root/radiance/ray/src/rt/pmapkdt.h
Revision: 1.3
Committed: Tue Sep 17 16:36:05 2024 UTC (7 months, 2 weeks ago) by greg
Changes since 1.2: +8 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
# User Rev Content
1 rschregle 1.1 /*
2     ==================================================================
3     In-core kd-tree for photon map
4
5     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6     (c) Fraunhofer Institute for Solar Energy Systems,
7     (c) Lucerne University of Applied Sciences and Arts,
8     supported by the Swiss National Science Foundation (SNSF, #147053)
9     ==================================================================
10
11 greg 1.3 $Id: pmapkdt.h,v 1.2 2020/04/08 15:14:21 rschregle Exp $
12 rschregle 1.1 */
13
14
15     #ifndef PMAPKDT_H
16     #define PMAPKDT_H
17
18     /* #include <stdio.h>
19     #include "fvect.h" */
20     #include "pmapdata.h"
21
22 greg 1.3 #ifdef __cplusplus
23     extern "C" {
24     #endif
25 rschregle 1.1
26     /* Forward declarations to break dependency loop with pmapdata.h */
27     struct PhotonMap;
28
29     /* k-d tree as linear array of photons */
30     typedef struct {
31     Photon *nodes; /* k-d tree as linear array */
32     } PhotonKdTree;
33
34     typedef PhotonKdTree PhotonStorage;
35     typedef Photon* PhotonIdx;
36
37     /* Priority queue node for kd-tree lookups */
38     typedef struct {
39     PhotonIdx idx; /* Pointer to photon */
40     float dist2; /* Photon's SQUARED distance to query point */
41     } kdT_SearchQueueNode;
42
43     typedef struct {
44     kdT_SearchQueueNode *node;
45     unsigned len, tail;
46     } kdT_SearchQueue;
47
48     typedef kdT_SearchQueueNode PhotonSearchQueueNode;
49     typedef kdT_SearchQueue PhotonSearchQueue;
50
51
52
53     void kdT_Null (PhotonKdTree *kdt);
54     /* Initialise kd-tree prior to storing photons */
55
56     void kdT_BuildPhotonMap (struct PhotonMap *pmap);
57     /* Build a balanced kd-tree pmap -> store from photons in unsorted
58     * heapfile pmap -> heap to guarantee logarithmic search times. The heap
59     * is destroyed on return. */
60
61     int kdT_SavePhotons (const struct PhotonMap *pmap, FILE *out);
62     /* Save photons in kd-tree to file. Return -1 on error, else 0 */
63
64     int kdT_LoadPhotons (struct PhotonMap *pmap, FILE *in);
65     /* Load photons in kd-tree from file. Return -1 on error, else 0 */
66
67     void kdT_InitFindPhotons (struct PhotonMap *pmap);
68     /* Initialise NN search queue prior to calling kdT_FindPhotons() */
69
70 rschregle 1.2 int kdT_FindPhotons (struct PhotonMap* pmap, const FVECT pos,
71     const FVECT norm);
72 rschregle 1.1 /* Locate pmap -> squeue.len nearest photons to pos with similar normal
73     * (NULL for volume photons) and return in search queue pmap -> squeue,
74 rschregle 1.2 * starting with the further photon at pmap -> squeue.node. Return -1
75     * if none found, else 0. */
76 rschregle 1.1
77 rschregle 1.2 int kdT_Find1Photon (struct PhotonMap* pmap, const FVECT pos,
78     const FVECT norm, Photon *photon);
79     /* Locate single nearest photon to pos with similar normal. Return -1
80     * if none found, else 0. */
81 rschregle 1.1
82     int kdT_GetPhoton (const struct PhotonMap *pmap, PhotonIdx idx,
83     Photon *photon);
84 rschregle 1.2 /* Retrieve photon referenced by idx from kd-tree and return -1 on
85     * error, else 0. */
86 rschregle 1.1
87     Photon *kdT_GetNearestPhoton (const PhotonSearchQueue *squeue,
88     PhotonIdx idx);
89     /* Retrieve photon from NN search queue after OOC_FindPhotons() */
90
91     PhotonIdx kdT_FirstPhoton (const struct PhotonMap* pmap);
92     /* Return pointer to first photon in kd-Tree */
93
94     void kdT_Delete (PhotonKdTree *kdt);
95     /* Self-destruct */
96
97 greg 1.3 #ifdef __cplusplus
98     }
99     #endif
100
101 rschregle 1.1 #endif
