root/radiance/ray/src/rt/pmapmat.h
Tue Sep 17 16:36:05 2024 UTC (10 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.14: +10 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
Mon Feb 22 13:27:49 2021 UTC (4 years, 5 months ago) by rschregle
Changes since 2.13: +5 -2 lines
style(mkpmap): revised headers and indentation/linebreaks
Mon Feb 4 18:20:27 2019 UTC (6 years, 6 months ago) by rschregle
Changes since 2.12: +6 -4 lines
Diff to previous 2.12
Clarified (hopefully) somewhat totally esoteric comment about PMAP_CAUSTICRAY()
macro.
Tue Feb 23 12:42:41 2016 UTC (9 years, 5 months ago) by rschregle
CVS Tags: rad5R1, rad5R2
Changes since 2.11: +41 -26 lines
Revised PMAP overcounting macros in pmapmat.h, added one in badcomponent()
for overcounted caustics from transferred shadow/ambient rays
Wed Oct 28 12:32:53 2015 UTC (9 years, 9 months ago) by rschregle
Changes since 2.10: +9 -5 lines
Included contrib pmap in overcounting macros
Wed Sep 2 18:59:01 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.9: +13 -9 lines
Had to reinstate ambRayInPmap() macro to avoid over-counting bug
Tue Sep 1 16:27:52 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.8: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (9 years, 11 months ago) by greg
Wed Jul 29 18:54:20 2015 UTC (10 years ago) by rschregle
Changes since 2.6: +8 -1 lines
Fixed bug with handling of -am rendering option, removed redundant code
Tue May 26 15:58:34 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.5: +3 -2 lines
More macro-management
Tue May 26 13:21:07 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.4: +2 -15 lines
Removed deprecated ambRayInPmap() macro from code
Thu May 21 15:28:24 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.3: +5 -2 lines
Moved ambient ray truncation to rayorigin() -- remove ambRayInPmap() later
Thu May 21 13:54:59 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.2: +2 -3 lines
Added calls to findmaterial() and simplified photon map shadow check
Fri May 8 13:20:22 2015 UTC (10 years, 3 months ago) by rschregle
Changes since 2.1: +8 -6 lines
Tue Feb 24 19:39:27 2015 UTC (10 years, 5 months ago) by greg
Diff to selected 2.12
