| 1 | /* RCSid $Id: pmapmat.h,v 2.14 2021/02/22 13:27:49 rschregle Exp $ */ |
| 2 | /* |
| 3 | ====================================================================== |
| 4 | Photon map support routines for scattering by materials. |
| 5 |  |
| 6 | Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
| 7 | (c) Fraunhofer Institute for Solar Energy Systems, |
| 8 | supported by the German Research Foundation |
| 9 | (DFG LU-204/10-2, "Fassadenintegrierte Regelsysteme FARESYS") |
| 10 | (c) Lucerne University of Applied Sciences and Arts, |
| 11 | supported by the Swiss National Science Foundation |
| 12 | (SNSF #147053, "Daylight Redirecting Components") |
| 13 | ====================================================================== |
| 14 |  |
| 15 | */ |
| 16 |  |
| 17 |  |
| 18 | #ifndef PMAPMAT_H |
| 19 | #define PMAPMAT_H |
| 20 |  |
| 21 | #include "pmap.h" |
| 22 |  |
| 23 | #ifdef __cplusplus |
| 24 | extern "C" { |
| 25 | #endif |
| 26 |  |
| 27 | /* |
| 28 | Check for paths already accounted for in photon map to avoid |
| 29 | double-counting during backward raytracing. |
| 30 |  |
| 31 | ambRayInPmap():      Check for DIFFUSE -> (DIFFUSE|SPECULAR) -> * |
| 32 | subpaths.  These occur during the backward pass |
| 33 | when an ambient ray spawns an indirect diffuse or |
| 34 | specular ray.  These subpaths are already |
| 35 | accounted for in the global photon map. |
| 36 | */ |
| 37 | #define ambRayInPmap(r) ((r) -> crtype & AMBIENT && photonMapping && \ |
| 38 | (ambounce < 0 || (r) -> rlvl > 1)) |
| 39 |  |
| 40 | /* |
| 41 | shadowRayInPmap():   Check for DIFFUSE -> SPECULAR -> LIGHT |
| 42 | subpaths. These occur during the backward pass |
| 43 | when a shadow ray is transferred through a |
| 44 | transparent material. These subpaths are already |
| 45 | accounted for by caustic photons in the global, |
| 46 | contrib, or dedicated caustic photon map. |
| 47 |  |
| 48 | !!! DISABLED FOR TESTING PENDING REPLACEMENT BY srcRayInPmap() !!! |
| 49 | */ |
| 50 | #if 1 |
| 51 | #define shadowRayInPmap(r) 0 |
| 52 | #else |
| 53 | #define shadowRayInPmap(r) (((globalPmap && ambounce < 0) || \ |
| 54 | causticPmap || contribPmap) && \ |
| 55 | (r) -> crtype & SHADOW) |
| 56 | #endif |
| 57 |  |
| 58 | /* srcRayInPmap():      Check whether a source ray transferred through |
| 59 | *                      medium (e.g.  glass/dielectric) is already |
| 60 | *                      accounted for in the photon map.  This is used by |
| 61 | *                      badcomponent() in source.c when checking source |
| 62 | *                      hits (glows and lights, hence ambient and shadow |
| 63 | *                      rays). |
| 64 | */ |
| 65 | #define srcRayInPmap(r)    (((globalPmap && ambounce < 0) || \ |
| 66 | causticPmap || contribPmap) && \ |
| 67 | (r) -> crtype & (AMBIENT | SHADOW) && \ |
| 68 | (r) -> rtype & (TRANS | REFRACTED)) |
| 69 |  |
| 70 | /* Check if scattered ray spawns a caustic photon; |
| 71 | * !!! NOTE this returns a single bit as boolean value (0|1), rather |
| 72 | * !!! than the original short int, hence the explicit test against zero. |
| 73 | * !!! This allows the macro the be used in a conditional statement |
| 74 | * !!! and when setting a photon's caustic flag in newPhoton(). */ |
| 75 | #define PMAP_CAUSTICRAY(r)    (((r) -> rtype & SPECULAR) != 0) |
| 76 |  |
| 77 |  |
| 78 | /* Scattered photon ray types for photonRay() */ |
| 79 | #define  PMAP_DIFFREFL        (REFLECTED | AMBIENT) |
| 80 | #define  PMAP_DIFFTRANS       (REFLECTED | AMBIENT | TRANS) |
| 81 | #define  PMAP_SPECREFL        (REFLECTED | SPECULAR) |
| 82 | #define  PMAP_SPECTRANS       (REFLECTED | SPECULAR | TRANS) |
| 83 | #define  PMAP_REFRACT         (REFRACTED | SPECULAR) |
| 84 | #define  PMAP_XFER            (TRANS) |
| 85 |  |
| 86 |  |
| 87 |  |
| 88 | /* Dispatch table for photon scattering functions */ |
| 89 | extern int (*photonScatter []) (OBJREC*, RAY*); |
| 90 |  |
| 91 | /* List of antimatter sensor modifier names */ |
| 92 | extern char *photonSensorList [MAXSET + 1]; |
| 93 |  |
| 94 |  |
| 95 |  |
| 96 | /* Spawn a new photon ray from a previous one; this is effectively a |
| 97 | * customised rayorigin(). */ |
| 98 | void photonRay (const RAY *rayIn, RAY *rayOut, int rayOutType, |
| 99 | COLOR fluxAtten); |
| 100 |  |
| 101 | /* Init photonScatter[] dispatch table with material specific scattering |
| 102 | routines */ |
| 103 | void initPhotonScatterFuncs (); |
| 104 |  |
| 105 | /* Find antimatter geometry declared as photon sensors */ |
| 106 | void getPhotonSensors (char **sensorList); |
| 107 |  |
| 108 | #ifdef __cplusplus |
| 109 | } |
| 110 | #endif |
| 111 |  |
| 112 | #endif |
