root/Development/ray/src/rt/pmapkdt.c
Wed Apr 8 15:14:21 2020 UTC (5 years, 7 months ago) by rschregle
CVS Tags: HEAD, rad5R3, rad5R4, rad6R0
Changes since 1.5: +18 -8 lines
Diff to previous 1.5
Fixed est00pid bug in single photon lookups that returned junk when none found, added code to detect and handle (ignore).
Thu Nov 8 00:54:07 2018 UTC (7 years ago) by greg
Changes since 1.4: +3 -1 lines
Diff to previous 1.4
Thu May 31 12:34:16 2018 UTC (7 years, 5 months ago) by rschregle
Changes since 1.3: +8 -6 lines
Diff to previous 1.3
Fixed volume photon lookup bug (dereferenced NULL normal)
Wed Jan 24 19:39:05 2018 UTC (7 years, 9 months ago) by rschregle
Changes since 1.2: +19 -15 lines
Diff to previous 1.2
Hack to render contrib pmap as regular global pmap with rpict/rtrace/rvu
Mon Aug 14 21:12:10 2017 UTC (8 years, 2 months ago) by rschregle
Changes since 1.1: +7 -9 lines
Diff to previous 1.1
Updated photon map code for Windows; no multproc or ooC for now
Wed May 18 08:22:45 2016 UTC (9 years, 5 months ago) by rschregle
Added missing sources of iC and ooC pmap
