--- ray/src/rt/pmapmat.c 2018/06/11 12:46:51 2.16 +++ ray/src/rt/pmapmat.c 2018/06/25 20:49:10 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pmapmat.c,v 2.16 2018/06/11 12:46:51 rschregle Exp $"; +static const char RCSid[] = "$Id: pmapmat.c,v 2.17 2018/06/25 20:49:10 greg Exp $"; #endif /* ================================================================== @@ -1428,6 +1428,7 @@ static int pattexPhotonScatter (OBJREC *mat, RAY *rayI static int bsdfPhotonScatter (OBJREC *mat, RAY *rayIn) /* Generate new photon ray for BSDF modifier and recurse. */ { + int hasthick = (mat->otype == MAT_BSDF); int hitFront; SDError err; SDValue bsdfVal; @@ -1443,22 +1444,25 @@ static int bsdfPhotonScatter (OBJREC *mat, RAY *rayIn) /* Following code adapted from m_bsdf() */ /* Check arguments */ - if (mat -> oargs.nsargs < 6 || mat -> oargs.nfargs > 9 || + if (mat -> oargs.nsargs < hasthick+5 || mat -> oargs.nfargs > 9 || mat -> oargs.nfargs % 3) objerror(mat, USER, "bad # arguments"); hitFront = (rayIn -> rod > 0); /* Load cal file */ - mf = getfunc(mat, 5, 0x1d, 1); + mf = hasthick ? getfunc(mat, 5, 0x1d, 1) : getfunc(mat, 4, 0xe, 1); /* Get thickness */ - nd.thick = evalue(mf -> ep [0]); - if ((-FTINY <= nd.thick) & (nd.thick <= FTINY)) - nd.thick = .0; + nd.thick = 0; + if (hasthick) { + nd.thick = evalue(mf -> ep [0]); + if ((-FTINY <= nd.thick) & (nd.thick <= FTINY)) + nd.thick = .0; + } /* Get BSDF data */ - nd.sd = loadBSDF(mat -> oargs.sarg [1]); + nd.sd = loadBSDF(mat -> oargs.sarg [hasthick]); /* Extra diffuse reflectance from material def */ if (hitFront) { @@ -1496,9 +1500,9 @@ static int bsdfPhotonScatter (OBJREC *mat, RAY *rayIn) multcolor(nd.tdiff, rayIn -> pcol); /* Get up vector & xform to world coords */ - upvec [0] = evalue(mf -> ep [1]); - upvec [1] = evalue(mf -> ep [2]); - upvec [2] = evalue(mf -> ep [3]); + upvec [0] = evalue(mf -> ep [hasthick+0]); + upvec [1] = evalue(mf -> ep [hasthick+1]); + upvec [2] = evalue(mf -> ep [hasthick+2]); if (mf -> fxp != &unitxf) { multv3(upvec, upvec, mf -> fxp -> xfm); @@ -1703,5 +1707,6 @@ void initPhotonScatterFuncs () photonScatter [TEX_DATA] = pattexPhotonScatter; photonScatter [MOD_ALIAS] = aliasPhotonScatter; - photonScatter [MAT_BSDF] = bsdfPhotonScatter; + photonScatter [MAT_BSDF] = + photonScatter [MAT_SBSDF] = bsdfPhotonScatter; }
