fix: Issue with textured surfaces and source scattering
perf: Minor conditional optimizations
style(mkpmap): revised headers and indentation/linebreaks
fix(mkpmap): undefined photon ray dir in brdfPhotonScatter()
Minor comments fix
Fixed material pointer init bug in normal & aniso photon scattering routines
Added rudimentary (diffuse only) photon scattering for *data and *func
Added (rudimentary) support for BRTDfunc
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
Fixed handling of negative BSDF thickness during photon tracing
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Added -lr, -ld options to mkpmap, enabled -api
Revised PMAP overcounting macros in pmapmat.h, added one in badcomponent() for overcounted caustics from transferred shadow/ambient rays
Fixed handling of void alias with photon mapping
Improved handling of mixtures and photon ports with photon mapping
Removed dead code in bsdfPhotonScatter()
Fixed sampling of CFS with detailed geometry
Fixed bug in non-zero texture testing
bsdfPhotonScatter() now uses SDsampBSDF() from BSDF library rather than homebrew sampling code...
