root/Development/ray/src/rt/pmapio.h
Tue Sep 17 16:36:05 2024 UTC (13 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.8: +8 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
Thu Feb 18 17:08:50 2021 UTC (4 years, 8 months ago) by rschregle
Changes since 2.7: +10 -4 lines
fix(mkpmap,pmapdump): Made pmap files (hopefully) more portable by
forcing numPhotons to fixed size irrespective of platform (possibly with 0-padding)
Fri Dec 7 20:07:41 2018 UTC (6 years, 11 months ago) by rschregle
Changes since 2.6: +14 -6 lines
Bumped file format version, added/revised feature suffixes for PMAP_PRIMARYPOS
and PMAP_PRIMARYDIR.
Tue May 17 17:39:47 2016 UTC (9 years, 5 months ago) by rschregle
CVS Tags: rad5R1, rad5R2
Changes since 2.5: +31 -5 lines
Tue Sep 1 16:27:52 2015 UTC (10 years, 2 months ago) by greg
Tue Aug 18 18:45:55 2015 UTC (10 years, 2 months ago) by greg
Fri May 22 14:09:01 2015 UTC (10 years, 5 months ago) by greg
Removed redundant photon map type parameter
Fri May 8 13:20:22 2015 UTC (10 years, 6 months ago) by rschregle
Tue Feb 24 19:39:27 2015 UTC (10 years, 8 months ago) by greg
Diff to selected 2.8
