root/Development/ray/src/rt/pmapmat.c
Revision: 2.18
Committed: Tue Jun 26 14:42:18 2018 UTC (7 years, 6 months ago) by greg
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
# User Rev Content
1 greg 2.8 #ifndef lint
2 greg 2.18 static const char RCSid[] = "$Id: pmapmat.c,v 2.17 2018/06/25 20:49:10 greg Exp $";
3 greg 2.8 #endif
4 greg 2.1 /*
5     ==================================================================
6     Photon map support routines for scattering by materials.
7
8     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9     (c) Fraunhofer Institute for Solar Energy Systems,
10 rschregle 2.3 (c) Lucerne University of Applied Sciences and Arts,
11     supported by the Swiss National Science Foundation (SNSF, #147053)
12 greg 2.1 ==================================================================
13
14     */
15
16
17
18     #include "pmapmat.h"
19     #include "pmapdata.h"
20     #include "pmaprand.h"
21     #include "otypes.h"
22     #include "data.h"
23     #include "func.h"
24     #include "bsdf.h"
25     #include <math.h>
26
27
28
29     /* Stuff ripped off from material modules */
30     #define MAXITER 10
31     #define SP_REFL 01
32     #define SP_TRAN 02
33     #define SP_PURE 04
34     #define SP_FLAT 010
35     #define SP_BADU 040
36     #define MLAMBDA 500
37     #define RINDEX 1.52
38     #define FRESNE(ci) (exp(-5.85*(ci)) - 0.00287989916)
39
40
41
42     typedef struct {
43     OBJREC *mp;
44     RAY *rp;
45     short specfl;
46     COLOR mcolor, scolor;
47     FVECT vrefl, prdir, pnorm;
48     double alpha2, rdiff, rspec, trans, tdiff, tspec, pdot;
49     } NORMDAT;
50
51     typedef struct {
52     OBJREC *mp;
53     RAY *rp;
54     short specfl;
55     COLOR mcolor, scolor;
56     FVECT vrefl, prdir, u, v, pnorm;
57     double u_alpha, v_alpha, rdiff, rspec, trans, tdiff, tspec, pdot;
58     } ANISODAT;
59
60     typedef struct {
61     OBJREC *mp;
62     RAY *pr;
63     FVECT pnorm;
64     FVECT vray;
65     double sr_vpsa [2];
66     RREAL toloc [3][3];
67     RREAL fromloc [3][3];
68     double thick;
69     SDData *sd;
70     COLOR runsamp;
71     COLOR rdiff;
72     COLOR tunsamp;
73     COLOR tdiff;
74     } BSDFDAT;
75
76
77
78     extern const SDCDst SDemptyCD;
79
80     /* Per-material scattering function dispatch table; return value is usually
81     * zero, indicating photon termination */
82     int (*photonScatter [NUMOTYPE]) (OBJREC*, RAY*);
83
84     /* List of antimatter sensor modifier names and associated object set */
85     char *photonSensorList [MAXSET + 1] = {NULL};
86     static OBJECT photonSensorSet [MAXSET + 1] = {0};
87
88
89
90     /* ================ General support routines ================ */
91
92
93     void photonRay (const RAY *rayIn, RAY *rayOut,
94     int rayOutType, COLOR fluxAtten)
95     /* Spawn a new photon ray from a previous one; this is effectively a
96     * customised rayorigin().
97     * A SPECULAR rayOutType flags this photon as _caustic_ for subsequent hits.
98     * It is preserved for transferred rays (of type PMAP_XFER).
99     * fluxAtten specifies the RGB attenuation of the photon flux effected by
100     * the scattering material. The outgoing flux is then normalised to maintain
101     * a uniform average of 1 over RGB. If fluxAtten == NULL, the flux remains
102     * unchanged for the outgoing photon. fluxAtten is ignored for transferred
103     * rays.
104     * The ray direction is preserved for transferred rays, and undefined for
105     * scattered rays and must be subsequently set by the caller. */
106     {
107     rayorigin(rayOut, rayOutType, rayIn, NULL);
108
109 rschregle 2.13 if (rayIn) {
110     /* Transfer flux */
111     copycolor(rayOut -> rcol, rayIn -> rcol);
112
113     /* Copy caustic flag & direction for transferred rays */
114     if (rayOutType == PMAP_XFER) {
115     /* rayOut -> rtype |= rayIn -> rtype & SPECULAR; */
116     rayOut -> rtype |= rayIn -> rtype;
117     VCOPY(rayOut -> rdir, rayIn -> rdir);
118     }
119     else if (fluxAtten) {
120     /* Attenuate and normalise flux for scattered rays */
121     multcolor(rayOut -> rcol, fluxAtten);
122     colorNorm(rayOut -> rcol);
123     }
124
125     /* Propagate index of emitting light source */
126     rayOut -> rsrc = rayIn -> rsrc;
127 rschregle 2.14
128     /* Update maximum photon path distance */
129     rayOut -> rmax = rayIn -> rmax - rayIn -> rot;
130 greg 2.1 }
131     }
132
133
134
135     static void addPhotons (const RAY *r)
136     /* Insert photon hits, where applicable */
137     {
138     if (!r -> rlvl)
139     /* Add direct photon map at primary hitpoint */
140 rschregle 2.13 newPhoton(directPmap, r);
141 greg 2.1 else {
142     /* Add global or precomputed photon map at indirect hitpoint */
143 rschregle 2.13 newPhoton(preCompPmap ? preCompPmap : globalPmap, r);
144 greg 2.1
145     /* Store caustic photon if specular flag set */
146     if (PMAP_CAUSTICRAY(r))
147 rschregle 2.13 newPhoton(causticPmap, r);
148 greg 2.1
149     /* Store in contribution photon map */
150 rschregle 2.13 newPhoton(contribPmap, r);
151 greg 2.1 }
152     }
153
154
155
156     void getPhotonSensors (char **sensorList)
157     /* Find antimatter geometry declared as photon sensors */
158     {
159     OBJECT i;
160     OBJREC *obj;
161     char **lp;
162
163     /* Init sensor set */
164     photonSensorSet [0] = 0;
165
166     if (!sensorList [0])
167     return;
168
169     for (i = 0; i < nobjects; i++) {
170     obj = objptr(i);
171
172     /* Insert object in sensor set if it's in the specified sensor list
173     * and of type antimatter */
174     for (lp = sensorList; *lp; lp++) {
175     if (!strcmp(obj -> oname, *lp)) {
176     if (obj -> otype != MAT_CLIP) {
177     sprintf(errmsg, "photon sensor modifier %s is not antimatter",
178     obj -> oname);
179     error(USER, errmsg);
180     }
181
182     if (photonSensorSet [0] >= AMBLLEN)
183     error(USER, "too many photon sensor modifiers");
184
185     insertelem(photonSensorSet, i);
186     }
187     }
188     }
189
190     if (!photonSensorSet [0])
191     error(USER, "no photon sensors found");
192     }
193
194
195
196     /* ================ Material specific scattering routines ================ */
197
198
199     static int isoSpecPhotonScatter (NORMDAT *nd, RAY *rayOut)
200     /* Generate direction for isotropically specularly reflected
201     or transmitted ray. Returns 1 if successful. */
202     {
203     FVECT u, v, h;
204     RAY *rayIn = nd -> rp;
205     double d, d2, sinp, cosp;
206     int niter, i = 0;
207
208     /* Set up sample coordinates */
209 greg 2.5 getperpendicular(u, nd -> pnorm, 1);
210 greg 2.1 fcross(v, nd -> pnorm, u);
211
212     if (nd -> specfl & SP_REFL) {
213     /* Specular reflection; make MAXITER attempts at getting a ray */
214
215     for (niter = 0; niter < MAXITER; niter++) {
216     d = 2 * PI * pmapRandom(scatterState);
217     cosp = cos(d);
218     sinp = sin(d);
219     d2 = pmapRandom(scatterState);
220     d = d2 <= FTINY ? 1 : sqrt(nd -> alpha2 * -log(d2));
221
222     for (i = 0; i < 3; i++)
223     h [i] = nd -> pnorm [i] + d * (cosp * u [i] + sinp * v [i]);
224
225     d = -2 * DOT(h, rayIn -> rdir) / (1 + d * d);
226     VSUM(rayOut -> rdir, rayIn -> rdir, h, d);
227
228     if (DOT(rayOut -> rdir, rayIn -> ron) > FTINY)
229     return 1;
230     }
231
232     return 0;
233     }
234
235     else {
236     /* Specular transmission; make MAXITER attempts at getting a ray */
237
238     for (niter = 0; niter < MAXITER; niter++) {
239     d = 2 * PI * pmapRandom(scatterState);
240     cosp = cos(d);
241     sinp = sin(d);
242     d2 = pmapRandom(scatterState);
243     d = d2 <= FTINY ? 1 : sqrt(-log(d2) * nd -> alpha2);
244
245     for (i = 0; i < 3; i++)
246     rayOut -> rdir [i] = nd -> prdir [i] +
247     d * (cosp * u [i] + sinp * v [i]);
248
249     if (DOT(rayOut -> rdir, rayIn -> ron) < -FTINY) {
250     normalize(rayOut -> rdir);
251     return 1;
252     }
253     }
254
255     return 0;
256     }
257     }
258
259
260
261     static void diffPhotonScatter (FVECT normal, RAY* rayOut)
262     /* Generate cosine-weighted direction for diffuse ray */
263     {
264     const RREAL cosThetaSqr = pmapRandom(scatterState),
265     cosTheta = sqrt(cosThetaSqr),
266     sinTheta = sqrt(1 - cosThetaSqr),
267     phi = 2 * PI * pmapRandom(scatterState),
268     du = cos(phi) * sinTheta, dv = sin(phi) * sinTheta;
269     FVECT u, v;
270     int i = 0;
271
272     /* Set up sample coordinates */
273 greg 2.5 getperpendicular(u, normal, 1);
274 greg 2.1 fcross(v, normal, u);
275
276     /* Convert theta & phi to cartesian */
277     for (i = 0; i < 3; i++)
278     rayOut -> rdir [i] = du * u [i] + dv * v [i] + cosTheta * normal [i];
279
280     normalize(rayOut -> rdir);
281     }
282
283
284
285     static int normalPhotonScatter (OBJREC *mat, RAY *rayIn)
286     /* Generate new photon ray for isotropic material and recurse */
287     {
288     NORMDAT nd;
289     int i, hastexture;
290     float xi, albedo, prdiff, ptdiff, prspec, ptspec;
291     double d, fresnel;
292     RAY rayOut;
293
294     if (mat -> oargs.nfargs != (mat -> otype == MAT_TRANS ? 7 : 5))
295     objerror(mat, USER, "bad number of arguments");
296
297     /* Check for back side; reorient if back is visible */
298     if (rayIn -> rod < 0)
299     if (!backvis && mat -> otype != MAT_TRANS)
300     return 0;
301     else {
302     /* Get modifiers */
303     raytexture(rayIn, mat -> omod);
304     flipsurface(rayIn);
305     }
306     else raytexture(rayIn, mat -> omod);
307
308     nd.rp = rayIn;
309
310     /* Get material color */
311     copycolor(nd.mcolor, mat -> oargs.farg);
312
313     /* Get roughness */
314     nd.specfl = 0;
315     nd.alpha2 = mat -> oargs.farg [4];
316
317     if ((nd.alpha2 *= nd.alpha2) <= FTINY)
318     nd.specfl |= SP_PURE;
319
320     if (rayIn -> ro != NULL && isflat(rayIn -> ro -> otype))
321     nd.specfl |= SP_FLAT;
322
323     /* Perturb normal */
324 greg 2.4 if ((hastexture = (DOT(rayIn -> pert, rayIn -> pert) > sqr(FTINY)) ))
325 greg 2.1 nd.pdot = raynormal(nd.pnorm, rayIn);
326     else {
327     VCOPY(nd.pnorm, rayIn -> ron);
328     nd.pdot = rayIn -> rod;
329     }
330
331     nd.pdot = max(nd.pdot, .001);
332
333     /* Modify material color */
334     multcolor(nd.mcolor, rayIn -> pcol);
335     nd.rspec = mat -> oargs.farg [3];
336
337     /* Approximate Fresnel term */
338     if (nd.specfl & SP_PURE && nd.rspec > FTINY) {
339     fresnel = FRESNE(rayIn -> rod);
340     nd.rspec += fresnel * (1 - nd.rspec);
341     }
342     else fresnel = 0;
343
344     /* Transmission params */
345     if (mat -> otype == MAT_TRANS) {
346     nd.trans = mat -> oargs.farg [5] * (1 - nd.rspec);
347     nd.tspec = nd.trans * mat -> oargs.farg [6];
348     nd.tdiff = nd.trans - nd.tspec;
349     }
350     else nd.tdiff = nd.tspec = nd.trans = 0;
351
352     /* Specular reflection params */
353     if (nd.rspec > FTINY) {
354     /* Specular color */
355     if (mat -> otype != MAT_METAL)
356     setcolor(nd.scolor, nd.rspec, nd.rspec, nd.rspec);
357     else if (fresnel > FTINY) {
358     d = nd.rspec * (1 - fresnel);
359     for (i = 0; i < 3; i++)
360     nd.scolor [i] = fresnel + nd.mcolor [i] * d;
361     }
362     else {
363     copycolor(nd.scolor, nd.mcolor);
364     scalecolor(nd.scolor, nd.rspec);
365     }
366     }
367     else setcolor(nd.scolor, 0, 0, 0);
368
369     /* Diffuse reflection params */
370     nd.rdiff = 1 - nd.trans - nd.rspec;
371
372     /* Set up probabilities */
373     prdiff = ptdiff = ptspec = colorAvg(nd.mcolor);
374     prdiff *= nd.rdiff;
375     ptdiff *= nd.tdiff;
376     prspec = colorAvg(nd.scolor);
377     ptspec *= nd.tspec;
378     albedo = prdiff + ptdiff + prspec + ptspec;
379
380     /* Insert direct and indirect photon hits if diffuse component */
381     if (prdiff > FTINY || ptdiff > FTINY)
382     addPhotons(rayIn);
383
384     xi = pmapRandom(rouletteState);
385
386     if (xi > albedo)
387     /* Absorbed */
388     return 0;
389
390     if (xi > (albedo -= prspec)) {
391     /* Specular reflection */
392     nd.specfl |= SP_REFL;
393
394     if (nd.specfl & SP_PURE) {
395     /* Perfect specular reflection */
396     for (i = 0; i < 3; i++) {
397     /* Reflected ray */
398     nd.vrefl [i] = rayIn -> rdir [i] + 2 * nd.pdot * nd.pnorm [i];
399     }
400
401     /* Penetration? */
402     if (hastexture && DOT(nd.vrefl, rayIn -> ron) <= FTINY)
403     for (i = 0; i < 3; i++) {
404     /* Safety measure */
405     nd.vrefl [i] = rayIn -> rdir [i] +
406     2 * rayIn -> rod * rayIn -> ron [i];
407     }
408
409     VCOPY(rayOut.rdir, nd.vrefl);
410     }
411
412     else if (!isoSpecPhotonScatter(&nd, &rayOut))
413     return 0;
414
415     photonRay(rayIn, &rayOut, PMAP_SPECREFL, nd.scolor);
416     }
417
418     else if (xi > (albedo -= ptspec)) {
419     /* Specular transmission */
420     nd.specfl |= SP_TRAN;
421
422     if (hastexture) {
423     /* Perturb */
424     for (i = 0; i < 3; i++)
425     nd.prdir [i] = rayIn -> rdir [i] - rayIn -> pert [i];
426
427     if (DOT(nd.prdir, rayIn -> ron) < -FTINY)
428     normalize(nd.prdir);
429     else VCOPY(nd.prdir, rayIn -> rdir);
430     }
431     else VCOPY(nd.prdir, rayIn -> rdir);
432
433     if ((nd.specfl & (SP_TRAN | SP_PURE)) == (SP_TRAN | SP_PURE))
434     /* Perfect specular transmission */
435     VCOPY(rayOut.rdir, nd.prdir);
436     else if (!isoSpecPhotonScatter(&nd, &rayOut))
437     return 0;
438
439     photonRay(rayIn, &rayOut, PMAP_SPECTRANS, nd.mcolor);
440     }
441
442     else if (xi > (albedo -= prdiff)) {
443     /* Diffuse reflection */
444     photonRay(rayIn, &rayOut, PMAP_DIFFREFL, nd.mcolor);
445     diffPhotonScatter(hastexture ? nd.pnorm : rayIn -> ron, &rayOut);
446     }
447
448     else {
449     /* Diffuse transmission */
450     flipsurface(rayIn);
451     photonRay(rayIn, &rayOut, PMAP_DIFFTRANS, nd.mcolor);
452
453     if (hastexture) {
454     FVECT bnorm;
455     bnorm [0] = -nd.pnorm [0];
456     bnorm [1] = -nd.pnorm [1];
457     bnorm [2] = -nd.pnorm [2];
458     diffPhotonScatter(bnorm, &rayOut);
459     }
460     else diffPhotonScatter(rayIn -> ron, &rayOut);
461     }
462
463     tracePhoton(&rayOut);
464     return 0;
465     }
466
467
468
469     static void getacoords (ANISODAT *np)
470     /* Set up coordinate system for anisotropic sampling; cloned from aniso.c */
471     {
472     MFUNC *mf;
473     int i;
474
475     mf = getfunc(np->mp, 3, 0x7, 1);
476     setfunc(np->mp, np->rp);
477     errno = 0;
478
479     for (i = 0; i < 3; i++)
480     np->u[i] = evalue(mf->ep[i]);
481
482     if ((errno == EDOM) | (errno == ERANGE)) {
483     objerror(np->mp, WARNING, "compute error");
484     np->specfl |= SP_BADU;
485     return;
486     }
487
488     if (mf->fxp != &unitxf)
489     multv3(np->u, np->u, mf->fxp->xfm);
490
491     fcross(np->v, np->pnorm, np->u);
492
493     if (normalize(np->v) == 0.0) {
494     objerror(np->mp, WARNING, "illegal orientation vector");
495     np->specfl |= SP_BADU;
496     return;
497     }
498
499     fcross(np->u, np->v, np->pnorm);
500     }
501
502
503
504     static int anisoSpecPhotonScatter (ANISODAT *nd, RAY *rayOut)
505     /* Generate direction for anisotropically specularly reflected
506     or transmitted ray. Returns 1 if successful. */
507     {
508     FVECT h;
509     double d, d2, sinp, cosp;
510     int niter, i;
511     RAY *rayIn = nd -> rp;
512
513     if (rayIn -> ro != NULL && isflat(rayIn -> ro -> otype))
514     nd -> specfl |= SP_FLAT;
515
516     /* set up coordinates */
517     getacoords(nd);
518
519     if (rayOut -> rtype & TRANS) {
520     /* Specular transmission */
521
522     if (DOT(rayIn -> pert, rayIn -> pert) <= FTINY * FTINY)
523     VCOPY(nd -> prdir, rayIn -> rdir);
524     else {
525     /* perturb */
526     for (i = 0; i < 3; i++)
527     nd -> prdir [i] = rayIn -> rdir [i] - rayIn -> pert [i];
528
529     if (DOT(nd -> prdir, rayIn -> ron) < -FTINY)
530     normalize(nd -> prdir);
531     else VCOPY(nd -> prdir, rayIn -> rdir);
532     }
533
534     /* Make MAXITER attempts at getting a ray */
535     for (niter = 0; niter < MAXITER; niter++) {
536     d = 2 * PI * pmapRandom(scatterState);
537     cosp = cos(d) * nd -> u_alpha;
538     sinp = sin(d) * nd -> v_alpha;
539     d = sqrt(sqr(cosp) + sqr(sinp));
540     cosp /= d;
541     sinp /= d;
542     d2 = pmapRandom(scatterState);
543     d = d2 <= FTINY ? 1
544     : sqrt(-log(d2) /
545     (sqr(cosp) / sqr(nd -> u_alpha) +
546     sqr(sinp) / (nd -> v_alpha * nd -> u_alpha)));
547
548     for (i = 0; i < 3; i++)
549     rayOut -> rdir [i] = nd -> prdir [i] + d *
550     (cosp * nd -> u [i] + sinp * nd -> v [i]);
551
552     if (DOT(rayOut -> rdir, rayIn -> ron) < -FTINY) {
553     normalize(rayOut -> rdir);
554     return 1;
555     }
556     }
557
558     return 0;
559     }
560
561     else {
562     /* Specular reflection */
563
564     /* Make MAXITER attempts at getting a ray */
565     for (niter = 0; niter < MAXITER; niter++) {
566     d = 2 * PI * pmapRandom(scatterState);
567     cosp = cos(d) * nd -> u_alpha;
568     sinp = sin(d) * nd -> v_alpha;
569     d = sqrt(sqr(cosp) + sqr(sinp));
570     cosp /= d;
571     sinp /= d;
572     d2 = pmapRandom(scatterState);
573     d = d2 <= FTINY ? 1
574     : sqrt(-log(d2) /
575     (sqr(cosp) / sqr(nd -> u_alpha) +
576     sqr(sinp) / (nd -> v_alpha * nd -> v_alpha)));
577
578     for (i = 0; i < 3; i++)
579     h [i] = nd -> pnorm [i] +
580     d * (cosp * nd -> u [i] + sinp * nd -> v [i]);
581
582     d = -2 * DOT(h, rayIn -> rdir) / (1 + d * d);
583     VSUM(rayOut -> rdir, rayIn -> rdir, h, d);
584
585     if (DOT(rayOut -> rdir, rayIn -> ron) > FTINY)
586     return 1;
587     }
588
589     return 0;
590     }
591     }
592
593
594
595     static int anisoPhotonScatter (OBJREC *mat, RAY *rayIn)
596     /* Generate new photon ray for anisotropic material and recurse */
597     {
598     ANISODAT nd;
599     float xi, albedo, prdiff, ptdiff, prspec, ptspec;
600     RAY rayOut;
601
602     if (mat -> oargs.nfargs != (mat -> otype == MAT_TRANS2 ? 8 : 6))
603     objerror(mat, USER, "bad number of real arguments");
604
605     nd.rp = rayIn;
606     nd.mp = objptr(rayIn -> ro -> omod);
607
608     /* get material color */
609     copycolor(nd.mcolor, mat -> oargs.farg);
610
611     /* get roughness */
612     nd.specfl = 0;
613     nd.u_alpha = mat -> oargs.farg [4];
614     nd.v_alpha = mat -> oargs.farg [5];
615     if (nd.u_alpha < FTINY || nd.v_alpha <= FTINY)
616     objerror(mat, USER, "roughness too small");
617
618     /* check for back side; reorient if back is visible */
619     if (rayIn -> rod < 0)
620     if (!backvis && mat -> otype != MAT_TRANS2)
621     return 0;
622     else {
623     /* get modifiers */
624     raytexture(rayIn, mat -> omod);
625     flipsurface(rayIn);
626     }
627     else raytexture(rayIn, mat -> omod);
628
629     /* perturb normal */
630     nd.pdot = max(raynormal(nd.pnorm, rayIn), .001);
631
632     /* modify material color */
633     multcolor(nd.mcolor, rayIn -> pcol);
634     nd.rspec = mat -> oargs.farg [3];
635
636     /* transmission params */
637     if (mat -> otype == MAT_TRANS2) {
638     nd.trans = mat -> oargs.farg [6] * (1 - nd.rspec);
639     nd.tspec = nd.trans * mat -> oargs.farg [7];
640     nd.tdiff = nd.trans - nd.tspec;
641     if (nd.tspec > FTINY)
642     nd.specfl |= SP_TRAN;
643     }
644     else nd.tdiff = nd.tspec = nd.trans = 0;
645
646     /* specular reflection params */
647     if (nd.rspec > FTINY) {
648     nd.specfl |= SP_REFL;
649
650     /* comput e specular color */
651     if (mat -> otype == MAT_METAL2)
652     copycolor(nd.scolor, nd.mcolor);
653     else setcolor(nd.scolor, 1, 1, 1);
654
655     scalecolor(nd.scolor, nd.rspec);
656     }
657     else setcolor(nd.scolor, 0, 0, 0);
658
659     /* diffuse reflection params */
660     nd.rdiff = 1 - nd.trans - nd.rspec;
661
662     /* Set up probabilities */
663     prdiff = ptdiff = ptspec = colorAvg(nd.mcolor);
664     prdiff *= nd.rdiff;
665     ptdiff *= nd.tdiff;
666     prspec = colorAvg(nd.scolor);
667     ptspec *= nd.tspec;
668     albedo = prdiff + ptdiff + prspec + ptspec;
669
670     /* Insert direct and indirect photon hits if diffuse component */
671     if (prdiff > FTINY || ptdiff > FTINY)
672     addPhotons(rayIn);
673
674     xi = pmapRandom(rouletteState);
675
676     if (xi > albedo)
677     /* Absorbed */
678     return 0;
679
680     if (xi > (albedo -= prspec))
681     /* Specular reflection */
682     if (!(nd.specfl & SP_BADU)) {
683     photonRay(rayIn, &rayOut, PMAP_SPECREFL, nd.scolor);
684
685     if (!anisoSpecPhotonScatter(&nd, &rayOut))
686     return 0;
687     }
688     else return 0;
689
690     else if (xi > (albedo -= ptspec))
691     /* Specular transmission */
692
693     if (!(nd.specfl & SP_BADU)) {
694     /* Specular transmission */
695     photonRay(rayIn, &rayOut, PMAP_SPECTRANS, nd.mcolor);
696
697     if (!anisoSpecPhotonScatter(&nd, &rayOut))
698     return 0;
699     }
700     else return 0;
701
702     else if (xi > (albedo -= prdiff)) {
703     /* Diffuse reflection */
704     photonRay(rayIn, &rayOut, PMAP_DIFFREFL, nd.mcolor);
705     diffPhotonScatter(nd.pnorm, &rayOut);
706     }
707
708     else {
709     /* Diffuse transmission */
710     FVECT bnorm;
711     flipsurface(rayIn);
712     bnorm [0] = -nd.pnorm [0];
713     bnorm [1] = -nd.pnorm [1];
714     bnorm [2] = -nd.pnorm [2];
715
716     photonRay(rayIn, &rayOut, PMAP_DIFFTRANS, nd.mcolor);
717     diffPhotonScatter(bnorm, &rayOut);
718     }
719
720     tracePhoton(&rayOut);
721     return 0;
722     }
723
724
725     static double mylog (double x)
726     /* special log for extinction coefficients; cloned from dielectric.c */
727     {
728     if (x < 1e-40)
729     return(-100.);
730
731     if (x >= 1.)
732     return(0.);
733
734     return(log(x));
735     }
736
737
738     static int dielectricPhotonScatter (OBJREC *mat, RAY *rayIn)
739     /* Generate new photon ray for dielectric material and recurse */
740     {
741     double cos1, cos2, nratio, d1, d2, refl;
742     COLOR ctrans, talb;
743     FVECT dnorm;
744     int hastexture, i;
745     RAY rayOut;
746
747     if (mat -> oargs.nfargs != (mat -> otype == MAT_DIELECTRIC ? 5 : 8))
748     objerror(mat, USER, "bad arguments");
749
750     /* get modifiers */
751     raytexture(rayIn, mat -> omod);
752
753 greg 2.4 if ((hastexture = (DOT(rayIn -> pert, rayIn -> pert) > FTINY * FTINY)))
754 greg 2.1 /* Perturb normal */
755     cos1 = raynormal(dnorm, rayIn);
756     else {
757     VCOPY(dnorm, rayIn -> ron);
758     cos1 = rayIn -> rod;
759     }
760
761     /* index of refraction */
762     nratio = mat -> otype ==
763     MAT_DIELECTRIC ? mat -> oargs.farg [3] + mat -> oargs.farg [4] / MLAMBDA
764     : mat -> oargs.farg [3] / mat -> oargs.farg [7];
765
766     if (cos1 < 0) {
767     /* inside */
768     hastexture = -hastexture;
769     cos1 = -cos1;
770     dnorm [0] = -dnorm [0];
771     dnorm [1] = -dnorm [1];
772     dnorm [2] = -dnorm [2];
773     setcolor(rayIn -> cext,
774     -mylog(mat -> oargs.farg [0] * rayIn -> pcol [0]),
775     -mylog(mat -> oargs.farg [1] * rayIn -> pcol [1]),
776     -mylog(mat -> oargs.farg [2] * rayIn -> pcol [2]));
777     setcolor(rayIn -> albedo, 0, 0, 0);
778     rayIn -> gecc = 0;
779
780     if (mat -> otype == MAT_INTERFACE) {
781     setcolor(ctrans,
782     -mylog(mat -> oargs.farg [4] * rayIn -> pcol [0]),
783     -mylog(mat -> oargs.farg [5] * rayIn -> pcol [1]),
784     -mylog(mat -> oargs.farg [6] * rayIn -> pcol [2]));
785     setcolor(talb, 0, 0, 0);
786     }
787     else {
788     copycolor(ctrans, cextinction);
789     copycolor(talb, salbedo);
790     }
791     }
792
793     else {
794     /* outside */
795     nratio = 1.0 / nratio;
796     setcolor(ctrans,
797     -mylog(mat -> oargs.farg [0] * rayIn -> pcol [0]),
798     -mylog(mat -> oargs.farg [1] * rayIn -> pcol [1]),
799     -mylog(mat -> oargs.farg [2] * rayIn -> pcol [2]));
800     setcolor(talb, 0, 0, 0);
801
802     if (mat -> otype == MAT_INTERFACE) {
803     setcolor(rayIn -> cext,
804     -mylog(mat -> oargs.farg [4] * rayIn -> pcol [0]),
805     -mylog(mat -> oargs.farg [5] * rayIn -> pcol [1]),
806     -mylog(mat -> oargs.farg [6] * rayIn -> pcol [2]));
807     setcolor(rayIn -> albedo, 0, 0, 0);
808     rayIn -> gecc = 0;
809     }
810     }
811
812     /* compute cos theta2 */
813     d2 = 1 - sqr(nratio) * (1 - sqr(cos1));
814
815     if (d2 < FTINY) {
816     /* Total reflection */
817     refl = cos2 = 1.0;
818     }
819     else {
820     /* Refraction, compute Fresnel's equations */
821     cos2 = sqrt(d2);
822     d1 = cos1;
823     d2 = nratio * cos2;
824     d1 = (d1 - d2) / (d1 + d2);
825     refl = sqr(d1);
826     d1 = 1 / cos1;
827     d2 = nratio / cos2;
828     d1 = (d1 - d2) / (d1 + d2);
829     refl += sqr(d1);
830     refl *= 0.5;
831     }
832
833     if (pmapRandom(rouletteState) > refl) {
834     /* Refraction */
835     photonRay(rayIn, &rayOut, PMAP_REFRACT, NULL);
836     d1 = nratio * cos1 - cos2;
837
838     for (i = 0; i < 3; i++)
839     rayOut.rdir [i] = nratio * rayIn -> rdir [i] + d1 * dnorm [i];
840
841     if (hastexture && DOT(rayOut.rdir, rayIn -> ron) * hastexture >= -FTINY) {
842     d1 *= hastexture;
843
844     for (i = 0; i < 3; i++)
845     rayOut.rdir [i] = nratio * rayIn -> rdir [i] +
846     d1 * rayIn -> ron [i];
847
848     normalize(rayOut.rdir);
849     }
850
851     copycolor(rayOut.cext, ctrans);
852     copycolor(rayOut.albedo, talb);
853     }
854
855     else {
856     /* Reflection */
857     photonRay(rayIn, &rayOut, PMAP_SPECREFL, NULL);
858     VSUM(rayOut.rdir, rayIn -> rdir, dnorm, 2 * cos1);
859
860     if (hastexture && DOT(rayOut.rdir, rayIn -> ron) * hastexture <= FTINY)
861     for (i = 0; i < 3; i++)
862     rayOut.rdir [i] = rayIn -> rdir [i] +
863     2 * rayIn -> rod * rayIn -> ron [i];
864     }
865
866     /* Ray is modified by medium defined by cext and albedo in
867     * photonParticipate() */
868     tracePhoton(&rayOut);
869
870     return 0;
871     }
872
873
874
875     static int glassPhotonScatter (OBJREC *mat, RAY *rayIn)
876     /* Generate new photon ray for glass material and recurse */
877     {
878     float albedo, xi, ptrans;
879     COLOR mcolor, refl, trans;
880     double pdot, cos2, d, r1e, r1m, rindex = 0.0;
881     FVECT pnorm, pdir;
882     int hastexture, i;
883     RAY rayOut;
884
885     /* check arguments */
886     if (mat -> oargs.nfargs == 3)
887     rindex = RINDEX;
888     else if (mat -> oargs.nfargs == 4)
889     rindex = mat -> oargs.farg [3];
890     else objerror(mat, USER, "bad arguments");
891
892     copycolor(mcolor, mat -> oargs.farg);
893
894     /* get modifiers */
895     raytexture(rayIn, mat -> omod);
896
897     /* reorient if necessary */
898     if (rayIn -> rod < 0)
899     flipsurface(rayIn);
900 greg 2.4 if ((hastexture = (DOT(rayIn -> pert, rayIn -> pert) > FTINY * FTINY) ))
901 greg 2.1 pdot = raynormal(pnorm, rayIn);
902     else {
903     VCOPY(pnorm, rayIn -> ron);
904     pdot = rayIn -> rod;
905     }
906
907     /* Modify material color */
908     multcolor(mcolor, rayIn -> pcol);
909
910     /* angular transmission */
911     cos2 = sqrt((1 - 1 / sqr(rindex)) + sqr(pdot / rindex));
912     setcolor(mcolor, pow(mcolor [0], 1 / cos2), pow(mcolor [1], 1 / cos2),
913     pow(mcolor [2], 1 / cos2));
914
915     /* compute reflection */
916     r1e = (pdot - rindex * cos2) / (pdot + rindex * cos2);
917     r1e *= r1e;
918     r1m = (1 / pdot - rindex / cos2) / (1 / pdot + rindex / cos2);
919     r1m *= r1m;
920
921     for (i = 0; i < 3; i++) {
922     double r1ed2, r1md2, d2;
923
924     d = mcolor [i];
925     d2 = sqr(d);
926     r1ed2 = sqr(r1e) * d2;
927     r1md2 = sqr(r1m) * d2;
928
929     /* compute transmittance */
930     trans [i] = 0.5 * d *
931     (sqr(1 - r1e) / (1 - r1ed2) + sqr(1 - r1m) / (1 - r1md2));
932
933     /* compute reflectance */
934     refl [i] = 0.5 * (r1e * (1 + (1 - 2 * r1e) * d2) / (1 - r1ed2) +
935     r1m * (1 + (1 - 2 * r1m) * d2) / (1 - r1md2));
936     }
937
938     /* Set up probabilities */
939     ptrans = colorAvg(trans);
940     albedo = colorAvg(refl) + ptrans;
941     xi = pmapRandom(rouletteState);
942
943
944     if (xi > albedo)
945     /* Absorbed */
946     return 0;
947
948     if (xi > (albedo -= ptrans)) {
949     /* Transmitted */
950
951     if (hastexture) {
952     /* perturb direction */
953     VSUM(pdir, rayIn -> rdir, rayIn -> pert, 2 * (1 - rindex));
954
955     if (normalize(pdir) == 0) {
956     objerror(mat, WARNING, "bad perturbation");
957     VCOPY(pdir, rayIn -> rdir);
958     }
959     }
960     else VCOPY(pdir, rayIn -> rdir);
961
962     VCOPY(rayOut.rdir, pdir);
963     photonRay(rayIn, &rayOut, PMAP_SPECTRANS, mcolor);
964     }
965
966     else {
967     /* reflected ray */
968     VSUM(rayOut.rdir, rayIn -> rdir, pnorm, 2 * pdot);
969     photonRay(rayIn, &rayOut, PMAP_SPECREFL, mcolor);
970     }
971
972     tracePhoton(&rayOut);
973     return 0;
974     }
975
976
977
978     static int aliasPhotonScatter (OBJREC *mat, RAY *rayIn)
979     /* Transfer photon scattering to alias target */
980     {
981     OBJECT aliasObj;
982     OBJREC aliasRec;
983
984     /* Straight replacement? */
985     if (!mat -> oargs.nsargs) {
986 rschregle 2.11 /* Skip void modifier! */
987 rschregle 2.13 if (mat -> omod != OVOID) {
988 rschregle 2.11 mat = objptr(mat -> omod);
989     photonScatter [mat -> otype] (mat, rayIn);
990     }
991 greg 2.1
992     return 0;
993     }
994
995     /* Else replace alias */
996     if (mat -> oargs.nsargs != 1)
997     objerror(mat, INTERNAL, "bad # string arguments");
998
999     aliasObj = lastmod(objndx(mat), mat -> oargs.sarg [0]);
1000
1001     if (aliasObj < 0)
1002     objerror(mat, USER, "bad reference");
1003
1004     memcpy(&aliasRec, objptr(aliasObj), sizeof(OBJREC));
1005
1006     /* Substitute modifier */
1007     aliasRec.omod = mat -> omod;
1008
1009     /* Replacement scattering routine */
1010     photonScatter [aliasRec.otype] (&aliasRec, rayIn);
1011     return 0;
1012     }
1013
1014
1015
1016     static int clipPhotonScatter (OBJREC *mat, RAY *rayIn)
1017     /* Generate new photon ray for antimatter material and recurse */
1018     {
1019     OBJECT obj = objndx(mat), mod, cset [MAXSET + 1], *modset;
1020     int entering, inside = 0, i;
1021     const RAY *rp;
1022     RAY rayOut;
1023
1024     if ((modset = (OBJECT*)mat -> os) == NULL) {
1025     if (mat -> oargs.nsargs < 1 || mat -> oargs.nsargs > MAXSET)
1026     objerror(mat, USER, "bad # arguments");
1027
1028     modset = (OBJECT*)malloc((mat -> oargs.nsargs + 1) * sizeof(OBJECT));
1029
1030     if (modset == NULL)
1031     error(SYSTEM, "out of memory in clipPhotonScatter");
1032     modset [0] = 0;
1033
1034     for (i = 0; i < mat -> oargs.nsargs; i++) {
1035     if (!strcmp(mat -> oargs.sarg [i], VOIDID))
1036     continue;
1037
1038     if ((mod = lastmod(obj, mat -> oargs.sarg [i])) == OVOID) {
1039     sprintf(errmsg, "unknown modifier \"%s\"", mat -> oargs.sarg [i]);
1040     objerror(mat, WARNING, errmsg);
1041     continue;
1042     }
1043
1044     if (inset(modset, mod)) {
1045     objerror(mat, WARNING, "duplicate modifier");
1046     continue;
1047     }
1048
1049     insertelem(modset, mod);
1050     }
1051
1052     mat -> os = (char*)modset;
1053     }
1054
1055     if (rayIn -> clipset != NULL)
1056     setcopy(cset, rayIn -> clipset);
1057     else cset [0] = 0;
1058
1059     entering = rayIn -> rod > 0;
1060
1061     /* Store photon incident from front if material defined as sensor */
1062     if (entering && inset(photonSensorSet, obj))
1063     addPhotons(rayIn);
1064
1065     for (i = modset [0]; i > 0; i--) {
1066     if (entering) {
1067     if (!inset(cset, modset [i])) {
1068     if (cset [0] >= MAXSET)
1069     error(INTERNAL, "set overflow in clipPhotonScatter");
1070     insertelem(cset, modset [i]);
1071     }
1072     }
1073     else if (inset(cset, modset [i]))
1074     deletelem(cset, modset [i]);
1075     }
1076
1077     rayIn -> newcset = cset;
1078
1079     if (strcmp(mat -> oargs.sarg [0], VOIDID)) {
1080     for (rp = rayIn; rp -> parent != NULL; rp = rp -> parent) {
1081     if ( !(rp -> rtype & RAYREFL) && rp->parent->ro != NULL &&
1082     inset(modset, rp -> parent -> ro -> omod)) {
1083
1084     if (rp -> parent -> rod > 0)
1085     inside++;
1086     else inside--;
1087     }
1088     }
1089
1090     if (inside > 0) {
1091     flipsurface(rayIn);
1092     mat = objptr(lastmod(obj, mat -> oargs.sarg [0]));
1093     photonScatter [mat -> otype] (mat, rayIn);
1094     return 0;
1095     }
1096     }
1097
1098     /* Else transfer ray */
1099     photonRay(rayIn, &rayOut, PMAP_XFER, NULL);
1100     tracePhoton(&rayOut);
1101
1102     return 0;
1103     }
1104
1105
1106
1107     static int mirrorPhotonScatter (OBJREC *mat, RAY *rayIn)
1108     /* Generate new photon ray for mirror material and recurse */
1109     {
1110     RAY rayOut;
1111     int rpure = 1, i;
1112     FVECT pnorm;
1113     double pdot;
1114     float albedo;
1115     COLOR mcolor;
1116
1117     /* check arguments */
1118     if (mat -> oargs.nfargs != 3 || mat -> oargs.nsargs > 1)
1119     objerror(mat, USER, "bad number of arguments");
1120
1121     /* back is black */
1122     if (rayIn -> rod < 0)
1123     return 0;
1124
1125     /* get modifiers */
1126     raytexture(rayIn, mat -> omod);
1127
1128     /* assign material color */
1129     copycolor(mcolor, mat -> oargs.farg);
1130     multcolor(mcolor, rayIn -> pcol);
1131
1132     /* Set up probabilities */
1133     albedo = colorAvg(mcolor);
1134
1135     if (pmapRandom(rouletteState) > albedo)
1136     /* Absorbed */
1137     return 0;
1138
1139     /* compute reflected ray */
1140     photonRay(rayIn, &rayOut, PMAP_SPECREFL, mcolor);
1141
1142     if (DOT(rayIn -> pert, rayIn -> pert) > sqr(FTINY)) {
1143     /* use textures */
1144     pdot = raynormal(pnorm, rayIn);
1145
1146     for (i = 0; i < 3; i++)
1147     rayOut.rdir [i] = rayIn -> rdir [i] + 2 * pdot * pnorm [i];
1148
1149     rpure = 0;
1150     }
1151
1152     /* Check for penetration */
1153     if (rpure || DOT(rayOut.rdir, rayIn -> ron) <= FTINY)
1154     for (i = 0; i < 3; i++)
1155     rayOut.rdir [i] = rayIn -> rdir [i] +
1156     2 * rayIn -> rod * rayIn -> ron [i];
1157
1158     tracePhoton(&rayOut);
1159     return 0;
1160     }
1161
1162
1163
1164     static int mistPhotonScatter (OBJREC *mat, RAY *rayIn)
1165     /* Generate new photon ray within mist and recurse */
1166     {
1167     COLOR mext;
1168     RREAL re, ge, be;
1169     RAY rayOut;
1170
1171     /* check arguments */
1172     if (mat -> oargs.nfargs > 7)
1173     objerror(mat, USER, "bad arguments");
1174
1175     if (mat -> oargs.nfargs > 2) {
1176     /* compute extinction */
1177     copycolor(mext, mat -> oargs.farg);
1178     /* get modifiers */
1179     raytexture(rayIn, mat -> omod);
1180     multcolor(mext, rayIn -> pcol);
1181     }
1182     else setcolor(mext, 0, 0, 0);
1183
1184     photonRay(rayIn, &rayOut, PMAP_XFER, NULL);
1185
1186     if (rayIn -> rod > 0) {
1187     /* entering ray */
1188     addcolor(rayOut.cext, mext);
1189
1190     if (mat -> oargs.nfargs > 5)
1191     copycolor(rayOut.albedo, mat -> oargs.farg + 3);
1192     if (mat -> oargs.nfargs > 6)
1193     rayOut.gecc = mat -> oargs.farg [6];
1194     }
1195
1196     else {
1197     /* leaving ray */
1198     re = max(rayIn -> cext [0] - mext [0], cextinction [0]);
1199     ge = max(rayIn -> cext [1] - mext [1], cextinction [1]);
1200     be = max(rayIn -> cext [2] - mext [2], cextinction [2]);
1201     setcolor(rayOut.cext, re, ge, be);
1202
1203     if (mat -> oargs.nfargs > 5)
1204     copycolor(rayOut.albedo, salbedo);
1205     if (mat -> oargs.nfargs > 6)
1206     rayOut.gecc = seccg;
1207     }
1208
1209     tracePhoton(&rayOut);
1210
1211     return 0;
1212     }
1213
1214
1215
1216     static int mx_dataPhotonScatter (OBJREC *mat, RAY *rayIn)
1217     /* Pass photon on to materials selected by mixture data */
1218     {
1219     OBJECT obj;
1220     double coef, pt [MAXDIM];
1221     DATARRAY *dp;
1222     OBJECT mod [2];
1223     MFUNC *mf;
1224     int i;
1225
1226     if (mat -> oargs.nsargs < 6)
1227     objerror(mat, USER, "bad # arguments");
1228
1229     obj = objndx(mat);
1230
1231     for (i = 0; i < 2; i++)
1232     if (!strcmp(mat -> oargs.sarg [i], VOIDID))
1233     mod [i] = OVOID;
1234     else if ((mod [i] = lastmod(obj, mat -> oargs.sarg [i])) == OVOID) {
1235     sprintf(errmsg, "undefined modifier \"%s\"", mat -> oargs.sarg [i]);
1236     objerror(mat, USER, errmsg);
1237     }
1238
1239     dp = getdata(mat -> oargs.sarg [3]);
1240     i = (1 << dp -> nd) - 1;
1241     mf = getfunc(mat, 4, i << 5, 0);
1242     setfunc(mat, rayIn);
1243     errno = 0;
1244
1245     for (i = 0; i < dp -> nd; i++) {
1246     pt [i] = evalue(mf -> ep [i]);
1247
1248     if (errno) {
1249     objerror(mat, WARNING, "compute error");
1250     return 0;
1251     }
1252     }
1253
1254     coef = datavalue(dp, pt);
1255     errno = 0;
1256     coef = funvalue(mat -> oargs.sarg [2], 1, &coef);
1257
1258     if (errno)
1259     objerror(mat, WARNING, "compute error");
1260     else {
1261 rschregle 2.10 OBJECT mxMod = mod [pmapRandom(rouletteState) < coef ? 0 : 1];
1262
1263     if (mxMod != OVOID) {
1264     mat = objptr(mxMod);
1265     photonScatter [mat -> otype] (mat, rayIn);
1266     }
1267     else {
1268     /* Transfer ray if no modifier */
1269     RAY rayOut;
1270
1271     photonRay(rayIn, &rayOut, PMAP_XFER, NULL);
1272     tracePhoton(&rayOut);
1273     }
1274 greg 2.1 }
1275
1276     return 0;
1277     }
1278
1279
1280
1281     static int mx_pdataPhotonScatter (OBJREC *mat, RAY *rayIn)
1282     /* Pass photon on to materials selected by mixture picture */
1283     {
1284     OBJECT obj;
1285     double col [3], coef, pt [MAXDIM];
1286     DATARRAY *dp;
1287     OBJECT mod [2];
1288     MFUNC *mf;
1289     int i;
1290
1291     if (mat -> oargs.nsargs < 7)
1292     objerror(mat, USER, "bad # arguments");
1293
1294     obj = objndx(mat);
1295
1296     for (i = 0; i < 2; i++)
1297     if (!strcmp(mat -> oargs.sarg [i], VOIDID))
1298     mod [i] = OVOID;
1299     else if ((mod [i] = lastmod(obj, mat -> oargs.sarg [i])) == OVOID) {
1300     sprintf(errmsg, "undefined modifier \"%s\"", mat -> oargs.sarg [i]);
1301     objerror(mat, USER, errmsg);
1302     }
1303
1304     dp = getpict(mat -> oargs.sarg [3]);
1305     mf = getfunc(mat, 4, 0x3 << 5, 0);
1306     setfunc(mat, rayIn);
1307     errno = 0;
1308     pt [1] = evalue(mf -> ep [0]);
1309     pt [0] = evalue(mf -> ep [1]);
1310
1311     if (errno) {
1312     objerror(mat, WARNING, "compute error");
1313     return 0;
1314     }
1315
1316     for (i = 0; i < 3; i++)
1317     col [i] = datavalue(dp + i, pt);
1318
1319     errno = 0;
1320     coef = funvalue(mat -> oargs.sarg [2], 3, col);
1321
1322     if (errno)
1323     objerror(mat, WARNING, "compute error");
1324     else {
1325 rschregle 2.10 OBJECT mxMod = mod [pmapRandom(rouletteState) < coef ? 0 : 1];
1326
1327     if (mxMod != OVOID) {
1328     mat = objptr(mxMod);
1329     photonScatter [mat -> otype] (mat, rayIn);
1330     }
1331     else {
1332     /* Transfer ray if no modifier */
1333     RAY rayOut;
1334
1335     photonRay(rayIn, &rayOut, PMAP_XFER, NULL);
1336     tracePhoton(&rayOut);
1337     }
1338 greg 2.1 }
1339
1340     return 0;
1341     }
1342
1343
1344
1345     static int mx_funcPhotonScatter (OBJREC *mat, RAY *rayIn)
1346     /* Pass photon on to materials selected by mixture function */
1347     {
1348     OBJECT obj, mod [2];
1349     int i;
1350     double coef;
1351     MFUNC *mf;
1352
1353     if (mat -> oargs.nsargs < 4)
1354     objerror(mat, USER, "bad # arguments");
1355
1356     obj = objndx(mat);
1357
1358     for (i = 0; i < 2; i++)
1359     if (!strcmp(mat -> oargs.sarg [i], VOIDID))
1360     mod [i] = OVOID;
1361     else if ((mod [i] = lastmod(obj, mat -> oargs.sarg [i])) == OVOID) {
1362     sprintf(errmsg, "undefined modifier \"%s\"", mat -> oargs.sarg [i]);
1363     objerror(mat, USER, errmsg);
1364     }
1365
1366     mf = getfunc(mat, 3, 0x4, 0);
1367     setfunc(mat, rayIn);
1368     errno = 0;
1369
1370     /* bound coefficient */
1371     coef = min(1, max(0, evalue(mf -> ep [0])));
1372
1373     if (errno)
1374     objerror(mat, WARNING, "compute error");
1375     else {
1376 rschregle 2.10 OBJECT mxMod = mod [pmapRandom(rouletteState) < coef ? 0 : 1];
1377
1378     if (mxMod != OVOID) {
1379     mat = objptr(mxMod);
1380     photonScatter [mat -> otype] (mat, rayIn);
1381     }
1382     else {
1383     /* Transfer ray if no modifier */
1384     RAY rayOut;
1385
1386     photonRay(rayIn, &rayOut, PMAP_XFER, NULL);
1387     tracePhoton(&rayOut);
1388     }
1389 greg 2.1 }
1390
1391     return 0;
1392     }
1393
1394
1395
1396     static int pattexPhotonScatter (OBJREC *mat, RAY *rayIn)
1397     /* Generate new photon ray for pattern or texture modifier and recurse.
1398     This code is brought to you by Henkel! :^) */
1399     {
1400     RAY rayOut;
1401
1402     /* Get pattern */
1403     ofun [mat -> otype].funp(mat, rayIn);
1404     if (mat -> omod != OVOID) {
1405     /* Scatter using modifier (if any) */
1406     mat = objptr(mat -> omod);
1407     photonScatter [mat -> otype] (mat, rayIn);
1408     }
1409     else {
1410     /* Transfer ray if no modifier */
1411     photonRay(rayIn, &rayOut, PMAP_XFER, NULL);
1412     tracePhoton(&rayOut);
1413     }
1414
1415     return 0;
1416     }
1417
1418
1419
1420 rschregle 2.3 /*
1421 rschregle 2.7 ==================================================================
1422 rschregle 2.3 The following code is
1423     (c) Lucerne University of Applied Sciences and Arts,
1424     supported by the Swiss National Science Foundation (SNSF, #147053)
1425 rschregle 2.7 ==================================================================
1426 rschregle 2.3 */
1427
1428 greg 2.1 static int bsdfPhotonScatter (OBJREC *mat, RAY *rayIn)
1429     /* Generate new photon ray for BSDF modifier and recurse. */
1430     {
1431 greg 2.17 int hasthick = (mat->otype == MAT_BSDF);
1432 greg 2.1 int hitFront;
1433     SDError err;
1434 rschregle 2.2 SDValue bsdfVal;
1435 greg 2.1 FVECT upvec;
1436     MFUNC *mf;
1437     BSDFDAT nd;
1438     RAY rayOut;
1439 rschregle 2.2 COLOR bsdfRGB;
1440 greg 2.6 int transmitted;
1441 rschregle 2.2 double prDiff, ptDiff, prDiffSD, ptDiffSD, prSpecSD, ptSpecSD,
1442 greg 2.6 albedo, xi;
1443     const double patAlb = bright(rayIn -> pcol);
1444 rschregle 2.2
1445 greg 2.1 /* Following code adapted from m_bsdf() */
1446     /* Check arguments */
1447 greg 2.17 if (mat -> oargs.nsargs < hasthick+5 || mat -> oargs.nfargs > 9 ||
1448 greg 2.1 mat -> oargs.nfargs % 3)
1449     objerror(mat, USER, "bad # arguments");
1450
1451 rschregle 2.16 hitFront = (rayIn -> rod > 0);
1452 greg 2.1
1453 rschregle 2.16 /* Load cal file */
1454 greg 2.17 mf = hasthick ? getfunc(mat, 5, 0x1d, 1) : getfunc(mat, 4, 0xe, 1);
1455 rschregle 2.16
1456     /* Get thickness */
1457 greg 2.17 nd.thick = 0;
1458     if (hasthick) {
1459     nd.thick = evalue(mf -> ep [0]);
1460     if ((-FTINY <= nd.thick) & (nd.thick <= FTINY))
1461     nd.thick = .0;
1462     }
1463 rschregle 2.7
1464 greg 2.1 /* Get BSDF data */
1465 greg 2.17 nd.sd = loadBSDF(mat -> oargs.sarg [hasthick]);
1466 greg 2.1
1467 rschregle 2.2 /* Extra diffuse reflectance from material def */
1468 greg 2.1 if (hitFront) {
1469     if (mat -> oargs.nfargs < 3)
1470     setcolor(nd.rdiff, .0, .0, .0);
1471     else setcolor(nd.rdiff, mat -> oargs.farg [0], mat -> oargs.farg [1],
1472     mat -> oargs.farg [2]);
1473     }
1474     else if (mat -> oargs.nfargs < 6) {
1475     /* Check for absorbing backside */
1476     if (!backvis && !nd.sd -> rb && !nd.sd -> tf) {
1477     SDfreeCache(nd.sd);
1478     return 0;
1479     }
1480
1481     setcolor(nd.rdiff, .0, .0, .0);
1482     }
1483     else setcolor(nd.rdiff, mat -> oargs.farg [3], mat -> oargs.farg [4],
1484     mat -> oargs.farg [5]);
1485
1486 rschregle 2.16 /* Extra diffuse transmittance from material def */
1487     if (mat -> oargs.nfargs < 9)
1488     setcolor(nd.tdiff, .0, .0, .0);
1489 greg 2.1 else setcolor(nd.tdiff, mat -> oargs.farg [6], mat -> oargs.farg [7],
1490     mat -> oargs.farg [8]);
1491
1492     nd.mp = mat;
1493     nd.pr = rayIn;
1494 rschregle 2.16
1495 greg 2.1 /* Get modifiers */
1496     raytexture(rayIn, mat -> omod);
1497
1498     /* Modify diffuse values */
1499     multcolor(nd.rdiff, rayIn -> pcol);
1500     multcolor(nd.tdiff, rayIn -> pcol);
1501 rschregle 2.16
1502 greg 2.1 /* Get up vector & xform to world coords */
1503 greg 2.17 upvec [0] = evalue(mf -> ep [hasthick+0]);
1504     upvec [1] = evalue(mf -> ep [hasthick+1]);
1505     upvec [2] = evalue(mf -> ep [hasthick+2]);
1506 greg 2.1
1507     if (mf -> fxp != &unitxf) {
1508     multv3(upvec, upvec, mf -> fxp -> xfm);
1509     nd.thick *= mf -> fxp -> sca;
1510     }
1511
1512     if (rayIn -> rox) {
1513     multv3(upvec, upvec, rayIn -> rox -> f.xfm);
1514     nd.thick *= rayIn -> rox -> f.sca;
1515     }
1516
1517     /* Perturb normal */
1518     raynormal(nd.pnorm, rayIn);
1519
1520     /* Xform incident dir to local BSDF coords */
1521     err = SDcompXform(nd.toloc, nd.pnorm, upvec);
1522
1523     if (!err) {
1524     nd.vray [0] = -rayIn -> rdir [0];
1525     nd.vray [1] = -rayIn -> rdir [1];
1526     nd.vray [2] = -rayIn -> rdir [2];
1527     err = SDmapDir(nd.vray, nd.toloc, nd.vray);
1528     }
1529
1530     if (!err)
1531     err = SDinvXform(nd.fromloc, nd.toloc);
1532
1533     if (err) {
1534     objerror(mat, WARNING, "Illegal orientation vector");
1535     return 0;
1536     }
1537
1538     /* Determine BSDF resolution */
1539     err = SDsizeBSDF(nd.sr_vpsa, nd.vray, NULL, SDqueryMin + SDqueryMax, nd.sd);
1540
1541     if (err)
1542     objerror(mat, USER, transSDError(err));
1543
1544     nd.sr_vpsa [0] = sqrt(nd.sr_vpsa [0]);
1545     nd.sr_vpsa [1] = sqrt(nd.sr_vpsa [1]);
1546
1547     /* Orient perturbed normal towards incident side */
1548 rschregle 2.16 if (!hitFront) {
1549 greg 2.1 nd.pnorm [0] = -nd.pnorm [0];
1550     nd.pnorm [1] = -nd.pnorm [1];
1551     nd.pnorm [2] = -nd.pnorm [2];
1552     }
1553 rschregle 2.2
1554     /* Get scatter probabilities (weighted by pattern except for spec refl)
1555     * prDiff, ptDiff: extra diffuse component in material def
1556     * prDiffSD, ptDiffSD: diffuse (constant) component in SDF
1557     * prSpecSD, ptSpecSD: non-diffuse ("specular") component in SDF
1558     * albedo: sum of above, inverse absorption probability */
1559     prDiff = colorAvg(nd.rdiff);
1560     ptDiff = colorAvg(nd.tdiff);
1561     prDiffSD = patAlb * SDdirectHemi(nd.vray, SDsampDf | SDsampR, nd.sd);
1562     ptDiffSD = patAlb * SDdirectHemi(nd.vray, SDsampDf | SDsampT, nd.sd);
1563     prSpecSD = SDdirectHemi(nd.vray, SDsampSp | SDsampR, nd.sd);
1564     ptSpecSD = patAlb * SDdirectHemi(nd.vray, SDsampSp | SDsampT, nd.sd);
1565     albedo = prDiff + ptDiff + prDiffSD + ptDiffSD + prSpecSD + ptSpecSD;
1566
1567     /*
1568     if (albedo > 1)
1569     objerror(mat, WARNING, "Invalid albedo");
1570     */
1571
1572     /* Insert direct and indirect photon hits if diffuse component */
1573     if (prDiff + ptDiff + prDiffSD + ptDiffSD > FTINY)
1574     addPhotons(rayIn);
1575
1576 greg 2.6 xi = pmapRandom(rouletteState);
1577 rschregle 2.2
1578     if (xi > albedo)
1579     /* Absorbtion */
1580     return 0;
1581
1582 greg 2.6 transmitted = 0;
1583
1584 rschregle 2.2 if ((xi -= prDiff) <= 0) {
1585     /* Diffuse reflection (extra component in material def) */
1586     photonRay(rayIn, &rayOut, PMAP_DIFFREFL, nd.rdiff);
1587     diffPhotonScatter(nd.pnorm, &rayOut);
1588     }
1589 greg 2.1
1590 rschregle 2.2 else if ((xi -= ptDiff) <= 0) {
1591     /* Diffuse transmission (extra component in material def) */
1592     photonRay(rayIn, &rayOut, PMAP_DIFFTRANS, nd.tdiff);
1593 greg 2.6 diffPhotonScatter(nd.pnorm, &rayOut);
1594     transmitted = 1;
1595 rschregle 2.2 }
1596 greg 2.6
1597 rschregle 2.2 else { /* Sample SDF */
1598     if ((xi -= prDiffSD) <= 0) {
1599     /* Diffuse SDF reflection (constant component) */
1600 greg 2.6 if ((err = SDsampBSDF(&bsdfVal, nd.vray, pmapRandom(scatterState),
1601 rschregle 2.2 SDsampDf | SDsampR, nd.sd)))
1602     objerror(mat, USER, transSDError(err));
1603
1604     /* Apply pattern to spectral component */
1605     ccy2rgb(&bsdfVal.spec, bsdfVal.cieY, bsdfRGB);
1606     multcolor(bsdfRGB, rayIn -> pcol);
1607     photonRay(rayIn, &rayOut, PMAP_DIFFREFL, bsdfRGB);
1608 greg 2.1 }
1609 rschregle 2.2
1610     else if ((xi -= ptDiffSD) <= 0) {
1611     /* Diffuse SDF transmission (constant component) */
1612 greg 2.6 if ((err = SDsampBSDF(&bsdfVal, nd.vray, pmapRandom(scatterState),
1613 rschregle 2.2 SDsampDf | SDsampT, nd.sd)))
1614     objerror(mat, USER, transSDError(err));
1615 greg 2.1
1616 rschregle 2.2 /* Apply pattern to spectral component */
1617     ccy2rgb(&bsdfVal.spec, bsdfVal.cieY, bsdfRGB);
1618     multcolor(bsdfRGB, rayIn -> pcol);
1619     addcolor(bsdfRGB, nd.tdiff);
1620 rschregle 2.7 photonRay(rayIn, &rayOut, PMAP_DIFFTRANS, bsdfRGB);
1621 greg 2.6 transmitted = 1;
1622 greg 2.1 }
1623 rschregle 2.2
1624     else if ((xi -= prSpecSD) <= 0) {
1625     /* Non-diffuse ("specular") SDF reflection */
1626 greg 2.6 if ((err = SDsampBSDF(&bsdfVal, nd.vray, pmapRandom(scatterState),
1627 rschregle 2.2 SDsampSp | SDsampR, nd.sd)))
1628     objerror(mat, USER, transSDError(err));
1629 greg 2.1
1630 rschregle 2.2 ccy2rgb(&bsdfVal.spec, bsdfVal.cieY, bsdfRGB);
1631     photonRay(rayIn, &rayOut, PMAP_SPECREFL, bsdfRGB);
1632 greg 2.1 }
1633
1634     else {
1635 rschregle 2.2 /* Non-diffuse ("specular") SDF transmission */
1636 greg 2.6 if ((err = SDsampBSDF(&bsdfVal, nd.vray, pmapRandom(scatterState),
1637 rschregle 2.2 SDsampSp | SDsampT, nd.sd)))
1638     objerror(mat, USER, transSDError(err));
1639 greg 2.1
1640 rschregle 2.2 /* Apply pattern to spectral component */
1641 greg 2.1 ccy2rgb(&bsdfVal.spec, bsdfVal.cieY, bsdfRGB);
1642 rschregle 2.2 multcolor(bsdfRGB, rayIn -> pcol);
1643     photonRay(rayIn, &rayOut, PMAP_SPECTRANS, bsdfRGB);
1644 greg 2.6 transmitted = 1;
1645 rschregle 2.2 }
1646
1647     /* Xform outgoing dir to world coords */
1648     if ((err = SDmapDir(rayOut.rdir, nd.fromloc, nd.vray))) {
1649     objerror(mat, USER, transSDError(err));
1650     return 0;
1651 greg 2.1 }
1652 rschregle 2.2 }
1653 greg 2.1
1654 rschregle 2.2 /* Clean up */
1655 greg 2.1 SDfreeCache(nd.sd);
1656
1657 rschregle 2.16 /* Offset outgoing photon origin by thickness to bypass proxy geometry */
1658 greg 2.6 if (transmitted && nd.thick != 0)
1659 rschregle 2.7 VSUM(rayOut.rorg, rayOut.rorg, rayIn -> ron, -nd.thick);
1660 greg 2.6
1661 greg 2.1 tracePhoton(&rayOut);
1662     return 0;
1663     }
1664
1665
1666
1667     static int lightPhotonScatter (OBJREC* mat, RAY* ray)
1668 rschregle 2.15 /* Light sources doan' reflect, mang */
1669 greg 2.1 {
1670     return 0;
1671     }
1672
1673
1674
1675     void initPhotonScatterFuncs ()
1676     /* Init photonScatter[] dispatch table */
1677     {
1678     int i;
1679
1680     for (i = 0; i < NUMOTYPE; i++)
1681     photonScatter [i] = o_default;
1682
1683     photonScatter [MAT_LIGHT] = photonScatter [MAT_ILLUM] =
1684     photonScatter [MAT_GLOW] = photonScatter [MAT_SPOT] =
1685     lightPhotonScatter;
1686
1687     photonScatter [MAT_PLASTIC] = photonScatter [MAT_METAL] =
1688     photonScatter [MAT_TRANS] = normalPhotonScatter;
1689
1690     photonScatter [MAT_PLASTIC2] = photonScatter [MAT_METAL2] =
1691     photonScatter [MAT_TRANS2] = anisoPhotonScatter;
1692
1693     photonScatter [MAT_DIELECTRIC] = photonScatter [MAT_INTERFACE] =
1694     dielectricPhotonScatter;
1695
1696     photonScatter [MAT_MIST] = mistPhotonScatter;
1697     photonScatter [MAT_GLASS] = glassPhotonScatter;
1698     photonScatter [MAT_CLIP] = clipPhotonScatter;
1699     photonScatter [MAT_MIRROR] = mirrorPhotonScatter;
1700     photonScatter [MIX_FUNC] = mx_funcPhotonScatter;
1701     photonScatter [MIX_DATA] = mx_dataPhotonScatter;
1702     photonScatter [MIX_PICT]= mx_pdataPhotonScatter;
1703
1704     photonScatter [PAT_BDATA] = photonScatter [PAT_CDATA] =
1705     photonScatter [PAT_BFUNC] = photonScatter [PAT_CFUNC] =
1706     photonScatter [PAT_CPICT] = photonScatter [TEX_FUNC] =
1707     photonScatter [TEX_DATA] = pattexPhotonScatter;
1708
1709     photonScatter [MOD_ALIAS] = aliasPhotonScatter;
1710 greg 2.17 photonScatter [MAT_BSDF] =
1711 greg 2.18 photonScatter [MAT_ABSDF] = bsdfPhotonScatter;
1712 greg 2.1 }
