| 1 |
| 2 |
| 3 |
In-core kd-tree for photon map |
| 4 |
| 5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
| 6 |
(c) Fraunhofer Institute for Solar Energy Systems, |
| 7 |
(c) Lucerne University of Applied Sciences and Arts, |
| 8 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
| 9 |
| 10 |
| 11 |
$Id: pmapkdt.c,v 1.4 2018/05/31 12:34:16 rschregle Exp $ |
| 12 |
| 13 |
| 14 |
| 15 |
| 16 |
#include "pmapdata.h" /* Includes pmapkdt.h */ |
| 17 |
#include "source.h" |
| 18 |
#include "otspecial.h" |
| 19 |
#include "random.h" |
| 20 |
| 21 |
| 22 |
| 23 |
| 24 |
void kdT_Null (PhotonKdTree *kdt) |
| 25 |
| 26 |
kdt -> nodes = NULL; |
| 27 |
| 28 |
| 29 |
| 30 |
| 31 |
static unsigned long kdT_MedianPartition (const Photon *heap, |
| 32 |
unsigned long *heapIdx, |
| 33 |
unsigned long *heapXdi, |
| 34 |
unsigned long left, |
| 35 |
unsigned long right, unsigned dim) |
| 36 |
/* Returns index to median in heap from indices left to right |
| 37 |
(inclusive) in dimension dim. The heap is partitioned relative to |
| 38 |
median using a quicksort algorithm. The heap indices in heapIdx are |
| 39 |
sorted rather than the heap itself. */ |
| 40 |
| 41 |
const float *p; |
| 42 |
unsigned long l, r, lg2, n2, m, n = right - left + 1; |
| 43 |
unsigned d; |
| 44 |
| 45 |
/* Round down n to nearest power of 2 */ |
| 46 |
for (lg2 = 0, n2 = n; n2 > 1; n2 >>= 1, ++lg2); |
| 47 |
n2 = 1 << lg2; |
| 48 |
| 49 |
/* Determine median position; this takes into account the fact that |
| 50 |
only the last level in the heap can be partially empty, and that |
| 51 |
it fills from left to right */ |
| 52 |
m = left + ((n - n2) > (n2 >> 1) - 1 ? n2 - 1 : n - (n2 >> 1)); |
| 53 |
| 54 |
while (right > left) { |
| 55 |
/* Pivot node */ |
| 56 |
p = heap [heapIdx [right]].pos; |
| 57 |
l = left; |
| 58 |
r = right - 1; |
| 59 |
| 60 |
/* l & r converge, swapping elements out of order with respect to |
| 61 |
pivot node. Identical keys are resolved by cycling through |
| 62 |
dim. The convergence point is then the pivot's position. */ |
| 63 |
do { |
| 64 |
while (l <= r) { |
| 65 |
d = dim; |
| 66 |
| 67 |
while (heap [heapIdx [l]].pos [d] == p [d]) { |
| 68 |
d = (d + 1) % 3; |
| 69 |
| 70 |
if (d == dim) { |
| 71 |
/* Ignore dupes? */ |
| 72 |
error(WARNING, "duplicate keys in photon heap"); |
| 73 |
l++; |
| 74 |
break; |
| 75 |
| 76 |
| 77 |
| 78 |
if (heap [heapIdx [l]].pos [d] < p [d]) |
| 79 |
l++; |
| 80 |
else break; |
| 81 |
| 82 |
| 83 |
while (r > l) { |
| 84 |
d = dim; |
| 85 |
| 86 |
while (heap [heapIdx [r]].pos [d] == p [d]) { |
| 87 |
d = (d + 1) % 3; |
| 88 |
| 89 |
if (d == dim) { |
| 90 |
| 91 |
| 92 |
r--; |
| 93 |
break; |
| 94 |
| 95 |
| 96 |
| 97 |
if (heap [heapIdx [r]].pos [d] > p [d]) |
| 98 |
r--; |
| 99 |
else break; |
| 100 |
| 101 |
| 102 |
/* Swap indices (not the nodes they point to) */ |
| 103 |
n2 = heapIdx [l]; |
| 104 |
heapIdx [l] = heapIdx [r]; |
| 105 |
heapIdx [r] = n2; |
| 106 |
/* Update reverse indices */ |
| 107 |
heapXdi [heapIdx [l]] = l; |
| 108 |
heapXdi [n2] = r; |
| 109 |
} while (l < r); |
| 110 |
| 111 |
/* Swap indices of convergence and pivot nodes */ |
| 112 |
heapIdx [r] = heapIdx [l]; |
| 113 |
heapIdx [l] = heapIdx [right]; |
| 114 |
heapIdx [right] = n2; |
| 115 |
| 116 |
heapXdi [heapIdx [r]] = r; |
| 117 |
| 118 |
heapXdi [n2] = right; |
| 119 |
| 120 |
if (l >= m) |
| 121 |
right = l - 1; |
| 122 |
if (l <= m) |
| 123 |
left = l + 1; |
| 124 |
| 125 |
| 126 |
/* Once left & right have converged at m, we have found the median */ |
| 127 |
return m; |
| 128 |
| 129 |
| 130 |
| 131 |
| 132 |
static void kdT_Build (Photon *heap, unsigned long *heapIdx, |
| 133 |
unsigned long *heapXdi, const float min [3], |
| 134 |
const float max [3], unsigned long left, |
| 135 |
unsigned long right, unsigned long root) |
| 136 |
/* Recursive part of balancePhotons(..). Builds heap from subarray |
| 137 |
defined by indices left and right. min and max are the minimum resp. |
| 138 |
maximum photon positions in the array. root is the index of the |
| 139 |
current subtree's root, which corresponds to the median's 1-based |
| 140 |
index in the heap. heapIdx are the balanced heap indices. The heap |
| 141 |
is accessed indirectly through these. heapXdi are the reverse indices |
| 142 |
from the heap to heapIdx so that heapXdi [heapIdx [i]] = i. */ |
| 143 |
| 144 |
float maxLeft [3], minRight [3]; |
| 145 |
Photon rootNode; |
| 146 |
unsigned d; |
| 147 |
| 148 |
/* Choose median for dimension with largest spread and partition |
| 149 |
accordingly */ |
| 150 |
const float d0 = max [0] - min [0], |
| 151 |
d1 = max [1] - min [1], |
| 152 |
d2 = max [2] - min [2]; |
| 153 |
const unsigned char dim = d0 > d1 ? d0 > d2 ? 0 : 2 |
| 154 |
: d1 > d2 ? 1 : 2; |
| 155 |
const unsigned long median = left == right |
| 156 |
? left |
| 157 |
: kdT_MedianPartition(heap, heapIdx, heapXdi, |
| 158 |
left, right, dim); |
| 159 |
| 160 |
/* Place median at root of current subtree. This consists of swapping |
| 161 |
the median and the root nodes and updating the heap indices */ |
| 162 |
memcpy(&rootNode, heap + heapIdx [median], sizeof(Photon)); |
| 163 |
memcpy(heap + heapIdx [median], heap + root - 1, sizeof(Photon)); |
| 164 |
rootNode.discr = dim; |
| 165 |
memcpy(heap + root - 1, &rootNode, sizeof(Photon)); |
| 166 |
heapIdx [heapXdi [root - 1]] = heapIdx [median]; |
| 167 |
heapXdi [heapIdx [median]] = heapXdi [root - 1]; |
| 168 |
heapIdx [median] = root - 1; |
| 169 |
heapXdi [root - 1] = median; |
| 170 |
| 171 |
/* Update bounds for left and right subtrees and recurse on them */ |
| 172 |
for (d = 0; d <= 2; d++) |
| 173 |
if (d == dim) |
| 174 |
maxLeft [d] = minRight [d] = rootNode.pos [d]; |
| 175 |
else { |
| 176 |
maxLeft [d] = max [d]; |
| 177 |
minRight [d] = min [d]; |
| 178 |
| 179 |
| 180 |
if (left < median) |
| 181 |
kdT_Build(heap, heapIdx, heapXdi, min, maxLeft, left, median - 1, |
| 182 |
root << 1); |
| 183 |
| 184 |
if (right > median) |
| 185 |
kdT_Build(heap, heapIdx, heapXdi, minRight, max, median + 1, right, |
| 186 |
(root << 1) + 1); |
| 187 |
| 188 |
| 189 |
| 190 |
| 191 |
void kdT_BuildPhotonMap (struct PhotonMap *pmap) |
| 192 |
| 193 |
Photon *nodes; |
| 194 |
unsigned long i; |
| 195 |
unsigned long *heapIdx, /* Photon index array */ |
| 196 |
*heapXdi; /* Reverse index to heapIdx */ |
| 197 |
| 198 |
/* Allocate kd-tree nodes and load photons from heap file */ |
| 199 |
if (!(nodes = calloc(pmap -> numPhotons, sizeof(Photon)))) |
| 200 |
error(SYSTEM, "failed in-core heap allocation in kdT_BuildPhotonMap"); |
| 201 |
| 202 |
rewind(pmap -> heap); |
| 203 |
i = fread(nodes, sizeof(Photon), pmap -> numPhotons, pmap -> heap); |
| 204 |
if (i != |
| 205 |
pmap -> numPhotons) |
| 206 |
error(SYSTEM, "failed loading photon heap in kdT_BuildPhotonMap"); |
| 207 |
| 208 |
pmap -> store.nodes = nodes; |
| 209 |
heapIdx = calloc(pmap -> numPhotons, sizeof(unsigned long)); |
| 210 |
heapXdi = calloc(pmap -> numPhotons, sizeof(unsigned long)); |
| 211 |
if (!heapIdx || !heapXdi) |
| 212 |
error(SYSTEM, "failed heap index allocation in kdT_BuildPhotonMap"); |
| 213 |
| 214 |
/* Initialize index arrays */ |
| 215 |
for (i = 0; i < pmap -> numPhotons; i++) |
| 216 |
heapXdi [i] = heapIdx [i] = i; |
| 217 |
| 218 |
/* Build kd-tree */ |
| 219 |
kdT_Build(nodes, heapIdx, heapXdi, pmap -> minPos, pmap -> maxPos, 0, |
| 220 |
pmap -> numPhotons - 1, 1); |
| 221 |
| 222 |
/* Cleanup */ |
| 223 |
free(heapIdx); |
| 224 |
free(heapXdi); |
| 225 |
| 226 |
| 227 |
| 228 |
| 229 |
int kdT_SavePhotons (const struct PhotonMap *pmap, FILE *out) |
| 230 |
| 231 |
unsigned long i, j; |
| 232 |
Photon *p = (Photon*)pmap -> store.nodes; |
| 233 |
| 234 |
for (i = 0; i < pmap -> numPhotons; i++, p++) { |
| 235 |
/* Write photon attributes */ |
| 236 |
for (j = 0; j < 3; j++) |
| 237 |
putflt(p -> pos [j], out); |
| 238 |
| 239 |
/* Bytewise dump otherwise we have portability probs */ |
| 240 |
| 241 |
putint(p -> norm [j], 1, out); |
| 242 |
| 243 |
#ifdef PMAP_FLOAT_FLUX |
| 244 |
| 245 |
putflt(p -> flux [j], out); |
| 246 |
#else |
| 247 |
for (j = 0; j < 4; j++) |
| 248 |
putint(p -> flux [j], 1, out); |
| 249 |
#endif |
| 250 |
| 251 |
putint(p -> primary, sizeof(p -> primary), out); |
| 252 |
putint(p -> flags, 1, out); |
| 253 |
| 254 |
if (ferror(out)) |
| 255 |
return -1; |
| 256 |
| 257 |
| 258 |
return 0; |
| 259 |
| 260 |
| 261 |
| 262 |
| 263 |
int kdT_LoadPhotons (struct PhotonMap *pmap, FILE *in) |
| 264 |
| 265 |
| 266 |
Photon *p; |
| 267 |
| 268 |
/* Allocate kd-tree based on initialised pmap -> numPhotons */ |
| 269 |
pmap -> store.nodes = calloc(sizeof(Photon), pmap -> numPhotons); |
| 270 |
if (!pmap -> store.nodes) |
| 271 |
error(SYSTEM, "failed kd-tree allocation in kdT_LoadPhotons"); |
| 272 |
| 273 |
/* Get photon attributes */ |
| 274 |
for (i = 0, p = pmap -> store.nodes; i < pmap -> numPhotons; i++, p++) { |
| 275 |
| 276 |
p -> pos [j] = getflt(in); |
| 277 |
| 278 |
/* Bytewise grab otherwise we have portability probs */ |
| 279 |
| 280 |
p -> norm [j] = getint(1, in); |
| 281 |
| 282 |
| 283 |
| 284 |
p -> flux [j] = getflt(in); |
| 285 |
#else |
| 286 |
| 287 |
p -> flux [j] = getint(1, in); |
| 288 |
#endif |
| 289 |
| 290 |
p -> primary = getint(sizeof(p -> primary), in); |
| 291 |
p -> flags = getint(1, in); |
| 292 |
| 293 |
if (feof(in)) |
| 294 |
return -1; |
| 295 |
| 296 |
| 297 |
return 0; |
| 298 |
| 299 |
| 300 |
| 301 |
| 302 |
void kdT_InitFindPhotons (struct PhotonMap *pmap) |
| 303 |
| 304 |
pmap -> squeue.len = pmap -> maxGather + 1; |
| 305 |
pmap -> squeue.node = calloc(pmap -> squeue.len, |
| 306 |
sizeof(PhotonSearchQueueNode)); |
| 307 |
if (!pmap -> squeue.node) |
| 308 |
error(SYSTEM, "can't allocate photon search queue"); |
| 309 |
| 310 |
| 311 |
| 312 |
| 313 |
static void kdT_FindNearest (PhotonMap *pmap, const float pos [3], |
| 314 |
const float norm [3], unsigned long node) |
| 315 |
/* Recursive part of kdT_FindPhotons(). Locate pmap -> squeue.len nearest |
| 316 |
* neighbours to pos with similar normal and return in search queue starting |
| 317 |
* at pmap -> squeue.node. Note that all heap and queue indices are |
| 318 |
* 1-based, but accesses to the arrays are 0-based! */ |
| 319 |
| 320 |
Photon *p = (Photon*)pmap -> store.nodes + node - 1; |
| 321 |
unsigned i, j; |
| 322 |
/* Signed distance to current photon's splitting plane */ |
| 323 |
float d = pos [p -> discr] - p -> pos [p -> discr], |
| 324 |
d2 = d * d, dv [3]; |
| 325 |
PhotonSearchQueueNode* sq = pmap -> squeue.node; |
| 326 |
const unsigned sqSize = pmap -> squeue.len; |
| 327 |
| 328 |
/* Search subtree closer to pos first; exclude other subtree if the |
| 329 |
distance to the splitting plane is greater than maxDist */ |
| 330 |
if (d < 0) { |
| 331 |
if (node << 1 <= pmap -> numPhotons) |
| 332 |
kdT_FindNearest(pmap, pos, norm, node << 1); |
| 333 |
| 334 |
if (d2 < pmap -> maxDist2 && node << 1 < pmap -> numPhotons) |
| 335 |
kdT_FindNearest(pmap, pos, norm, (node << 1) + 1); |
| 336 |
| 337 |
else { |
| 338 |
if (node << 1 < pmap -> numPhotons) |
| 339 |
| 340 |
| 341 |
if (d2 < pmap -> maxDist2 && node << 1 <= pmap -> numPhotons) |
| 342 |
| 343 |
| 344 |
| 345 |
/* Reject photon if normal faces away (ignored for volume photons) with |
| 346 |
* tolerance to account for perturbation; note photon normal is coded |
| 347 |
* in range [-127,127], hence we factor this in */ |
| 348 |
if (norm && DOT(norm, p -> norm) <= PMAP_NORM_TOL * 127 * frandom()) |
| 349 |
return; |
| 350 |
| 351 |
if (isContribPmap(pmap)) { |
| 352 |
/* Lookup in contribution photon map; filter according to emitting |
| 353 |
* light source if contrib list set, else accept all */ |
| 354 |
| 355 |
if (pmap -> srcContrib) { |
| 356 |
OBJREC *srcMod; |
| 357 |
const int srcIdx = photonSrcIdx(pmap, p); |
| 358 |
| 359 |
if (srcIdx < 0 || srcIdx >= nsources) |
| 360 |
error(INTERNAL, "invalid light source index in photon map"); |
| 361 |
| 362 |
srcMod = findmaterial(source [srcIdx].so); |
| 363 |
| 364 |
/* Reject photon if contributions from light source which emitted it |
| 365 |
* are not sought */ |
| 366 |
if (!lu_find(pmap -> srcContrib, srcMod -> oname) -> data) |
| 367 |
return; |
| 368 |
| 369 |
| 370 |
/* Reject non-caustic photon if lookup for caustic contribs */ |
| 371 |
if (pmap -> lookupCaustic & !p -> caustic) |
| 372 |
return; |
| 373 |
| 374 |
| 375 |
/* Squared distance to current photon (note dist2() requires doubles) */ |
| 376 |
VSUB(dv, pos, p -> pos); |
| 377 |
d2 = DOT(dv, dv); |
| 378 |
| 379 |
/* Accept photon if closer than current max dist & add to priority queue */ |
| 380 |
if (d2 < pmap -> maxDist2) { |
| 381 |
if (pmap -> squeue.tail < sqSize) { |
| 382 |
/* Priority queue not full; append photon and restore heap */ |
| 383 |
i = ++pmap -> squeue.tail; |
| 384 |
| 385 |
while (i > 1 && sq [(i >> 1) - 1].dist2 <= d2) { |
| 386 |
sq [i - 1].idx = sq [(i >> 1) - 1].idx; |
| 387 |
sq [i - 1].dist2 = sq [(i >> 1) - 1].dist2; |
| 388 |
i >>= 1; |
| 389 |
| 390 |
| 391 |
sq [--i].idx = (PhotonIdx)p; |
| 392 |
sq [i].dist2 = d2; |
| 393 |
/* Update maxDist if we've just filled the queue */ |
| 394 |
if (pmap -> squeue.tail >= pmap -> squeue.len) |
| 395 |
pmap -> maxDist2 = sq [0].dist2; |
| 396 |
| 397 |
else { |
| 398 |
/* Priority queue full; replace maximum, restore heap, and |
| 399 |
update maxDist */ |
| 400 |
i = 1; |
| 401 |
| 402 |
while (i <= sqSize >> 1) { |
| 403 |
j = i << 1; |
| 404 |
if (j < sqSize && sq [j - 1].dist2 < sq [j].dist2) |
| 405 |
j++; |
| 406 |
if (d2 >= sq [j - 1].dist2) |
| 407 |
break; |
| 408 |
sq [i - 1].idx = sq [j - 1].idx; |
| 409 |
sq [i - 1].dist2 = sq [j - 1].dist2; |
| 410 |
i = j; |
| 411 |
| 412 |
| 413 |
| 414 |
| 415 |
| 416 |
| 417 |
| 418 |
| 419 |
| 420 |
| 421 |
| 422 |
void kdT_FindPhotons (struct PhotonMap *pmap, const FVECT pos, |
| 423 |
const FVECT norm) |
| 424 |
| 425 |
float p [3], n [3]; |
| 426 |
| 427 |
/* Photon pos & normal stored at lower precision */ |
| 428 |
VCOPY(p, pos); |
| 429 |
if (norm) |
| 430 |
VCOPY(n, norm); |
| 431 |
kdT_FindNearest(pmap, p, norm ? n : NULL, 1); |
| 432 |
| 433 |
| 434 |
| 435 |
| 436 |
static void kdT_Find1Nearest (PhotonMap *pmap, const float pos [3], |
| 437 |
const float norm [3], Photon **photon, |
| 438 |
| 439 |
/* Recursive part of kdT_Find1Photon(). Locate single nearest neighbour to |
| 440 |
* pos with similar normal. Note that all heap and queue indices are |
| 441 |
| 442 |
| 443 |
| 444 |
| 445 |
float d = pos [p -> discr] - p -> pos [p -> discr], d2 = d * d, |
| 446 |
dv [3]; |
| 447 |
| 448 |
| 449 |
| 450 |
if (d < 0) { |
| 451 |
| 452 |
kdT_Find1Nearest(pmap, pos, norm, photon, node << 1); |
| 453 |
| 454 |
| 455 |
kdT_Find1Nearest(pmap, pos, norm, photon, (node << 1) + 1); |
| 456 |
| 457 |
else { |
| 458 |
| 459 |
| 460 |
| 461 |
| 462 |
| 463 |
| 464 |
| 465 |
/* Squared distance to current photon */ |
| 466 |
| 467 |
d2 = DOT(dv, dv); |
| 468 |
| 469 |
if (d2 < pmap -> maxDist2 && |
| 470 |
(!norm || DOT(norm, p -> norm) > PMAP_NORM_TOL * 127 * frandom())) { |
| 471 |
/* Closest photon so far with similar normal. We allow for tolerance |
| 472 |
* to account for perturbation in the latter; note the photon normal |
| 473 |
* is coded in the range [-127,127], hence we factor this in */ |
| 474 |
pmap -> maxDist2 = d2; |
| 475 |
*photon = p; |
| 476 |
| 477 |
| 478 |
| 479 |
| 480 |
| 481 |
void kdT_Find1Photon (struct PhotonMap *pmap, const FVECT pos, |
| 482 |
const FVECT norm, Photon *photon) |
| 483 |
| 484 |
| 485 |
Photon *pnn; |
| 486 |
| 487 |
| 488 |
VCOPY(p, pos); |
| 489 |
if (norm) |
| 490 |
VCOPY(n, norm); |
| 491 |
kdT_Find1Nearest(pmap, p, norm ? n : NULL, &pnn, 1); |
| 492 |
memcpy(photon, pnn, sizeof(Photon)); |
| 493 |
| 494 |
| 495 |
| 496 |
| 497 |
int kdT_GetPhoton (const struct PhotonMap *pmap, PhotonIdx idx, |
| 498 |
Photon *photon) |
| 499 |
| 500 |
memcpy(photon, idx, sizeof(Photon)); |
| 501 |
return 0; |
| 502 |
| 503 |
| 504 |
| 505 |
| 506 |
Photon *kdT_GetNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx) |
| 507 |
| 508 |
return idx; |
| 509 |
| 510 |
| 511 |
| 512 |
| 513 |
PhotonIdx kdT_FirstPhoton (const struct PhotonMap* pmap) |
| 514 |
| 515 |
return pmap -> store.nodes; |
| 516 |
| 517 |
| 518 |
| 519 |
| 520 |
void kdT_Delete (PhotonKdTree *kdt) |
| 521 |
| 522 |
free(kdt -> nodes); |
| 523 |
| 524 |
