root/radiance/ray/src/rt/pmapkdt.h
Revision: 1.2
Committed: Wed Apr 8 15:14:21 2020 UTC (5 years, 2 months ago) by rschregle
CVS Tags: rad5R4, rad5R3
Changes since 1.1: +11 -9 lines
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
# User Rev Content
1 rschregle 1.1 /*
2     ==================================================================
3     In-core kd-tree for photon map
4
5     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6     (c) Fraunhofer Institute for Solar Energy Systems,
7     (c) Lucerne University of Applied Sciences and Arts,
8     supported by the Swiss National Science Foundation (SNSF, #147053)
9     ==================================================================
10
11 rschregle 1.2 $Id: pmapkdt.h,v 1.1 2016/05/18 08:22:45 rschregle Exp $
12 rschregle 1.1 */
13
14
15     #ifndef PMAPKDT_H
16     #define PMAPKDT_H
17
18     /* #include <stdio.h>
19     #include "fvect.h" */
20     #include "pmapdata.h"
21
22
23     /* Forward declarations to break dependency loop with pmapdata.h */
24     struct PhotonMap;
25
26
27     /* k-d tree as linear array of photons */
28     typedef struct {
29     Photon *nodes; /* k-d tree as linear array */
30     } PhotonKdTree;
31
32     typedef PhotonKdTree PhotonStorage;
33     typedef Photon* PhotonIdx;
34
35     /* Priority queue node for kd-tree lookups */
36     typedef struct {
37     PhotonIdx idx; /* Pointer to photon */
38     float dist2; /* Photon's SQUARED distance to query point */
39     } kdT_SearchQueueNode;
40
41     typedef struct {
42     kdT_SearchQueueNode *node;
43     unsigned len, tail;
44     } kdT_SearchQueue;
45
46     typedef kdT_SearchQueueNode PhotonSearchQueueNode;
47     typedef kdT_SearchQueue PhotonSearchQueue;
48
49
50
51     void kdT_Null (PhotonKdTree *kdt);
52     /* Initialise kd-tree prior to storing photons */
53
54     void kdT_BuildPhotonMap (struct PhotonMap *pmap);
55     /* Build a balanced kd-tree pmap -> store from photons in unsorted
56     * heapfile pmap -> heap to guarantee logarithmic search times. The heap
57     * is destroyed on return. */
58
59     int kdT_SavePhotons (const struct PhotonMap *pmap, FILE *out);
60     /* Save photons in kd-tree to file. Return -1 on error, else 0 */
61
62     int kdT_LoadPhotons (struct PhotonMap *pmap, FILE *in);
63     /* Load photons in kd-tree from file. Return -1 on error, else 0 */
64
65     void kdT_InitFindPhotons (struct PhotonMap *pmap);
66     /* Initialise NN search queue prior to calling kdT_FindPhotons() */
67
68 rschregle 1.2 int kdT_FindPhotons (struct PhotonMap* pmap, const FVECT pos,
69     const FVECT norm);
70 rschregle 1.1 /* Locate pmap -> squeue.len nearest photons to pos with similar normal
71     * (NULL for volume photons) and return in search queue pmap -> squeue,
72 rschregle 1.2 * starting with the further photon at pmap -> squeue.node. Return -1
73     * if none found, else 0. */
74 rschregle 1.1
75 rschregle 1.2 int kdT_Find1Photon (struct PhotonMap* pmap, const FVECT pos,
76     const FVECT norm, Photon *photon);
77     /* Locate single nearest photon to pos with similar normal. Return -1
78     * if none found, else 0. */
79 rschregle 1.1
80     int kdT_GetPhoton (const struct PhotonMap *pmap, PhotonIdx idx,
81     Photon *photon);
82 rschregle 1.2 /* Retrieve photon referenced by idx from kd-tree and return -1 on
83     * error, else 0. */
84 rschregle 1.1
85     Photon *kdT_GetNearestPhoton (const PhotonSearchQueue *squeue,
86     PhotonIdx idx);
87     /* Retrieve photon from NN search queue after OOC_FindPhotons() */
88
89     PhotonIdx kdT_FirstPhoton (const struct PhotonMap* pmap);
90     /* Return pointer to first photon in kd-Tree */
91
92     void kdT_Delete (PhotonKdTree *kdt);
93     /* Self-destruct */
94
95     #endif
