root/radiance/ray/src/rt/pmapkdt.c
Revision: 1.2
Committed: Mon Aug 14 21:12:10 2017 UTC (7 years, 10 months ago) by rschregle
Changes since 1.1: +7 -9 lines
Updated photon map code for Windows; no multproc or ooC for now
# User Rev Content
1 rschregle 1.1 /*
2 rschregle 1.2 ======================================================================
3 rschregle 1.1 In-core kd-tree for photon map
4
5     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6     (c) Fraunhofer Institute for Solar Energy Systems,
7     (c) Lucerne University of Applied Sciences and Arts,
8 rschregle 1.2 supported by the Swiss National Science Foundation (SNSF, #147053)
9     ======================================================================
10 rschregle 1.1
11 rschregle 1.2 $Id: pmapkdt.c,v 1.1 2016/05/18 08:22:45 rschregle Exp $
12 rschregle 1.1 */
13
14
15 rschregle 1.2
16 rschregle 1.1 #include "pmapdata.h" /* Includes pmapkdt.h */
17     #include "source.h"
18
19
20
21
22     void kdT_Null (PhotonKdTree *kdt)
23     {
24     kdt -> nodes = NULL;
25     }
26
27
28
29     static unsigned long kdT_MedianPartition (const Photon *heap,
30     unsigned long *heapIdx,
31     unsigned long *heapXdi,
32     unsigned long left,
33     unsigned long right, unsigned dim)
34     /* Returns index to median in heap from indices left to right
35     (inclusive) in dimension dim. The heap is partitioned relative to
36     median using a quicksort algorithm. The heap indices in heapIdx are
37     sorted rather than the heap itself. */
38     {
39     const float *p;
40     unsigned long l, r, lg2, n2, m, n = right - left + 1;
41     unsigned d;
42
43     /* Round down n to nearest power of 2 */
44     for (lg2 = 0, n2 = n; n2 > 1; n2 >>= 1, ++lg2);
45     n2 = 1 << lg2;
46
47     /* Determine median position; this takes into account the fact that
48     only the last level in the heap can be partially empty, and that
49     it fills from left to right */
50     m = left + ((n - n2) > (n2 >> 1) - 1 ? n2 - 1 : n - (n2 >> 1));
51
52     while (right > left) {
53     /* Pivot node */
54     p = heap [heapIdx [right]].pos;
55     l = left;
56     r = right - 1;
57
58     /* l & r converge, swapping elements out of order with respect to
59     pivot node. Identical keys are resolved by cycling through
60     dim. The convergence point is then the pivot's position. */
61     do {
62     while (l <= r) {
63     d = dim;
64
65     while (heap [heapIdx [l]].pos [d] == p [d]) {
66     d = (d + 1) % 3;
67
68     if (d == dim) {
69     /* Ignore dupes? */
70     error(WARNING, "duplicate keys in photon heap");
71     l++;
72     break;
73     }
74     }
75
76     if (heap [heapIdx [l]].pos [d] < p [d])
77     l++;
78     else break;
79     }
80
81     while (r > l) {
82     d = dim;
83
84     while (heap [heapIdx [r]].pos [d] == p [d]) {
85     d = (d + 1) % 3;
86
87     if (d == dim) {
88     /* Ignore dupes? */
89     error(WARNING, "duplicate keys in photon heap");
90     r--;
91     break;
92     }
93     }
94
95     if (heap [heapIdx [r]].pos [d] > p [d])
96     r--;
97     else break;
98     }
99
100     /* Swap indices (not the nodes they point to) */
101     n2 = heapIdx [l];
102     heapIdx [l] = heapIdx [r];
103     heapIdx [r] = n2;
104     /* Update reverse indices */
105     heapXdi [heapIdx [l]] = l;
106     heapXdi [n2] = r;
107     } while (l < r);
108
109     /* Swap indices of convergence and pivot nodes */
110     heapIdx [r] = heapIdx [l];
111     heapIdx [l] = heapIdx [right];
112     heapIdx [right] = n2;
113     /* Update reverse indices */
114     heapXdi [heapIdx [r]] = r;
115     heapXdi [heapIdx [l]] = l;
116     heapXdi [n2] = right;
117
118     if (l >= m)
119     right = l - 1;
120     if (l <= m)
121     left = l + 1;
122     }
123
124     /* Once left & right have converged at m, we have found the median */
125     return m;
126     }
127
128
129
130     static void kdT_Build (Photon *heap, unsigned long *heapIdx,
131     unsigned long *heapXdi, const float min [3],
132     const float max [3], unsigned long left,
133     unsigned long right, unsigned long root)
134     /* Recursive part of balancePhotons(..). Builds heap from subarray
135     defined by indices left and right. min and max are the minimum resp.
136     maximum photon positions in the array. root is the index of the
137     current subtree's root, which corresponds to the median's 1-based
138     index in the heap. heapIdx are the balanced heap indices. The heap
139     is accessed indirectly through these. heapXdi are the reverse indices
140     from the heap to heapIdx so that heapXdi [heapIdx [i]] = i. */
141     {
142     float maxLeft [3], minRight [3];
143     Photon rootNode;
144     unsigned d;
145
146     /* Choose median for dimension with largest spread and partition
147     accordingly */
148     const float d0 = max [0] - min [0],
149     d1 = max [1] - min [1],
150     d2 = max [2] - min [2];
151     const unsigned char dim = d0 > d1 ? d0 > d2 ? 0 : 2
152     : d1 > d2 ? 1 : 2;
153     const unsigned long median = left == right
154     ? left
155     : kdT_MedianPartition(heap, heapIdx, heapXdi,
156     left, right, dim);
157
158     /* Place median at root of current subtree. This consists of swapping
159     the median and the root nodes and updating the heap indices */
160     memcpy(&rootNode, heap + heapIdx [median], sizeof(Photon));
161     memcpy(heap + heapIdx [median], heap + root - 1, sizeof(Photon));
162     rootNode.discr = dim;
163     memcpy(heap + root - 1, &rootNode, sizeof(Photon));
164     heapIdx [heapXdi [root - 1]] = heapIdx [median];
165     heapXdi [heapIdx [median]] = heapXdi [root - 1];
166     heapIdx [median] = root - 1;
167     heapXdi [root - 1] = median;
168
169     /* Update bounds for left and right subtrees and recurse on them */
170     for (d = 0; d <= 2; d++)
171     if (d == dim)
172     maxLeft [d] = minRight [d] = rootNode.pos [d];
173     else {
174     maxLeft [d] = max [d];
175     minRight [d] = min [d];
176     }
177
178     if (left < median)
179     kdT_Build(heap, heapIdx, heapXdi, min, maxLeft, left, median - 1,
180     root << 1);
181
182     if (right > median)
183     kdT_Build(heap, heapIdx, heapXdi, minRight, max, median + 1, right,
184     (root << 1) + 1);
185     }
186
187
188
189     void kdT_BuildPhotonMap (struct PhotonMap *pmap)
190     {
191     Photon *nodes;
192     unsigned long i;
193     unsigned long *heapIdx, /* Photon index array */
194     *heapXdi; /* Reverse index to heapIdx */
195
196     /* Allocate kd-tree nodes and load photons from heap file */
197     if (!(nodes = calloc(pmap -> numPhotons, sizeof(Photon))))
198     error(SYSTEM, "failed in-core heap allocation in kdT_BuildPhotonMap");
199
200     rewind(pmap -> heap);
201 rschregle 1.2 i = fread(nodes, sizeof(Photon), pmap -> numPhotons, pmap -> heap);
202     if (i !=
203 rschregle 1.1 pmap -> numPhotons)
204     error(SYSTEM, "failed loading photon heap in kdT_BuildPhotonMap");
205
206     pmap -> store.nodes = nodes;
207     heapIdx = calloc(pmap -> numPhotons, sizeof(unsigned long));
208     heapXdi = calloc(pmap -> numPhotons, sizeof(unsigned long));
209     if (!heapIdx || !heapXdi)
210     error(SYSTEM, "failed heap index allocation in kdT_BuildPhotonMap");
211
212     /* Initialize index arrays */
213     for (i = 0; i < pmap -> numPhotons; i++)
214     heapXdi [i] = heapIdx [i] = i;
215
216     /* Build kd-tree */
217     kdT_Build(nodes, heapIdx, heapXdi, pmap -> minPos, pmap -> maxPos, 0,
218     pmap -> numPhotons - 1, 1);
219
220     /* Cleanup */
221     free(heapIdx);
222     free(heapXdi);
223     }
224
225
226
227     int kdT_SavePhotons (const struct PhotonMap *pmap, FILE *out)
228     {
229     unsigned long i, j;
230     Photon *p = (Photon*)pmap -> store.nodes;
231
232     for (i = 0; i < pmap -> numPhotons; i++, p++) {
233     /* Write photon attributes */
234     for (j = 0; j < 3; j++)
235     putflt(p -> pos [j], out);
236
237     /* Bytewise dump otherwise we have portability probs */
238     for (j = 0; j < 3; j++)
239     putint(p -> norm [j], 1, out);
240
241     #ifdef PMAP_FLOAT_FLUX
242     for (j = 0; j < 3; j++)
243     putflt(p -> flux [j], out);
244     #else
245     for (j = 0; j < 4; j++)
246     putint(p -> flux [j], 1, out);
247     #endif
248
249     putint(p -> primary, sizeof(p -> primary), out);
250     putint(p -> flags, 1, out);
251
252     if (ferror(out))
253     return -1;
254     }
255
256     return 0;
257     }
258
259
260
261     int kdT_LoadPhotons (struct PhotonMap *pmap, FILE *in)
262     {
263     unsigned long i, j;
264     Photon *p;
265
266     /* Allocate kd-tree based on initialised pmap -> numPhotons */
267     pmap -> store.nodes = calloc(sizeof(Photon), pmap -> numPhotons);
268     if (!pmap -> store.nodes)
269     error(SYSTEM, "failed kd-tree allocation in kdT_LoadPhotons");
270
271     /* Get photon attributes */
272     for (i = 0, p = pmap -> store.nodes; i < pmap -> numPhotons; i++, p++) {
273     for (j = 0; j < 3; j++)
274     p -> pos [j] = getflt(in);
275
276     /* Bytewise grab otherwise we have portability probs */
277     for (j = 0; j < 3; j++)
278     p -> norm [j] = getint(1, in);
279
280     #ifdef PMAP_FLOAT_FLUX
281     for (j = 0; j < 3; j++)
282     p -> flux [j] = getflt(in);
283     #else
284     for (j = 0; j < 4; j++)
285     p -> flux [j] = getint(1, in);
286     #endif
287
288     p -> primary = getint(sizeof(p -> primary), in);
289     p -> flags = getint(1, in);
290
291     if (feof(in))
292     return -1;
293     }
294
295     return 0;
296     }
297
298
299
300     void kdT_InitFindPhotons (struct PhotonMap *pmap)
301     {
302     pmap -> squeue.len = pmap -> maxGather + 1;
303     pmap -> squeue.node = calloc(pmap -> squeue.len,
304     sizeof(PhotonSearchQueueNode));
305     if (!pmap -> squeue.node)
306     error(SYSTEM, "can't allocate photon search queue");
307     }
308
309
310
311     static void kdT_FindNearest (PhotonMap *pmap, const float pos [3],
312     const float norm [3], unsigned long node)
313     /* Recursive part of kdT_FindPhotons(). Locate pmap -> squeue.len nearest
314     * neighbours to pos with similar normal and return in search queue starting
315     * at pmap -> squeue.node. Note that all heap and queue indices are
316     * 1-based, but accesses to the arrays are 0-based! */
317     {
318     Photon *p = (Photon*)pmap -> store.nodes + node - 1;
319     unsigned i, j;
320     /* Signed distance to current photon's splitting plane */
321     float d = pos [p -> discr] - p -> pos [p -> discr],
322     d2 = d * d, dv [3];
323     PhotonSearchQueueNode* sq = pmap -> squeue.node;
324     const unsigned sqSize = pmap -> squeue.len;
325
326     /* Search subtree closer to pos first; exclude other subtree if the
327     distance to the splitting plane is greater than maxDist */
328     if (d < 0) {
329     if (node << 1 <= pmap -> numPhotons)
330     kdT_FindNearest(pmap, pos, norm, node << 1);
331
332     if (d2 < pmap -> maxDist2 && node << 1 < pmap -> numPhotons)
333     kdT_FindNearest(pmap, pos, norm, (node << 1) + 1);
334     }
335     else {
336     if (node << 1 < pmap -> numPhotons)
337     kdT_FindNearest(pmap, pos, norm, (node << 1) + 1);
338
339     if (d2 < pmap -> maxDist2 && node << 1 <= pmap -> numPhotons)
340     kdT_FindNearest(pmap, pos, norm, node << 1);
341     }
342
343     /* Reject photon if normal faces away (ignored for volume photons) with
344     * tolerance to account for perturbation; note photon normal is coded
345     * in range [-127,127], hence we factor this in */
346     if (norm && DOT(norm, p -> norm) <= PMAP_NORM_TOL * 127 * frandom())
347     return;
348
349     if (isContribPmap(pmap) && pmap -> srcContrib) {
350     /* Lookup in contribution photon map */
351     OBJREC *srcMod;
352     const int srcIdx = photonSrcIdx(pmap, p);
353
354     if (srcIdx < 0 || srcIdx >= nsources)
355     error(INTERNAL, "invalid light source index in photon map");
356
357     srcMod = findmaterial(source [srcIdx].so);
358
359     /* Reject photon if contributions from light source which emitted it
360     * are not sought */
361     if (!lu_find(pmap -> srcContrib, srcMod -> oname) -> data)
362     return;
363
364     /* Reject non-caustic photon if lookup for caustic contribs */
365     if (pmap -> lookupCaustic & !p -> caustic)
366     return;
367     }
368
369     /* Squared distance to current photon (note dist2() requires doubles) */
370     VSUB(dv, pos, p -> pos);
371     d2 = DOT(dv, dv);
372
373     /* Accept photon if closer than current max dist & add to priority queue */
374     if (d2 < pmap -> maxDist2) {
375     if (pmap -> squeue.tail < sqSize) {
376     /* Priority queue not full; append photon and restore heap */
377     i = ++pmap -> squeue.tail;
378
379     while (i > 1 && sq [(i >> 1) - 1].dist2 <= d2) {
380     sq [i - 1].idx = sq [(i >> 1) - 1].idx;
381     sq [i - 1].dist2 = sq [(i >> 1) - 1].dist2;
382     i >>= 1;
383     }
384
385     sq [--i].idx = (PhotonIdx)p;
386     sq [i].dist2 = d2;
387     /* Update maxDist if we've just filled the queue */
388     if (pmap -> squeue.tail >= pmap -> squeue.len)
389     pmap -> maxDist2 = sq [0].dist2;
390     }
391     else {
392     /* Priority queue full; replace maximum, restore heap, and
393     update maxDist */
394     i = 1;
395
396     while (i <= sqSize >> 1) {
397     j = i << 1;
398     if (j < sqSize && sq [j - 1].dist2 < sq [j].dist2)
399     j++;
400     if (d2 >= sq [j - 1].dist2)
401     break;
402     sq [i - 1].idx = sq [j - 1].idx;
403     sq [i - 1].dist2 = sq [j - 1].dist2;
404     i = j;
405     }
406
407     sq [--i].idx = (PhotonIdx)p;
408     sq [i].dist2 = d2;
409     pmap -> maxDist2 = sq [0].dist2;
410     }
411     }
412     }
413
414
415
416     void kdT_FindPhotons (struct PhotonMap *pmap, const FVECT pos,
417     const FVECT norm)
418     {
419     float p [3], n [3];
420
421     /* Photon pos & normal stored at lower precision */
422     VCOPY(p, pos);
423     VCOPY(n, norm);
424     kdT_FindNearest(pmap, p, n, 1);
425     }
426
427
428
429     static void kdT_Find1Nearest (PhotonMap *pmap, const float pos [3],
430     const float norm [3], Photon **photon,
431     unsigned long node)
432     /* Recursive part of kdT_Find1Photon(). Locate single nearest neighbour to
433     * pos with similar normal. Note that all heap and queue indices are
434     * 1-based, but accesses to the arrays are 0-based! */
435     {
436     Photon *p = (Photon*)pmap -> store.nodes + node - 1;
437     /* Signed distance to current photon's splitting plane */
438     float d = pos [p -> discr] - p -> pos [p -> discr], d2 = d * d,
439     dv [3];
440
441     /* Search subtree closer to pos first; exclude other subtree if the
442     distance to the splitting plane is greater than maxDist */
443     if (d < 0) {
444     if (node << 1 <= pmap -> numPhotons)
445     kdT_Find1Nearest(pmap, pos, norm, photon, node << 1);
446
447     if (d2 < pmap -> maxDist2 && node << 1 < pmap -> numPhotons)
448     kdT_Find1Nearest(pmap, pos, norm, photon, (node << 1) + 1);
449     }
450     else {
451     if (node << 1 < pmap -> numPhotons)
452     kdT_Find1Nearest(pmap, pos, norm, photon, (node << 1) + 1);
453
454     if (d2 < pmap -> maxDist2 && node << 1 <= pmap -> numPhotons)
455     kdT_Find1Nearest(pmap, pos, norm, photon, node << 1);
456     }
457
458     /* Squared distance to current photon */
459     VSUB(dv, pos, p -> pos);
460     d2 = DOT(dv, dv);
461
462     if (d2 < pmap -> maxDist2 &&
463     DOT(norm, p -> norm) > PMAP_NORM_TOL * 127 * frandom()) {
464     /* Closest photon so far with similar normal. We allow for tolerance
465     * to account for perturbation in the latter; note the photon normal
466     * is coded in the range [-127,127], hence we factor this in */
467     pmap -> maxDist2 = d2;
468     *photon = p;
469     }
470     }
471
472
473
474     void kdT_Find1Photon (struct PhotonMap *pmap, const FVECT pos,
475     const FVECT norm, Photon *photon)
476     {
477     float p [3], n [3];
478     Photon *pnn;
479
480     /* Photon pos & normal stored at lower precision */
481     VCOPY(p, pos);
482     VCOPY(n, norm);
483     kdT_Find1Nearest(pmap, p, n, &pnn, 1);
484     memcpy(photon, pnn, sizeof(Photon));
485     }
486
487
488
489     int kdT_GetPhoton (const struct PhotonMap *pmap, PhotonIdx idx,
490     Photon *photon)
491     {
492     memcpy(photon, idx, sizeof(Photon));
493     return 0;
494     }
495
496
497
498     Photon *kdT_GetNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx)
499     {
500     return idx;
501     }
502
503
504
505     PhotonIdx kdT_FirstPhoton (const struct PhotonMap* pmap)
506     {
507     return pmap -> store.nodes;
508     }
509
510
511
512     void kdT_Delete (PhotonKdTree *kdt)
513     {
514     free(kdt -> nodes);
515     kdt -> nodes = NULL;
516     }
