root/radiance/ray/src/rt/pmapmat.h
Revision: 2.12
Committed: Tue Feb 23 12:42:41 2016 UTC (9 years, 2 months ago) by rschregle
CVS Tags: rad5R2, rad5R1
Changes since 2.11: +41 -26 lines
Revised PMAP overcounting macros in pmapmat.h, added one in badcomponent()
for overcounted caustics from transferred shadow/ambient rays
1 /* RCSid $Id: pmapmat.h,v 4.18 2016/02/04 18:02:47 taschreg Exp taschreg $ */
2 /*
3 ======================================================================
4 Photon map support routines for scattering by materials.
5
6 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
7 (c) Fraunhofer Institute for Solar Energy Systems,
8 (c) Lucerne University of Applied Sciences and Arts,
9 supported by the Swiss National Science Foundation (SNSF, #147053)
10 ======================================================================
11
12 */
13
14
15 #ifndef PMAPMAT_H
16 #define PMAPMAT_H
17
18 #include "pmap.h"
19
20 /*
21 Check for paths already accounted for in photon map to avoid
22 double-counting during backward raytracing.
23
24 ambRayInPmap(): Check for DIFFUSE -> (DIFFUSE|SPECULAR) -> *
25 subpaths. These occur during the backward pass
26 when an ambient ray spawns an indirect diffuse or
27 specular ray. These subpaths are already
28 accounted for in the global photon map.
29 */
30 #define ambRayInPmap(r) ((r) -> crtype & AMBIENT && photonMapping && \
31 (ambounce < 0 || (r) -> rlvl > 1))
32
33 /*
34 shadowRayInPmap(): Check for DIFFUSE -> SPECULAR -> LIGHT
35 subpaths. These occur during the backward pass
36 when a shadow ray is transferred through a
37 transparent material. These subpaths are already
38 accounted for by caustic photons in the global,
39 contrib, or dedicated caustic photon map.
40
41 !!! DISABLED FOR TESTING PENDING REPLACEMENT BY srcRayInPmap() !!!
42 */
43 #if 1
44 #define shadowRayInPmap(r) 0
45 #else
46 #define shadowRayInPmap(r) (((globalPmap && ambounce < 0) || \
47 causticPmap || contribPmap) && \
48 (r) -> crtype & SHADOW)
49 #endif
50
51 /* srcRayInPmap(): Check whether a source ray transferred through
52 * medium (e.g. glass/dielectric) is already
53 * accounted for in the photon map. This is used by
54 * badcomponent() in source.c when checking source
55 * hits (glows and lights, hence ambient and shadow
56 * rays).
57 */
58 #define srcRayInPmap(r) (((globalPmap && ambounce < 0) || \
59 causticPmap || contribPmap) && \
60 (r) -> crtype & (AMBIENT | SHADOW) && \
61 (r) -> rtype & (TRANS | REFRACTED))
62
63 /* Check if scattered ray spawns a caustic photon;
64 * !!! NOTE this has to set bit 0 to properly handle caustic contrib
65 * !!! photons, so the explicit test against zero *IS* required! */
66 #define PMAP_CAUSTICRAY(r) (((r) -> rtype & SPECULAR) != 0)
67
68
69 /* Scattered photon ray types for photonRay() */
70 #define PMAP_DIFFREFL (REFLECTED | AMBIENT)
71 #define PMAP_DIFFTRANS (REFLECTED | AMBIENT | TRANS)
72 #define PMAP_SPECREFL (REFLECTED | SPECULAR)
73 #define PMAP_SPECTRANS (REFLECTED | SPECULAR | TRANS)
74 #define PMAP_REFRACT (REFRACTED | SPECULAR)
75 #define PMAP_XFER (TRANS)
76
77
78
79 /* Dispatch table for photon scattering functions */
80 extern int (*photonScatter []) (OBJREC*, RAY*);
81
82 /* List of antimatter sensor modifier names */
83 extern char *photonSensorList [MAXSET + 1];
84
85
86
87 /* Spawn a new photon ray from a previous one; this is effectively a
88 * customised rayorigin(). */
89 void photonRay (const RAY *rayIn, RAY *rayOut, int rayOutType,
90 COLOR fluxAtten);
91
92 /* Init photonScatter[] dispatch table with material specific scattering
93 routines */
94 void initPhotonScatterFuncs ();
95
96 /* Find antimatter geometry declared as photon sensors */
97 void getPhotonSensors (char **sensorList);
98
99 #endif
