root/radiance/ray/src/rt/pmapmat.c
Mon Feb 22 13:27:49 2021 UTC (3 years, 3 months ago) by rschregle
CVS Tags: HEAD, rad5R4
Changes since 2.23: +63 -41 lines
Diff to previous 2.23 , to selected 2.12
style(mkpmap): revised headers and indentation/linebreaks
Wed Jan 20 19:44:15 2021 UTC (3 years, 4 months ago) by rschregle
Diff to previous 2.22 , to selected 2.12
fix(mkpmap): undefined photon ray dir in brdfPhotonScatter()
Mon Jan 13 17:12:19 2020 UTC (4 years, 4 months ago) by rschregle
Changes since 2.21: +3 -4 lines
Diff to previous 2.21 , to selected 2.12
Minor comments fix
Thu Dec 6 20:00:35 2018 UTC (5 years, 5 months ago) by rschregle
Changes since 2.20: +28 -28 lines
Diff to previous 2.20 , to selected 2.12
Fixed material pointer init bug in normal & aniso photon scattering routines
Thu Dec 6 12:21:38 2018 UTC (5 years, 5 months ago) by rschregle
Changes since 2.19: +138 -114 lines
Diff to previous 2.19 , to selected 2.12
Added rudimentary (diffuse only) photon scattering for *data and *func
Tue Dec 4 21:58:46 2018 UTC (5 years, 5 months ago) by rschregle
Changes since 2.18: +342 -63 lines
Diff to previous 2.18 , to selected 2.12
Added (rudimentary) support for BRTDfunc
Tue Jun 26 14:42:18 2018 UTC (5 years, 11 months ago) by greg
Diff to previous 2.17 , to selected 2.12
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
Mon Jun 25 20:49:10 2018 UTC (5 years, 11 months ago) by greg
Changes since 2.16: +16 -11 lines
Mon Jun 11 12:46:51 2018 UTC (5 years, 11 months ago) by rschregle
Changes since 2.15: +16 -22 lines
Fixed handling of negative BSDF thickness during photon tracing
Tue Mar 20 19:55:33 2018 UTC (6 years, 2 months ago) by rschregle
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Fri Feb 2 19:47:55 2018 UTC (6 years, 3 months ago) by rschregle
Added -lr, -ld options to mkpmap, enabled -api
Tue May 17 17:39:47 2016 UTC (8 years ago) by rschregle
Changes since 2.12: +24 -22 lines
Diff to previous 2.12
Tue Feb 23 12:42:41 2016 UTC (8 years, 3 months ago) by rschregle
Revised PMAP overcounting macros in pmapmat.h, added one in badcomponent()
for overcounted caustics from transferred shadow/ambient rays
Tue Oct 20 15:49:44 2015 UTC (8 years, 7 months ago) by rschregle
Changes since 2.10: +6 -3 lines
Fixed handling of void alias with photon mapping
Tue Sep 29 18:16:34 2015 UTC (8 years, 8 months ago) by rschregle
Changes since 2.9: +40 -7 lines
Improved handling of mixtures and photon ports with photon mapping
Tue Sep 1 16:27:52 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.8: +1 -2 lines
Tue Aug 18 18:45:55 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.7: +4 -1 lines
Wed May 27 17:54:19 2015 UTC (9 years ago) by rschregle
Changes since 2.6: +8 -291 lines
Removed dead code in bsdfPhotonScatter()
Fri May 22 10:27:40 2015 UTC (9 years ago) by greg
Changes since 2.5: +26 -13 lines
Fixed sampling of CFS with detailed geometry
Thu May 21 05:54:54 2015 UTC (9 years ago) by greg
Wed May 20 15:59:44 2015 UTC (9 years ago) by greg
Changes since 2.3: +6 -16 lines
Fixed bug in non-zero texture testing
Fri May 8 13:20:23 2015 UTC (9 years ago) by rschregle
Changes since 2.2: +9 -2 lines
Wed Apr 22 15:50:44 2015 UTC (9 years, 1 month ago) by rschregle
Changes since 2.1: +375 -138 lines
bsdfPhotonScatter() now uses SDsampBSDF() from BSDF library rather than
homebrew sampling code...
Tue Feb 24 19:39:27 2015 UTC (9 years, 3 months ago) by greg
Diff to selected 2.12
