--- ray/src/rt/pmapmat.h 2015/09/02 18:59:01 2.10 +++ ray/src/rt/pmapmat.h 2019/02/04 18:20:27 2.13 @@ -1,13 +1,13 @@ -/* RCSid $Id: pmapmat.h,v 2.10 2015/09/02 18:59:01 greg Exp $ */ +/* RCSid $Id: pmapmat.h,v 2.13 2019/02/04 18:20:27 rschregle Exp $ */ /* - ================================================================== + ====================================================================== Photon map support routines for scattering by materials. Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) (c) Fraunhofer Institute for Solar Energy Systems, (c) Lucerne University of Applied Sciences and Arts, - supported by the Swiss National Science Foundation (SNSF, #147053) - ================================================================== + supported by the Swiss National Science Foundation (SNSF, #147053) + ====================================================================== */ @@ -17,34 +17,55 @@ #include "pmap.h" - /* - ambRayInPmap(): Check for DIFFUSE -> (DIFFUSE|SPECULAR) -> * - subpaths. These occur during the backward pass - when an ambient ray spawns an indirect diffuse or - specular ray. These subpaths are already - accounted for in the global photon map. - */ - #define ambRayInPmap(r) ((r) -> crtype & AMBIENT && photonMapping && \ - (ambounce < 0 || (r) -> rlvl > 1 || \ - causticPhotonMapping || contribPhotonMapping)) - - /* + /* Check for paths already accounted for in photon map to avoid double-counting during backward raytracing. - + + ambRayInPmap(): Check for DIFFUSE -> (DIFFUSE|SPECULAR) -> * + subpaths. These occur during the backward pass + when an ambient ray spawns an indirect diffuse or + specular ray. These subpaths are already + accounted for in the global photon map. + */ + #define ambRayInPmap(r) ((r) -> crtype & AMBIENT && photonMapping && \ + (ambounce < 0 || (r) -> rlvl > 1)) + + /* shadowRayInPmap(): Check for DIFFUSE -> SPECULAR -> LIGHT subpaths. These occur during the backward pass when a shadow ray is transferred through a transparent material. These subpaths are already accounted for by caustic photons in the global, contrib, or dedicated caustic photon map. + + !!! DISABLED FOR TESTING PENDING REPLACEMENT BY srcRayInPmap() !!! */ - #define shadowRayInPmap(r) ((r) -> crtype & SHADOW && \ - (ambounce < 0 || ((r) -> crtype & AMBIENT ? \ - photonMapping : causticPhotonMapping))) - - /* Check if scattered ray spawns a caustic photon */ - #define PMAP_CAUSTICRAY(r) ((r) -> rtype & SPECULAR) +#if 1 + #define shadowRayInPmap(r) 0 +#else + #define shadowRayInPmap(r) (((globalPmap && ambounce < 0) || \ + causticPmap || contribPmap) && \ + (r) -> crtype & SHADOW) +#endif + + /* srcRayInPmap(): Check whether a source ray transferred through + * medium (e.g. glass/dielectric) is already + * accounted for in the photon map. This is used by + * badcomponent() in source.c when checking source + * hits (glows and lights, hence ambient and shadow + * rays). + */ + #define srcRayInPmap(r) (((globalPmap && ambounce < 0) || \ + causticPmap || contribPmap) && \ + (r) -> crtype & (AMBIENT | SHADOW) && \ + (r) -> rtype & (TRANS | REFRACTED)) + + /* Check if scattered ray spawns a caustic photon; + * !!! NOTE this returns a single bit as boolean value (0|1), rather + * !!! than the original short int, hence the explicit test against zero. + * !!! This allows the macro the be used in a conditional statement + * !!! and when setting a photon's caustic flag in newPhoton(). */ + #define PMAP_CAUSTICRAY(r) (((r) -> rtype & SPECULAR) != 0) /* Scattered photon ray types for photonRay() */
