| 1 |
| 2 |
| 3 |
   In-core kd-tree for photon map |
| 4 |
| 5 |
   Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
| 6 |
   (c) Fraunhofer Institute for Solar Energy Systems, |
| 7 |
   (c) Lucerne University of Applied Sciences and Arts, |
| 8 |
       supported by the Swiss National Science Foundation (SNSF, #147053) |
| 9 |
| 10 |
| 11 |
   $Id: pmapkdt.c,v 1.1 2016/05/18 08:22:45 rschregle Exp $ |
| 12 |
| 13 |
| 14 |
| 15 |
| 16 |
#include "pmapdata.h"   /* Includes pmapkdt.h */ |
| 17 |
#include "source.h" |
| 18 |
| 19 |
| 20 |
| 21 |
| 22 |
void kdT_Null (PhotonKdTree *kdt) |
| 23 |
| 24 |
   kdt -> nodes = NULL; |
| 25 |
| 26 |
| 27 |
| 28 |
| 29 |
static unsigned long kdT_MedianPartition (const Photon *heap,  |
| 30 |
                                          unsigned long *heapIdx, |
| 31 |
                                          unsigned long *heapXdi,  |
| 32 |
                                          unsigned long left,  |
| 33 |
                                          unsigned long right, unsigned dim) |
| 34 |
/* Returns index to median in heap from indices left to right  |
| 35 |
   (inclusive) in dimension dim. The heap is partitioned relative to  |
| 36 |
   median using a quicksort algorithm. The heap indices in heapIdx are |
| 37 |
   sorted rather than the heap itself. */ |
| 38 |
| 39 |
   const float    *p; |
| 40 |
   unsigned long  l, r, lg2, n2, m, n = right - left + 1; |
| 41 |
   unsigned       d; |
| 42 |
| 43 |
   /* Round down n to nearest power of 2 */ |
| 44 |
   for (lg2 = 0, n2 = n; n2 > 1; n2 >>= 1, ++lg2); |
| 45 |
   n2 = 1 << lg2; |
| 46 |
| 47 |
   /* Determine median position; this takes into account the fact that  |
| 48 |
      only the last level in the heap can be partially empty, and that  |
| 49 |
      it fills from left to right */ |
| 50 |
   m = left + ((n - n2) > (n2 >> 1) - 1 ? n2 - 1 : n - (n2 >> 1)); |
| 51 |
| 52 |
   while (right > left) { |
| 53 |
      /* Pivot node */ |
| 54 |
      p = heap [heapIdx [right]].pos; |
| 55 |
      l = left; |
| 56 |
      r = right - 1; |
| 57 |
| 58 |
      /* l & r converge, swapping elements out of order with respect to  |
| 59 |
         pivot node. Identical keys are resolved by cycling through |
| 60 |
         dim. The convergence point is then the pivot's position. */ |
| 61 |
      do { |
| 62 |
         while (l <= r) { |
| 63 |
            d = dim; |
| 64 |
| 65 |
            while (heap [heapIdx [l]].pos [d] == p [d]) { |
| 66 |
               d = (d + 1) % 3; |
| 67 |
| 68 |
               if (d == dim) { |
| 69 |
                  /* Ignore dupes? */ |
| 70 |
                  error(WARNING, "duplicate keys in photon heap"); |
| 71 |
                  l++; |
| 72 |
                  break; |
| 73 |
| 74 |
| 75 |
| 76 |
            if (heap [heapIdx [l]].pos [d] < p [d])  |
| 77 |
               l++; |
| 78 |
            else break; |
| 79 |
| 80 |
| 81 |
         while (r > l) { |
| 82 |
            d = dim; |
| 83 |
| 84 |
            while (heap [heapIdx [r]].pos [d] == p [d]) { |
| 85 |
               d = (d + 1) % 3; |
| 86 |
| 87 |
               if (d == dim) { |
| 88 |
| 89 |
| 90 |
                  r--; |
| 91 |
                  break; |
| 92 |
| 93 |
| 94 |
| 95 |
            if (heap [heapIdx [r]].pos [d] > p [d])  |
| 96 |
               r--; |
| 97 |
            else break; |
| 98 |
| 99 |
| 100 |
         /* Swap indices (not the nodes they point to) */ |
| 101 |
         n2 = heapIdx [l]; |
| 102 |
         heapIdx [l] = heapIdx [r]; |
| 103 |
         heapIdx [r] = n2; |
| 104 |
         /* Update reverse indices */ |
| 105 |
         heapXdi [heapIdx [l]] = l; |
| 106 |
         heapXdi [n2] = r; |
| 107 |
      } while (l < r); |
| 108 |
| 109 |
      /* Swap indices of convergence and pivot nodes */ |
| 110 |
      heapIdx [r] = heapIdx [l]; |
| 111 |
      heapIdx [l] = heapIdx [right]; |
| 112 |
      heapIdx [right] = n2; |
| 113 |
| 114 |
      heapXdi [heapIdx [r]] = r; |
| 115 |
| 116 |
      heapXdi [n2] = right; |
| 117 |
| 118 |
      if (l >= m)  |
| 119 |
         right = l - 1; |
| 120 |
      if (l <= m)  |
| 121 |
         left = l + 1; |
| 122 |
| 123 |
| 124 |
   /* Once left & right have converged at m, we have found the median */ |
| 125 |
   return m; |
| 126 |
| 127 |
| 128 |
| 129 |
| 130 |
static void kdT_Build (Photon *heap, unsigned long *heapIdx, |
| 131 |
                       unsigned long *heapXdi, const float min [3],  |
| 132 |
                       const float max [3], unsigned long left,  |
| 133 |
                       unsigned long right, unsigned long root) |
| 134 |
/* Recursive part of balancePhotons(..). Builds heap from subarray |
| 135 |
   defined by indices left and right. min and max are the minimum resp.  |
| 136 |
   maximum photon positions in the array. root is the index of the |
| 137 |
   current subtree's root, which corresponds to the median's 1-based  |
| 138 |
   index in the heap. heapIdx are the balanced heap indices. The heap |
| 139 |
   is accessed indirectly through these. heapXdi are the reverse indices  |
| 140 |
   from the heap to heapIdx so that heapXdi [heapIdx [i]] = i. */ |
| 141 |
| 142 |
   float                maxLeft [3], minRight [3]; |
| 143 |
   Photon               rootNode; |
| 144 |
   unsigned             d; |
| 145 |
| 146 |
   /* Choose median for dimension with largest spread and partition  |
| 147 |
      accordingly */ |
| 148 |
   const float          d0 = max [0] - min [0],  |
| 149 |
                        d1 = max [1] - min [1],  |
| 150 |
                        d2 = max [2] - min [2]; |
| 151 |
   const unsigned char  dim = d0 > d1 ? d0 > d2 ? 0 : 2  |
| 152 |
                                      : d1 > d2 ? 1 : 2; |
| 153 |
   const unsigned long  median = left == right  |
| 154 |
                                 ? left  |
| 155 |
                                 : kdT_MedianPartition(heap, heapIdx, heapXdi, |
| 156 |
                                                       left, right, dim); |
| 157 |
| 158 |
   /* Place median at root of current subtree. This consists of swapping  |
| 159 |
      the median and the root nodes and updating the heap indices */ |
| 160 |
   memcpy(&rootNode, heap + heapIdx [median], sizeof(Photon)); |
| 161 |
   memcpy(heap + heapIdx [median], heap + root - 1, sizeof(Photon)); |
| 162 |
   rootNode.discr = dim; |
| 163 |
   memcpy(heap + root - 1, &rootNode, sizeof(Photon)); |
| 164 |
   heapIdx [heapXdi [root - 1]] = heapIdx [median]; |
| 165 |
   heapXdi [heapIdx [median]] = heapXdi [root - 1]; |
| 166 |
   heapIdx [median] = root - 1; |
| 167 |
   heapXdi [root - 1] = median; |
| 168 |
| 169 |
   /* Update bounds for left and right subtrees and recurse on them */ |
| 170 |
   for (d = 0; d <= 2; d++) |
| 171 |
      if (d == dim)  |
| 172 |
         maxLeft [d] = minRight [d] = rootNode.pos [d]; |
| 173 |
      else { |
| 174 |
         maxLeft [d] = max [d]; |
| 175 |
         minRight [d] = min [d]; |
| 176 |
| 177 |
| 178 |
   if (left < median)  |
| 179 |
      kdT_Build(heap, heapIdx, heapXdi, min, maxLeft, left, median - 1,  |
| 180 |
                root << 1); |
| 181 |
| 182 |
   if (right > median)  |
| 183 |
      kdT_Build(heap, heapIdx, heapXdi, minRight, max, median + 1, right,  |
| 184 |
                (root << 1) + 1); |
| 185 |
| 186 |
| 187 |
| 188 |
| 189 |
void kdT_BuildPhotonMap (struct PhotonMap *pmap) |
| 190 |
| 191 |
   Photon         *nodes; |
| 192 |
   unsigned long  i; |
| 193 |
   unsigned long  *heapIdx,        /* Photon index array */ |
| 194 |
                  *heapXdi;        /* Reverse index to heapIdx */ |
| 195 |
| 196 |
   /* Allocate kd-tree nodes and load photons from heap file */ |
| 197 |
   if (!(nodes = calloc(pmap -> numPhotons, sizeof(Photon)))) |
| 198 |
      error(SYSTEM, "failed in-core heap allocation in kdT_BuildPhotonMap"); |
| 199 |
| 200 |
   rewind(pmap -> heap); |
| 201 |
   i = fread(nodes, sizeof(Photon), pmap -> numPhotons, pmap -> heap); |
| 202 |
   if (i != |
| 203 |
       pmap -> numPhotons) |
| 204 |
      error(SYSTEM, "failed loading photon heap in kdT_BuildPhotonMap"); |
| 205 |
| 206 |
   pmap -> store.nodes = nodes; |
| 207 |
   heapIdx = calloc(pmap -> numPhotons, sizeof(unsigned long)); |
| 208 |
   heapXdi = calloc(pmap -> numPhotons, sizeof(unsigned long)); |
| 209 |
   if (!heapIdx || !heapXdi) |
| 210 |
      error(SYSTEM, "failed heap index allocation in kdT_BuildPhotonMap"); |
| 211 |
| 212 |
   /* Initialize index arrays */ |
| 213 |
   for (i = 0; i < pmap -> numPhotons; i++) |
| 214 |
      heapXdi [i] = heapIdx [i] = i; |
| 215 |
| 216 |
   /* Build kd-tree */ |
| 217 |
   kdT_Build(nodes, heapIdx, heapXdi, pmap -> minPos, pmap -> maxPos, 0,  |
| 218 |
             pmap -> numPhotons - 1, 1); |
| 219 |
| 220 |
   /* Cleanup */ |
| 221 |
   free(heapIdx); |
| 222 |
   free(heapXdi); |
| 223 |
| 224 |
| 225 |
| 226 |
| 227 |
int kdT_SavePhotons (const struct PhotonMap *pmap, FILE *out) |
| 228 |
| 229 |
   unsigned long        i, j; |
| 230 |
   Photon               *p = (Photon*)pmap -> store.nodes; |
| 231 |
| 232 |
   for (i = 0; i < pmap -> numPhotons; i++, p++) { |
| 233 |
      /* Write photon attributes */ |
| 234 |
      for (j = 0; j < 3; j++) |
| 235 |
         putflt(p -> pos [j], out); |
| 236 |
| 237 |
      /* Bytewise dump otherwise we have portability probs */ |
| 238 |
| 239 |
         putint(p -> norm [j], 1, out); |
| 240 |
| 241 |
#ifdef PMAP_FLOAT_FLUX |
| 242 |
| 243 |
         putflt(p -> flux [j], out); |
| 244 |
#else |
| 245 |
      for (j = 0; j < 4; j++)  |
| 246 |
         putint(p -> flux [j], 1, out); |
| 247 |
#endif |
| 248 |
| 249 |
      putint(p -> primary, sizeof(p -> primary), out); |
| 250 |
      putint(p -> flags, 1, out); |
| 251 |
| 252 |
      if (ferror(out)) |
| 253 |
         return -1; |
| 254 |
| 255 |
| 256 |
   return 0; |
| 257 |
| 258 |
| 259 |
| 260 |
| 261 |
int kdT_LoadPhotons (struct PhotonMap *pmap, FILE *in) |
| 262 |
| 263 |
| 264 |
   Photon         *p; |
| 265 |
| 266 |
   /* Allocate kd-tree based on initialised pmap -> numPhotons */ |
| 267 |
   pmap -> store.nodes = calloc(sizeof(Photon), pmap -> numPhotons); |
| 268 |
   if (!pmap -> store.nodes)  |
| 269 |
      error(SYSTEM, "failed kd-tree allocation in kdT_LoadPhotons"); |
| 270 |
| 271 |
   /* Get photon attributes */    |
| 272 |
   for (i = 0, p = pmap -> store.nodes; i < pmap -> numPhotons; i++, p++) { |
| 273 |
| 274 |
         p -> pos [j] = getflt(in); |
| 275 |
| 276 |
      /* Bytewise grab otherwise we have portability probs */ |
| 277 |
| 278 |
         p -> norm [j] = getint(1, in); |
| 279 |
| 280 |
| 281 |
| 282 |
         p -> flux [j] = getflt(in); |
| 283 |
#else       |
| 284 |
| 285 |
         p -> flux [j] = getint(1, in); |
| 286 |
#endif |
| 287 |
| 288 |
      p -> primary = getint(sizeof(p -> primary), in); |
| 289 |
      p -> flags = getint(1, in); |
| 290 |
| 291 |
      if (feof(in)) |
| 292 |
         return -1; |
| 293 |
| 294 |
| 295 |
   return 0; |
| 296 |
| 297 |
| 298 |
| 299 |
| 300 |
void kdT_InitFindPhotons (struct PhotonMap *pmap) |
| 301 |
| 302 |
   pmap -> squeue.len = pmap -> maxGather + 1; |
| 303 |
   pmap -> squeue.node = calloc(pmap -> squeue.len, |
| 304 |
                                sizeof(PhotonSearchQueueNode)); |
| 305 |
   if (!pmap -> squeue.node)  |
| 306 |
      error(SYSTEM, "can't allocate photon search queue"); |
| 307 |
| 308 |
| 309 |
| 310 |
| 311 |
static void kdT_FindNearest (PhotonMap *pmap, const float pos [3],  |
| 312 |
                             const float norm [3], unsigned long node) |
| 313 |
/* Recursive part of kdT_FindPhotons(). Locate pmap -> squeue.len nearest |
| 314 |
 * neighbours to pos with similar normal and return in search queue starting |
| 315 |
 * at pmap -> squeue.node.  Note that all heap and queue indices are |
| 316 |
 * 1-based, but accesses to the arrays are 0-based!  */ |
| 317 |
| 318 |
   Photon                  *p = (Photon*)pmap -> store.nodes + node - 1; |
| 319 |
   unsigned                i, j; |
| 320 |
   /* Signed distance to current photon's splitting plane */ |
| 321 |
   float                   d = pos [p -> discr] - p -> pos [p -> discr],  |
| 322 |
                           d2 = d * d, dv [3]; |
| 323 |
   PhotonSearchQueueNode*  sq = pmap -> squeue.node; |
| 324 |
   const unsigned          sqSize = pmap -> squeue.len; |
| 325 |
| 326 |
   /* Search subtree closer to pos first; exclude other subtree if the  |
| 327 |
      distance to the splitting plane is greater than maxDist */ |
| 328 |
   if (d < 0) { |
| 329 |
      if (node << 1 <= pmap -> numPhotons)  |
| 330 |
         kdT_FindNearest(pmap, pos, norm, node << 1); |
| 331 |
| 332 |
      if (d2 < pmap -> maxDist2 && node << 1 < pmap -> numPhotons)  |
| 333 |
         kdT_FindNearest(pmap, pos, norm, (node << 1) + 1); |
| 334 |
| 335 |
   else { |
| 336 |
      if (node << 1 < pmap -> numPhotons)  |
| 337 |
| 338 |
| 339 |
      if (d2 < pmap -> maxDist2 && node << 1 <= pmap -> numPhotons)  |
| 340 |
| 341 |
| 342 |
| 343 |
   /* Reject photon if normal faces away (ignored for volume photons) with |
| 344 |
    * tolerance to account for perturbation; note photon normal is coded |
| 345 |
    * in range [-127,127], hence we factor this in */ |
| 346 |
   if (norm && DOT(norm, p -> norm) <= PMAP_NORM_TOL * 127 * frandom()) |
| 347 |
      return; |
| 348 |
| 349 |
   if (isContribPmap(pmap) && pmap -> srcContrib) { |
| 350 |
      /* Lookup in contribution photon map */ |
| 351 |
      OBJREC *srcMod;  |
| 352 |
      const int srcIdx = photonSrcIdx(pmap, p); |
| 353 |
| 354 |
      if (srcIdx < 0 || srcIdx >= nsources) |
| 355 |
         error(INTERNAL, "invalid light source index in photon map"); |
| 356 |
| 357 |
      srcMod = findmaterial(source [srcIdx].so); |
| 358 |
| 359 |
      /* Reject photon if contributions from light source which emitted it |
| 360 |
       * are not sought */ |
| 361 |
      if (!lu_find(pmap -> srcContrib, srcMod -> oname) -> data) |
| 362 |
         return; |
| 363 |
| 364 |
      /* Reject non-caustic photon if lookup for caustic contribs */ |
| 365 |
      if (pmap -> lookupCaustic & !p -> caustic) |
| 366 |
         return; |
| 367 |
| 368 |
| 369 |
   /* Squared distance to current photon (note dist2() requires doubles) */ |
| 370 |
   VSUB(dv, pos, p -> pos); |
| 371 |
   d2 = DOT(dv, dv); |
| 372 |
| 373 |
   /* Accept photon if closer than current max dist & add to priority queue */ |
| 374 |
   if (d2 < pmap -> maxDist2) { |
| 375 |
      if (pmap -> squeue.tail < sqSize) { |
| 376 |
         /* Priority queue not full; append photon and restore heap */ |
| 377 |
         i = ++pmap -> squeue.tail; |
| 378 |
| 379 |
         while (i > 1 && sq [(i >> 1) - 1].dist2 <= d2) { |
| 380 |
            sq [i - 1].idx    = sq [(i >> 1) - 1].idx; |
| 381 |
            sq [i - 1].dist2  = sq [(i >> 1) - 1].dist2; |
| 382 |
            i >>= 1; |
| 383 |
| 384 |
| 385 |
         sq [--i].idx = (PhotonIdx)p; |
| 386 |
         sq [i].dist2 = d2; |
| 387 |
         /* Update maxDist if we've just filled the queue */ |
| 388 |
         if (pmap -> squeue.tail >= pmap -> squeue.len) |
| 389 |
            pmap -> maxDist2 = sq [0].dist2; |
| 390 |
| 391 |
      else { |
| 392 |
         /* Priority queue full; replace maximum, restore heap, and  |
| 393 |
            update maxDist */ |
| 394 |
         i = 1; |
| 395 |
| 396 |
         while (i <= sqSize >> 1) { |
| 397 |
            j = i << 1; |
| 398 |
            if (j < sqSize && sq [j - 1].dist2 < sq [j].dist2)  |
| 399 |
               j++; |
| 400 |
            if (d2 >= sq [j - 1].dist2)  |
| 401 |
               break; |
| 402 |
            sq [i - 1].idx    = sq [j - 1].idx; |
| 403 |
            sq [i - 1].dist2  = sq [j - 1].dist2; |
| 404 |
            i = j; |
| 405 |
| 406 |
| 407 |
| 408 |
| 409 |
| 410 |
| 411 |
| 412 |
| 413 |
| 414 |
| 415 |
| 416 |
void kdT_FindPhotons (struct PhotonMap *pmap, const FVECT pos,  |
| 417 |
                      const FVECT norm) |
| 418 |
| 419 |
   float p [3], n [3]; |
| 420 |
| 421 |
   /* Photon pos & normal stored at lower precision */ |
| 422 |
   VCOPY(p, pos); |
| 423 |
   VCOPY(n, norm); |
| 424 |
   kdT_FindNearest(pmap, p, n, 1); |
| 425 |
| 426 |
| 427 |
| 428 |
| 429 |
static void kdT_Find1Nearest (PhotonMap *pmap, const float pos [3],  |
| 430 |
                              const float norm [3], Photon **photon,  |
| 431 |
| 432 |
/* Recursive part of kdT_Find1Photon().  Locate single nearest neighbour to |
| 433 |
 * pos with similar normal.  Note that all heap and queue indices are |
| 434 |
| 435 |
| 436 |
| 437 |
| 438 |
   float    d  = pos [p -> discr] - p -> pos [p -> discr], d2 = d * d,  |
| 439 |
            dv [3]; |
| 440 |
| 441 |
| 442 |
| 443 |
   if (d < 0) { |
| 444 |
| 445 |
         kdT_Find1Nearest(pmap, pos, norm, photon, node << 1); |
| 446 |
| 447 |
| 448 |
         kdT_Find1Nearest(pmap, pos, norm, photon, (node << 1) + 1); |
| 449 |
| 450 |
   else { |
| 451 |
| 452 |
| 453 |
| 454 |
| 455 |
| 456 |
| 457 |
| 458 |
   /* Squared distance to current photon */ |
| 459 |
| 460 |
   d2 = DOT(dv, dv); |
| 461 |
| 462 |
   if (d2 < pmap -> maxDist2 &&  |
| 463 |
       DOT(norm, p -> norm) > PMAP_NORM_TOL * 127 * frandom()) { |
| 464 |
      /* Closest photon so far with similar normal. We allow for tolerance |
| 465 |
       * to account for perturbation in the latter; note the photon normal |
| 466 |
       * is coded in the range [-127,127], hence we factor this in  */ |
| 467 |
      pmap -> maxDist2 = d2; |
| 468 |
      *photon = p; |
| 469 |
| 470 |
| 471 |
| 472 |
| 473 |
| 474 |
void kdT_Find1Photon (struct PhotonMap *pmap, const FVECT pos,  |
| 475 |
                      const FVECT norm, Photon *photon) |
| 476 |
| 477 |
| 478 |
   Photon   *pnn; |
| 479 |
| 480 |
| 481 |
   VCOPY(p, pos); |
| 482 |
   VCOPY(n, norm); |
| 483 |
   kdT_Find1Nearest(pmap, p, n, &pnn, 1); |
| 484 |
   memcpy(photon, pnn, sizeof(Photon)); |
| 485 |
| 486 |
| 487 |
| 488 |
| 489 |
int kdT_GetPhoton (const struct PhotonMap *pmap, PhotonIdx idx, |
| 490 |
                   Photon *photon) |
| 491 |
| 492 |
   memcpy(photon, idx, sizeof(Photon));    |
| 493 |
   return 0; |
| 494 |
| 495 |
| 496 |
| 497 |
| 498 |
Photon *kdT_GetNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx) |
| 499 |
| 500 |
   return idx; |
| 501 |
| 502 |
| 503 |
| 504 |
| 505 |
PhotonIdx kdT_FirstPhoton (const struct PhotonMap* pmap) |
| 506 |
| 507 |
   return pmap -> store.nodes; |
| 508 |
| 509 |
| 510 |
| 511 |
| 512 |
void kdT_Delete (PhotonKdTree *kdt) |
| 513 |
| 514 |
   free(kdt -> nodes); |
| 515 |
| 516 |
