| 1 |
rschregle |
1.1 |
| 2 |
| 3 |
In-core kd-tree for photon map
| 4 |
| 5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 6 |
(c) Fraunhofer Institute for Solar Energy Systems,
| 7 |
(c) Lucerne University of Applied Sciences and Arts,
| 8 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 9 |
| 10 |
| 11 |
$Id: pmapkdt.h,v 1.2 2015/11/13 17:31:25 taschreg Exp taschreg $
| 12 |
| 13 |
| 14 |
| 15 |
#ifndef PMAPKDT_H
| 16 |
#define PMAPKDT_H
| 17 |
| 18 |
/* #include <stdio.h>
| 19 |
#include "fvect.h" */
| 20 |
#include "pmapdata.h"
| 21 |
| 22 |
| 23 |
/* Forward declarations to break dependency loop with pmapdata.h */
| 24 |
struct PhotonMap;
| 25 |
| 26 |
| 27 |
/* k-d tree as linear array of photons */
| 28 |
typedef struct {
| 29 |
Photon *nodes; /* k-d tree as linear array */
| 30 |
} PhotonKdTree;
| 31 |
| 32 |
typedef PhotonKdTree PhotonStorage;
| 33 |
typedef Photon* PhotonIdx;
| 34 |
| 35 |
/* Priority queue node for kd-tree lookups */
| 36 |
typedef struct {
| 37 |
PhotonIdx idx; /* Pointer to photon */
| 38 |
float dist2; /* Photon's SQUARED distance to query point */
| 39 |
} kdT_SearchQueueNode;
| 40 |
| 41 |
typedef struct {
| 42 |
kdT_SearchQueueNode *node;
| 43 |
unsigned len, tail;
| 44 |
} kdT_SearchQueue;
| 45 |
| 46 |
typedef kdT_SearchQueueNode PhotonSearchQueueNode;
| 47 |
typedef kdT_SearchQueue PhotonSearchQueue;
| 48 |
| 49 |
| 50 |
| 51 |
void kdT_Null (PhotonKdTree *kdt);
| 52 |
/* Initialise kd-tree prior to storing photons */
| 53 |
| 54 |
void kdT_BuildPhotonMap (struct PhotonMap *pmap);
| 55 |
/* Build a balanced kd-tree pmap -> store from photons in unsorted
| 56 |
* heapfile pmap -> heap to guarantee logarithmic search times. The heap
| 57 |
* is destroyed on return. */
| 58 |
| 59 |
int kdT_SavePhotons (const struct PhotonMap *pmap, FILE *out);
| 60 |
/* Save photons in kd-tree to file. Return -1 on error, else 0 */
| 61 |
| 62 |
int kdT_LoadPhotons (struct PhotonMap *pmap, FILE *in);
| 63 |
/* Load photons in kd-tree from file. Return -1 on error, else 0 */
| 64 |
| 65 |
void kdT_InitFindPhotons (struct PhotonMap *pmap);
| 66 |
/* Initialise NN search queue prior to calling kdT_FindPhotons() */
| 67 |
| 68 |
void kdT_FindPhotons (struct PhotonMap* pmap, const FVECT pos,
| 69 |
const FVECT norm);
| 70 |
/* Locate pmap -> squeue.len nearest photons to pos with similar normal
| 71 |
* (NULL for volume photons) and return in search queue pmap -> squeue,
| 72 |
* starting with the further photon at pmap -> squeue.node */
| 73 |
| 74 |
void kdT_Find1Photon (struct PhotonMap* pmap, const FVECT pos,
| 75 |
const FVECT norm, Photon *photon);
| 76 |
/* Locate single nearest photon to pos with similar normal */
| 77 |
| 78 |
int kdT_GetPhoton (const struct PhotonMap *pmap, PhotonIdx idx,
| 79 |
Photon *photon);
| 80 |
/* Retrieve photon referenced by idx from kd-tree and return 0 on
| 81 |
* success, else -1. */
| 82 |
| 83 |
Photon *kdT_GetNearestPhoton (const PhotonSearchQueue *squeue,
| 84 |
PhotonIdx idx);
| 85 |
/* Retrieve photon from NN search queue after OOC_FindPhotons() */
| 86 |
| 87 |
PhotonIdx kdT_FirstPhoton (const struct PhotonMap* pmap);
| 88 |
/* Return pointer to first photon in kd-Tree */
| 89 |
| 90 |
void kdT_Delete (PhotonKdTree *kdt);
| 91 |
/* Self-destruct */
| 92 |
| 93 |
#endif
