1 |
/* RCSid $Id: pmapmat.h,v 2.13 2019/02/04 18:20:27 rschregle Exp $ */ |
2 |
3 |
4 |
Photon map support routines for scattering by materials. |
5 |
6 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
7 |
(c) Fraunhofer Institute for Solar Energy Systems, |
8 |
supported by the German Research Foundation |
9 |
(DFG LU-204/10-2, "Fassadenintegrierte Regelsysteme FARESYS") |
10 |
(c) Lucerne University of Applied Sciences and Arts, |
11 |
supported by the Swiss National Science Foundation |
12 |
(SNSF #147053, "Daylight Redirecting Components") |
13 |
14 |
15 |
16 |
17 |
18 |
#ifndef PMAPMAT_H |
19 |
#define PMAPMAT_H |
20 |
21 |
#include "pmap.h" |
22 |
23 |
24 |
Check for paths already accounted for in photon map to avoid |
25 |
double-counting during backward raytracing. |
26 |
27 |
ambRayInPmap(): Check for DIFFUSE -> (DIFFUSE|SPECULAR) -> * |
28 |
subpaths. These occur during the backward pass |
29 |
when an ambient ray spawns an indirect diffuse or |
30 |
specular ray. These subpaths are already |
31 |
accounted for in the global photon map. |
32 |
33 |
#define ambRayInPmap(r) ((r) -> crtype & AMBIENT && photonMapping && \ |
34 |
(ambounce < 0 || (r) -> rlvl > 1)) |
35 |
36 |
37 |
shadowRayInPmap(): Check for DIFFUSE -> SPECULAR -> LIGHT |
38 |
39 |
when a shadow ray is transferred through a |
40 |
transparent material. These subpaths are already |
41 |
accounted for by caustic photons in the global, |
42 |
contrib, or dedicated caustic photon map. |
43 |
44 |
!!! DISABLED FOR TESTING PENDING REPLACEMENT BY srcRayInPmap() !!! |
45 |
46 |
#if 1 |
47 |
#define shadowRayInPmap(r) 0 |
48 |
#else |
49 |
#define shadowRayInPmap(r) (((globalPmap && ambounce < 0) || \ |
50 |
causticPmap || contribPmap) && \ |
51 |
(r) -> crtype & SHADOW) |
52 |
#endif |
53 |
54 |
/* srcRayInPmap(): Check whether a source ray transferred through |
55 |
* medium (e.g. glass/dielectric) is already |
56 |
* accounted for in the photon map. This is used by |
57 |
* badcomponent() in source.c when checking source |
58 |
* hits (glows and lights, hence ambient and shadow |
59 |
* rays). |
60 |
61 |
#define srcRayInPmap(r) (((globalPmap && ambounce < 0) || \ |
62 |
63 |
(r) -> crtype & (AMBIENT | SHADOW) && \ |
64 |
(r) -> rtype & (TRANS | REFRACTED)) |
65 |
66 |
/* Check if scattered ray spawns a caustic photon; |
67 |
* !!! NOTE this returns a single bit as boolean value (0|1), rather |
68 |
* !!! than the original short int, hence the explicit test against zero. |
69 |
* !!! This allows the macro the be used in a conditional statement |
70 |
* !!! and when setting a photon's caustic flag in newPhoton(). */ |
71 |
#define PMAP_CAUSTICRAY(r) (((r) -> rtype & SPECULAR) != 0) |
72 |
73 |
74 |
/* Scattered photon ray types for photonRay() */ |
75 |
#define PMAP_DIFFREFL (REFLECTED | AMBIENT) |
76 |
#define PMAP_DIFFTRANS (REFLECTED | AMBIENT | TRANS) |
77 |
#define PMAP_SPECREFL (REFLECTED | SPECULAR) |
78 |
#define PMAP_SPECTRANS (REFLECTED | SPECULAR | TRANS) |
79 |
#define PMAP_REFRACT (REFRACTED | SPECULAR) |
80 |
#define PMAP_XFER (TRANS) |
81 |
82 |
83 |
84 |
/* Dispatch table for photon scattering functions */ |
85 |
extern int (*photonScatter []) (OBJREC*, RAY*); |
86 |
87 |
/* List of antimatter sensor modifier names */ |
88 |
extern char *photonSensorList [MAXSET + 1]; |
89 |
90 |
91 |
92 |
/* Spawn a new photon ray from a previous one; this is effectively a |
93 |
* customised rayorigin(). */ |
94 |
void photonRay (const RAY *rayIn, RAY *rayOut, int rayOutType, |
95 |
COLOR fluxAtten); |
96 |
97 |
/* Init photonScatter[] dispatch table with material specific scattering |
98 |
routines */ |
99 |
void initPhotonScatterFuncs (); |
100 |
101 |
/* Find antimatter geometry declared as photon sensors */ |
102 |
void getPhotonSensors (char **sensorList); |
103 |
104 |
#endif |
