root/radiance/ray/src/rt/pmapkdt.c
Revision: 1.6
Committed: Wed Apr 8 15:14:21 2020 UTC (5 years ago) by rschregle
CVS Tags: rad5R4, rad5R3, HEAD
Changes since 1.5: +18 -8 lines
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
# User Rev Content
1 rschregle 1.1 /*
2 rschregle 1.2 ======================================================================
3 rschregle 1.1 In-core kd-tree for photon map
4
5     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6     (c) Fraunhofer Institute for Solar Energy Systems,
7     (c) Lucerne University of Applied Sciences and Arts,
8 rschregle 1.2 supported by the Swiss National Science Foundation (SNSF, #147053)
9     ======================================================================
10 rschregle 1.1
11 rschregle 1.6 $Id: pmapkdt.c,v 1.5 2018/11/08 00:54:07 greg Exp $
12 rschregle 1.1 */
13
14
15 rschregle 1.2
16 rschregle 1.1 #include "pmapdata.h" /* Includes pmapkdt.h */
17     #include "source.h"
18 greg 1.5 #include "otspecial.h"
19     #include "random.h"
20 rschregle 1.1
21
22
23
24     void kdT_Null (PhotonKdTree *kdt)
25     {
26     kdt -> nodes = NULL;
27     }
28
29
30
31     static unsigned long kdT_MedianPartition (const Photon *heap,
32     unsigned long *heapIdx,
33     unsigned long *heapXdi,
34     unsigned long left,
35     unsigned long right, unsigned dim)
36     /* Returns index to median in heap from indices left to right
37     (inclusive) in dimension dim. The heap is partitioned relative to
38     median using a quicksort algorithm. The heap indices in heapIdx are
39     sorted rather than the heap itself. */
40     {
41     const float *p;
42     unsigned long l, r, lg2, n2, m, n = right - left + 1;
43     unsigned d;
44
45     /* Round down n to nearest power of 2 */
46     for (lg2 = 0, n2 = n; n2 > 1; n2 >>= 1, ++lg2);
47     n2 = 1 << lg2;
48
49     /* Determine median position; this takes into account the fact that
50     only the last level in the heap can be partially empty, and that
51     it fills from left to right */
52     m = left + ((n - n2) > (n2 >> 1) - 1 ? n2 - 1 : n - (n2 >> 1));
53
54     while (right > left) {
55     /* Pivot node */
56     p = heap [heapIdx [right]].pos;
57     l = left;
58     r = right - 1;
59
60     /* l & r converge, swapping elements out of order with respect to
61     pivot node. Identical keys are resolved by cycling through
62     dim. The convergence point is then the pivot's position. */
63     do {
64     while (l <= r) {
65     d = dim;
66
67     while (heap [heapIdx [l]].pos [d] == p [d]) {
68     d = (d + 1) % 3;
69
70     if (d == dim) {
71     /* Ignore dupes? */
72     error(WARNING, "duplicate keys in photon heap");
73     l++;
74     break;
75     }
76     }
77
78     if (heap [heapIdx [l]].pos [d] < p [d])
79     l++;
80     else break;
81     }
82
83     while (r > l) {
84     d = dim;
85
86     while (heap [heapIdx [r]].pos [d] == p [d]) {
87     d = (d + 1) % 3;
88
89     if (d == dim) {
90     /* Ignore dupes? */
91     error(WARNING, "duplicate keys in photon heap");
92     r--;
93     break;
94     }
95     }
96
97     if (heap [heapIdx [r]].pos [d] > p [d])
98     r--;
99     else break;
100     }
101
102     /* Swap indices (not the nodes they point to) */
103     n2 = heapIdx [l];
104     heapIdx [l] = heapIdx [r];
105     heapIdx [r] = n2;
106     /* Update reverse indices */
107     heapXdi [heapIdx [l]] = l;
108     heapXdi [n2] = r;
109     } while (l < r);
110
111     /* Swap indices of convergence and pivot nodes */
112     heapIdx [r] = heapIdx [l];
113     heapIdx [l] = heapIdx [right];
114     heapIdx [right] = n2;
115     /* Update reverse indices */
116     heapXdi [heapIdx [r]] = r;
117     heapXdi [heapIdx [l]] = l;
118     heapXdi [n2] = right;
119
120     if (l >= m)
121     right = l - 1;
122     if (l <= m)
123     left = l + 1;
124     }
125
126     /* Once left & right have converged at m, we have found the median */
127     return m;
128     }
129
130
131
132     static void kdT_Build (Photon *heap, unsigned long *heapIdx,
133     unsigned long *heapXdi, const float min [3],
134     const float max [3], unsigned long left,
135     unsigned long right, unsigned long root)
136     /* Recursive part of balancePhotons(..). Builds heap from subarray
137     defined by indices left and right. min and max are the minimum resp.
138     maximum photon positions in the array. root is the index of the
139     current subtree's root, which corresponds to the median's 1-based
140     index in the heap. heapIdx are the balanced heap indices. The heap
141     is accessed indirectly through these. heapXdi are the reverse indices
142     from the heap to heapIdx so that heapXdi [heapIdx [i]] = i. */
143     {
144     float maxLeft [3], minRight [3];
145     Photon rootNode;
146     unsigned d;
147
148     /* Choose median for dimension with largest spread and partition
149     accordingly */
150     const float d0 = max [0] - min [0],
151     d1 = max [1] - min [1],
152     d2 = max [2] - min [2];
153     const unsigned char dim = d0 > d1 ? d0 > d2 ? 0 : 2
154     : d1 > d2 ? 1 : 2;
155     const unsigned long median = left == right
156     ? left
157     : kdT_MedianPartition(heap, heapIdx, heapXdi,
158     left, right, dim);
159
160     /* Place median at root of current subtree. This consists of swapping
161     the median and the root nodes and updating the heap indices */
162     memcpy(&rootNode, heap + heapIdx [median], sizeof(Photon));
163     memcpy(heap + heapIdx [median], heap + root - 1, sizeof(Photon));
164     rootNode.discr = dim;
165     memcpy(heap + root - 1, &rootNode, sizeof(Photon));
166     heapIdx [heapXdi [root - 1]] = heapIdx [median];
167     heapXdi [heapIdx [median]] = heapXdi [root - 1];
168     heapIdx [median] = root - 1;
169     heapXdi [root - 1] = median;
170
171     /* Update bounds for left and right subtrees and recurse on them */
172     for (d = 0; d <= 2; d++)
173     if (d == dim)
174     maxLeft [d] = minRight [d] = rootNode.pos [d];
175     else {
176     maxLeft [d] = max [d];
177     minRight [d] = min [d];
178     }
179
180     if (left < median)
181     kdT_Build(heap, heapIdx, heapXdi, min, maxLeft, left, median - 1,
182     root << 1);
183
184     if (right > median)
185     kdT_Build(heap, heapIdx, heapXdi, minRight, max, median + 1, right,
186     (root << 1) + 1);
187     }
188
189
190
191     void kdT_BuildPhotonMap (struct PhotonMap *pmap)
192     {
193     Photon *nodes;
194     unsigned long i;
195     unsigned long *heapIdx, /* Photon index array */
196     *heapXdi; /* Reverse index to heapIdx */
197
198     /* Allocate kd-tree nodes and load photons from heap file */
199     if (!(nodes = calloc(pmap -> numPhotons, sizeof(Photon))))
200     error(SYSTEM, "failed in-core heap allocation in kdT_BuildPhotonMap");
201
202     rewind(pmap -> heap);
203 rschregle 1.2 i = fread(nodes, sizeof(Photon), pmap -> numPhotons, pmap -> heap);
204     if (i !=
205 rschregle 1.1 pmap -> numPhotons)
206     error(SYSTEM, "failed loading photon heap in kdT_BuildPhotonMap");
207
208     pmap -> store.nodes = nodes;
209     heapIdx = calloc(pmap -> numPhotons, sizeof(unsigned long));
210     heapXdi = calloc(pmap -> numPhotons, sizeof(unsigned long));
211     if (!heapIdx || !heapXdi)
212     error(SYSTEM, "failed heap index allocation in kdT_BuildPhotonMap");
213
214     /* Initialize index arrays */
215     for (i = 0; i < pmap -> numPhotons; i++)
216     heapXdi [i] = heapIdx [i] = i;
217
218     /* Build kd-tree */
219     kdT_Build(nodes, heapIdx, heapXdi, pmap -> minPos, pmap -> maxPos, 0,
220     pmap -> numPhotons - 1, 1);
221
222     /* Cleanup */
223     free(heapIdx);
224     free(heapXdi);
225     }
226
227
228
229     int kdT_SavePhotons (const struct PhotonMap *pmap, FILE *out)
230     {
231     unsigned long i, j;
232     Photon *p = (Photon*)pmap -> store.nodes;
233
234     for (i = 0; i < pmap -> numPhotons; i++, p++) {
235     /* Write photon attributes */
236     for (j = 0; j < 3; j++)
237     putflt(p -> pos [j], out);
238
239     /* Bytewise dump otherwise we have portability probs */
240     for (j = 0; j < 3; j++)
241     putint(p -> norm [j], 1, out);
242
243     #ifdef PMAP_FLOAT_FLUX
244     for (j = 0; j < 3; j++)
245     putflt(p -> flux [j], out);
246     #else
247     for (j = 0; j < 4; j++)
248     putint(p -> flux [j], 1, out);
249     #endif
250
251     putint(p -> primary, sizeof(p -> primary), out);
252     putint(p -> flags, 1, out);
253
254     if (ferror(out))
255     return -1;
256     }
257
258     return 0;
259     }
260
261
262
263     int kdT_LoadPhotons (struct PhotonMap *pmap, FILE *in)
264     {
265     unsigned long i, j;
266     Photon *p;
267
268     /* Allocate kd-tree based on initialised pmap -> numPhotons */
269     pmap -> store.nodes = calloc(sizeof(Photon), pmap -> numPhotons);
270     if (!pmap -> store.nodes)
271     error(SYSTEM, "failed kd-tree allocation in kdT_LoadPhotons");
272
273     /* Get photon attributes */
274     for (i = 0, p = pmap -> store.nodes; i < pmap -> numPhotons; i++, p++) {
275     for (j = 0; j < 3; j++)
276     p -> pos [j] = getflt(in);
277
278     /* Bytewise grab otherwise we have portability probs */
279     for (j = 0; j < 3; j++)
280     p -> norm [j] = getint(1, in);
281
282     #ifdef PMAP_FLOAT_FLUX
283     for (j = 0; j < 3; j++)
284     p -> flux [j] = getflt(in);
285     #else
286     for (j = 0; j < 4; j++)
287     p -> flux [j] = getint(1, in);
288     #endif
289
290     p -> primary = getint(sizeof(p -> primary), in);
291     p -> flags = getint(1, in);
292
293     if (feof(in))
294     return -1;
295     }
296
297     return 0;
298     }
299
300
301
302     void kdT_InitFindPhotons (struct PhotonMap *pmap)
303     {
304     pmap -> squeue.len = pmap -> maxGather + 1;
305     pmap -> squeue.node = calloc(pmap -> squeue.len,
306     sizeof(PhotonSearchQueueNode));
307     if (!pmap -> squeue.node)
308     error(SYSTEM, "can't allocate photon search queue");
309     }
310
311
312
313     static void kdT_FindNearest (PhotonMap *pmap, const float pos [3],
314     const float norm [3], unsigned long node)
315     /* Recursive part of kdT_FindPhotons(). Locate pmap -> squeue.len nearest
316     * neighbours to pos with similar normal and return in search queue starting
317     * at pmap -> squeue.node. Note that all heap and queue indices are
318     * 1-based, but accesses to the arrays are 0-based! */
319     {
320     Photon *p = (Photon*)pmap -> store.nodes + node - 1;
321     unsigned i, j;
322     /* Signed distance to current photon's splitting plane */
323     float d = pos [p -> discr] - p -> pos [p -> discr],
324     d2 = d * d, dv [3];
325     PhotonSearchQueueNode* sq = pmap -> squeue.node;
326     const unsigned sqSize = pmap -> squeue.len;
327
328     /* Search subtree closer to pos first; exclude other subtree if the
329     distance to the splitting plane is greater than maxDist */
330     if (d < 0) {
331     if (node << 1 <= pmap -> numPhotons)
332     kdT_FindNearest(pmap, pos, norm, node << 1);
333
334     if (d2 < pmap -> maxDist2 && node << 1 < pmap -> numPhotons)
335     kdT_FindNearest(pmap, pos, norm, (node << 1) + 1);
336     }
337     else {
338     if (node << 1 < pmap -> numPhotons)
339     kdT_FindNearest(pmap, pos, norm, (node << 1) + 1);
340
341     if (d2 < pmap -> maxDist2 && node << 1 <= pmap -> numPhotons)
342     kdT_FindNearest(pmap, pos, norm, node << 1);
343     }
344
345     /* Reject photon if normal faces away (ignored for volume photons) with
346     * tolerance to account for perturbation; note photon normal is coded
347     * in range [-127,127], hence we factor this in */
348     if (norm && DOT(norm, p -> norm) <= PMAP_NORM_TOL * 127 * frandom())
349     return;
350
351 rschregle 1.3 if (isContribPmap(pmap)) {
352     /* Lookup in contribution photon map; filter according to emitting
353     * light source if contrib list set, else accept all */
354
355     if (pmap -> srcContrib) {
356     OBJREC *srcMod;
357     const int srcIdx = photonSrcIdx(pmap, p);
358
359     if (srcIdx < 0 || srcIdx >= nsources)
360     error(INTERNAL, "invalid light source index in photon map");
361
362     srcMod = findmaterial(source [srcIdx].so);
363
364     /* Reject photon if contributions from light source which emitted it
365     * are not sought */
366     if (!lu_find(pmap -> srcContrib, srcMod -> oname) -> data)
367     return;
368     }
369 rschregle 1.1
370     /* Reject non-caustic photon if lookup for caustic contribs */
371     if (pmap -> lookupCaustic & !p -> caustic)
372     return;
373     }
374
375     /* Squared distance to current photon (note dist2() requires doubles) */
376     VSUB(dv, pos, p -> pos);
377     d2 = DOT(dv, dv);
378
379     /* Accept photon if closer than current max dist & add to priority queue */
380     if (d2 < pmap -> maxDist2) {
381     if (pmap -> squeue.tail < sqSize) {
382     /* Priority queue not full; append photon and restore heap */
383     i = ++pmap -> squeue.tail;
384
385     while (i > 1 && sq [(i >> 1) - 1].dist2 <= d2) {
386     sq [i - 1].idx = sq [(i >> 1) - 1].idx;
387     sq [i - 1].dist2 = sq [(i >> 1) - 1].dist2;
388     i >>= 1;
389     }
390
391     sq [--i].idx = (PhotonIdx)p;
392     sq [i].dist2 = d2;
393     /* Update maxDist if we've just filled the queue */
394     if (pmap -> squeue.tail >= pmap -> squeue.len)
395     pmap -> maxDist2 = sq [0].dist2;
396     }
397     else {
398     /* Priority queue full; replace maximum, restore heap, and
399     update maxDist */
400     i = 1;
401
402     while (i <= sqSize >> 1) {
403     j = i << 1;
404     if (j < sqSize && sq [j - 1].dist2 < sq [j].dist2)
405     j++;
406     if (d2 >= sq [j - 1].dist2)
407     break;
408     sq [i - 1].idx = sq [j - 1].idx;
409     sq [i - 1].dist2 = sq [j - 1].dist2;
410     i = j;
411     }
412
413     sq [--i].idx = (PhotonIdx)p;
414     sq [i].dist2 = d2;
415     pmap -> maxDist2 = sq [0].dist2;
416     }
417     }
418     }
419
420
421
422 rschregle 1.6 int kdT_FindPhotons (struct PhotonMap *pmap, const FVECT pos,
423     const FVECT norm)
424 rschregle 1.1 {
425     float p [3], n [3];
426
427     /* Photon pos & normal stored at lower precision */
428     VCOPY(p, pos);
429 rschregle 1.4 if (norm)
430     VCOPY(n, norm);
431     kdT_FindNearest(pmap, p, norm ? n : NULL, 1);
432 rschregle 1.6
433     /* Return success or failure (empty queue => none found) */
434     return pmap -> squeue.tail ? 0 : -1;
435 rschregle 1.1 }
436
437
438
439     static void kdT_Find1Nearest (PhotonMap *pmap, const float pos [3],
440     const float norm [3], Photon **photon,
441     unsigned long node)
442     /* Recursive part of kdT_Find1Photon(). Locate single nearest neighbour to
443     * pos with similar normal. Note that all heap and queue indices are
444     * 1-based, but accesses to the arrays are 0-based! */
445     {
446     Photon *p = (Photon*)pmap -> store.nodes + node - 1;
447     /* Signed distance to current photon's splitting plane */
448     float d = pos [p -> discr] - p -> pos [p -> discr], d2 = d * d,
449     dv [3];
450
451     /* Search subtree closer to pos first; exclude other subtree if the
452     distance to the splitting plane is greater than maxDist */
453     if (d < 0) {
454     if (node << 1 <= pmap -> numPhotons)
455     kdT_Find1Nearest(pmap, pos, norm, photon, node << 1);
456
457     if (d2 < pmap -> maxDist2 && node << 1 < pmap -> numPhotons)
458     kdT_Find1Nearest(pmap, pos, norm, photon, (node << 1) + 1);
459     }
460     else {
461     if (node << 1 < pmap -> numPhotons)
462     kdT_Find1Nearest(pmap, pos, norm, photon, (node << 1) + 1);
463
464     if (d2 < pmap -> maxDist2 && node << 1 <= pmap -> numPhotons)
465     kdT_Find1Nearest(pmap, pos, norm, photon, node << 1);
466     }
467
468     /* Squared distance to current photon */
469     VSUB(dv, pos, p -> pos);
470     d2 = DOT(dv, dv);
471
472     if (d2 < pmap -> maxDist2 &&
473 rschregle 1.4 (!norm || DOT(norm, p -> norm) > PMAP_NORM_TOL * 127 * frandom())) {
474 rschregle 1.1 /* Closest photon so far with similar normal. We allow for tolerance
475     * to account for perturbation in the latter; note the photon normal
476     * is coded in the range [-127,127], hence we factor this in */
477     pmap -> maxDist2 = d2;
478     *photon = p;
479     }
480     }
481
482
483
484 rschregle 1.6 int kdT_Find1Photon (struct PhotonMap *pmap, const FVECT pos,
485     const FVECT norm, Photon *photon)
486 rschregle 1.1 {
487     float p [3], n [3];
488 rschregle 1.6 Photon *pnn = NULL;
489 rschregle 1.1
490     /* Photon pos & normal stored at lower precision */
491     VCOPY(p, pos);
492 rschregle 1.4 if (norm)
493     VCOPY(n, norm);
494 rschregle 1.6 kdT_Find1Nearest(pmap, p, norm ? n : NULL, &pnn, 1);
495     if (!pnn)
496     /* No photon found => failed */
497     return -1;
498     else {
499     /* Copy found photon => successs */
500     memcpy(photon, pnn, sizeof(Photon));
501     return 0;
502     }
503 rschregle 1.1 }
504
505
506
507     int kdT_GetPhoton (const struct PhotonMap *pmap, PhotonIdx idx,
508     Photon *photon)
509     {
510     memcpy(photon, idx, sizeof(Photon));
511     return 0;
512     }
513
514
515
516     Photon *kdT_GetNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx)
517     {
518     return idx;
519     }
520
521
522
523     PhotonIdx kdT_FirstPhoton (const struct PhotonMap* pmap)
524     {
525     return pmap -> store.nodes;
526     }
527
528
529
530     void kdT_Delete (PhotonKdTree *kdt)
531     {
532     free(kdt -> nodes);
533     kdt -> nodes = NULL;
534     }
