temp storage for type conversion */
31
32     VCOPY(photonPos, ((Photon*)p) -> pos);
33     return photonPos;
34     }
35
36
37
38     #ifdef DEBUG_OOC
39     static int OOC_CheckKeys (FILE *file, const OOC_Octree *oct)
40     {
41     Photon p, lastp;
42     RREAL *key;
43     OOC_MortonIdx zIdx, lastzIdx = 0;
44
45     rewind(file);
46     memset(&lastp, 0, sizeof(lastp));
47
48     while (fread(&p, sizeof(p), 1, file) > 0) {
49     key = OOC_PhotonKey(&p);
50     zIdx = OOC_KEY2MORTON(key, oct);
51
52     if (zIdx < lastzIdx) {
53     error(INTERNAL, "photons not sorted");
54     return -1;
55     }
56
57     if (zIdx == lastzIdx) {
58     sprintf(errmsg, "identical key %021ld "
59     "for [%.9f, %.9f, %.9f]\tand [%.9f, %.9f, %.9f]",
60     zIdx, lastp.pos [0], lastp.pos [1], lastp.pos [2],
61     p.pos [0], p.pos [1], p.pos [2]);
62     error(WARNING, errmsg);
63     }
64
65     lastzIdx = zIdx;
66     memcpy(&lastp, &p, sizeof(p));
67     }
68
69     return 0;
70     }
71     #endif
72
73
74
75     void OOC_BuildPhotonMap (struct PhotonMap *pmap, unsigned numProc)
76     {
77     FILE *leafFile;
78     char leafFname [1024];
79     FVECT d, octOrg;
80     int i;
81     RREAL octSize = 0;
82
83     /* Determine octree size and origin from pmap extent and init octree */
84     VCOPY(octOrg, pmap -> minPos);
85     VSUB(d, pmap -> maxPos, pmap -> minPos);
86     for (i = 0; i < 3; i++)
87     if (octSize < d [i])
88     octSize = d [i];
89
90     if (octSize < FTINY)
91     error(INTERNAL, "zero octree size in OOC_BuildPhotonMap");
92
93     /* Derive leaf filename from photon map and open file */
94     strncpy(leafFname, pmap -> fileName, sizeof(leafFname));
95     strncat(leafFname, PMAP_OOC_LEAFSUFFIX,
96     sizeof(leafFname) - strlen(leafFname) - 1);
97     if (!(leafFile = fopen(leafFname, "w+b")))
98     error(SYSTEM, "failed to open leaf file in OOC_BuildPhotonMap");
99
100     #ifdef DEBUG_OOC
101     eputs("Sorting photons by Morton code...\n");
102     #endif
103
104     /* Sort photons in heapfile by Morton code and write to leaf file */
105     if (OOC_Sort(pmap -> heap, leafFile, PMAP_OOC_NUMBLK, PMAP_OOC_BLKSIZE,
106     numProc, sizeof(Photon), octOrg, octSize, OOC_PhotonKey))
107     error(INTERNAL, "failed out-of-core photon sort in OOC_BuildPhotonMap");
108
109     /* Init and build octree */
110     OOC_Init(&pmap -> store, sizeof(Photon), octOrg, octSize, OOC_PhotonKey,
111     leafFile);
112
113     #ifdef DEBUG_OOC
114     eputs("Checking leaf file consistency...\n");
115     OOC_CheckKeys(leafFile, &pmap -> store);
116
117     eputs("Building out-of-core octree...\n");
118     #endif
119
120     if (!OOC_Build(&pmap -> store, PMAP_OOC_LEAFMAX, PMAP_OOC_MAXDEPTH))
121     error(INTERNAL, "failed out-of-core octree build in OOC_BuildPhotonMap");
122
123     #ifdef DEBUG_OOC
124     eputs("Checking out-of-core octree consistency...\n");
125     if (OOC_Check(&pmap -> store, OOC_ROOT(&pmap -> store),
126     octOrg, octSize, 0))
127     error(INTERNAL, "inconsistent out-of-core octree; Time4Harakiri");
128     #endif
129     }
130
131
132
133     int OOC_SavePhotons (const struct PhotonMap *pmap, FILE *out)
134     {
135     return OOC_SaveOctree(&pmap -> store, out);
136     }
137
138
139
140     int OOC_LoadPhotons (struct PhotonMap *pmap, FILE *nodeFile)
141     {
142     FILE *leafFile;
143     char leafFname [1024];
144
145     /* Derive leaf filename from photon map and open file */
146     strncpy(leafFname, pmap -> fileName, sizeof(leafFname));
147     strncat(leafFname, PMAP_OOC_LEAFSUFFIX,
148     sizeof(leafFname) - strlen(leafFname) - 1);
149
150     if (!(leafFile = fopen(leafFname, "r")))
151     error(SYSTEM, "failed to open leaf file in OOC_LoadPhotons");
152
153     if (OOC_LoadOctree(&pmap -> store, nodeFile, OOC_PhotonKey, leafFile))
154     return -1;
155 rschregle 1.7
156     #ifdef DEBUG_OOC
157     /* Check octree for consistency */
158     if (OOC_Check(
159     &pmap -> store, OOC_ROOT(&pmap -> store),
160     pmap -> store.org, pmap -> store.size, 0
161     ))
162     return -1;
163     #endif
164
165 rschregle 1.1 return 0;
166     }
167
168
169
170     void OOC_InitFindPhotons (struct PhotonMap *pmap)
171     {
172     if (OOC_InitNearest(&pmap -> squeue, pmap -> maxGather + 1,
173     sizeof(Photon)))
174     error(SYSTEM, "can't allocate photon search queue");
175     }
176
177
178
179     static void OOC_InitPhotonCache (struct PhotonMap *pmap)
180     /* Initialise OOC photon cache */
181     {
182     static char warn = 1;
183
184     if (!pmap -> store.cache && !pmap -> numDensity) {
185     if (pmapCacheSize > 0) {
186     const unsigned pageSize = pmapCachePageSize * pmap -> maxGather,
187     numPages = pmapCacheSize / pageSize;
188     /* Allocate & init I/O cache in octree */
189     pmap -> store.cache = malloc(sizeof(OOC_Cache));
190
191     if (!pmap -> store.cache ||
192     OOC_CacheInit(pmap -> store.cache, numPages, pageSize,
193     sizeof(Photon))) {
194     error(SYSTEM, "failed OOC photon map cache init");
195     }
196     }
197     else if (warn) {
198     error(WARNING, "OOC photon map cache DISABLED");
199     warn = 0;
200     }
201     }
202     }
203
204
205
206     typedef struct {
207     const PhotonMap *pmap;
208     const float *norm;
209     } OOC_FilterData;
210
211
212
213     int OOC_FilterPhoton (void *p, void *fd)
214     /* Filter callback for photon kNN search, used by OOC_FindNearest() */
215     {
216     const Photon *photon = p;
217     const OOC_FilterData *filtData = fd;
218     const PhotonMap *pmap = filtData -> pmap;
219
220     /* Reject photon if normal faces away (ignored for volume photons) with
221     * tolerance to account for perturbation; note photon normal is coded
222     * in range [-127,127], hence we factor this in */
223     if (filtData -> norm &&
224     DOT(filtData->norm, photon->norm) <= PMAP_NORM_TOL * 127 * frandom())
225     return 0;
226
227 rschregle 1.3 if (isContribPmap(pmap)) {
228     /* Lookup in contribution photon map; filter according to emitting
229     * light source if contrib list set, else accept all */
230
231     if (pmap -> srcContrib) {
232     OBJREC *srcMod;
233     const int srcIdx = photonSrcIdx(pmap, photon);
234 rschregle 1.1
235 rschregle 1.3 if (srcIdx < 0 || srcIdx >= nsources)
236     error(INTERNAL, "invalid light source index in photon map");
237 rschregle 1.1
238 rschregle 1.3 srcMod = findmaterial(source [srcIdx].so);
239 rschregle 1.1
240 rschregle 1.3 /* Reject photon if contributions from light source which emitted
241     * it are not sought */
242     if (!lu_find(pmap -> srcContrib, srcMod -> oname) -> data)
243     return 0;
244     }
245 rschregle 1.1
246     /* Reject non-caustic photon if lookup for caustic contribs */
247     if (pmap -> lookupCaustic && !photon -> caustic)
248     return 0;
249     }
250
251     /* Accept photon */
252     return 1;
253     }
254
255
256
257 rschregle 1.6 int OOC_FindPhotons (struct PhotonMap *pmap, const FVECT pos, const FVECT norm)
258 rschregle 1.1 {
259     OOC_SearchFilter filt;
260     OOC_FilterData filtData;
261     float n [3];
262
263     /* Lazily init OOC cache */
264     if (!pmap -> store.cache)
265     OOC_InitPhotonCache(pmap);
266
267     /* Set up filter callback */
268     filtData.pmap = pmap;
269 rschregle 1.4 if (norm)
270     VCOPY(n, norm);
271     filtData.norm = norm ? n : NULL;
272 rschregle 1.1 filt.data = &filtData;
273     filt.func = OOC_FilterPhoton;
274
275     pmap -> maxDist2 = OOC_FindNearest(&pmap -> store,
276     OOC_ROOT(&pmap -> store), 0,
277     pmap -> store.org, pmap -> store.size,
278     pos, &filt, &pmap -> squeue,
279     pmap -> maxDist2);
280
281     if (pmap -> maxDist2 < 0)
282     error(INTERNAL, "failed k-NN photon lookup in OOC_FindPhotons");
283 rschregle 1.6
284     /* Return success or failure (empty queue => none found) */
285     return pmap -> squeue.tail ? 0 : -1;
286 rschregle 1.1 }
287
288
289
290 rschregle 1.6 int OOC_Find1Photon (struct PhotonMap* pmap, const FVECT pos,
291     const FVECT norm, Photon *photon)
292 rschregle 1.1 {
293     OOC_SearchFilter filt;
294     OOC_FilterData filtData;
295 rschregle 1.6 float n [3], maxDist2;
296 rschregle 1.1
297     /* Lazily init OOC cache */
298     if (!pmap -> store.cache)
299     OOC_InitPhotonCache(pmap);
300
301     /* Set up filter callback */
302     filtData.pmap = pmap;
303 rschregle 1.4 if (norm)
304     VCOPY(n, norm);
305     filtData.norm = norm ? n : NULL;
306 rschregle 1.1 filt.data = &filtData;
307     filt.func = OOC_FilterPhoton;
308
309 rschregle 1.6 maxDist2 = OOC_Find1Nearest(&pmap -> store,
310     OOC_ROOT(&pmap -> store), 0,
311     pmap -> store.org, pmap -> store.size,
312     pos, &filt, photon, pmap -> maxDist2);
313
314     if (maxDist2 < 0)
315     error(INTERNAL, "failed 1-NN photon lookup in OOC_Find1Photon");
316
317     if (maxDist2 >= pmap -> maxDist2)
318     /* No photon found => failed */
319     return -1;
320     else {
321     /* Set photon distance => success */
322     pmap -> maxDist2 = maxDist2;
323     return 0;
324     }
325 rschregle 1.1 }
326
327
328
329     int OOC_GetPhoton (struct PhotonMap *pmap, PhotonIdx idx,
330     Photon *photon)
331     {
332     return OOC_GetData(&pmap -> store, idx, photon);
333     }
334
335
336
337     Photon *OOC_GetNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx)
338     {
339     return OOC_GetNearest(squeue, idx);
340     }
341
342
343
344     PhotonIdx OOC_FirstPhoton (const struct PhotonMap* pmap)
345     {
346     return 0;
347     }
