root/radiance/ray/src/rt/pmapio.c
Revision: 2.4
Committed: Wed May 20 14:44:12 2015 UTC (10 years ago) by greg
Changes since 2.3: +3 -5 lines
Reduced primary photon struct size using encoded direction
1 /*
2 ==================================================================
3 Photon map file I/O
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ==================================================================
10
11 $Id: pmapio.c,v 2.3 2015/05/20 12:58:31 greg Exp $
12 */
13
14
15
16 #include "pmapio.h"
17 #include "pmapdiag.h"
18 #include "resolu.h"
19
20
21
22 void savePhotonMap (const PhotonMap *pmap, const char *fname,
23 PhotonMapType type, int argc, char **argv)
24 {
25 unsigned long i, j;
26 const Photon* p;
27 FILE* file;
28
29 if (!pmap || !pmap -> heap || !pmap -> heapSize ||
30 !validPmapType(type)) {
31 error(INTERNAL, "attempt to save empty or invalid photon map");
32 return;
33 }
34
35 if (photonRepTime) {
36 sprintf(errmsg, "Saving %s (%ld photons)...\n",
37 fname, pmap -> heapSize);
38 eputs(errmsg);
39 fflush(stderr);
40 }
41
42 if (!(file = fopen(fname, "wb"))) {
43 sprintf(errmsg, "can't open photon map file %s", fname);
44 error(SYSTEM, errmsg);
45 }
46
47 /* Write header */
48 newheader("RADIANCE", file);
49
50 /* Write command line */
51 printargs(argc, argv, file);
52
53 /* Include statistics in info text */
54 fprintf(file, "%ld photons @ (%.2e, %.2e, %.2e) avg watts\n"
55 "Extent [%.3f, %.3f, %.3f] [%.3f, %.3f, %.3f]\n",
56 pmap -> heapSize, pmap -> photonFlux [0],
57 pmap -> photonFlux [1], pmap -> photonFlux [2],
58 pmap -> minPos [0], pmap -> minPos [1], pmap -> minPos [2],
59 pmap -> maxPos [0], pmap -> maxPos [1], pmap -> maxPos [2]);
60 if (pmap -> primary)
61 fprintf(file, "%d primary rays\n", pmap -> primaryEnd + 1);
62
63 /* Write format */
64 fputformat((char*)pmapFormat [type], file);
65 fprintf(file, "VERSION=%d\n", PMAP_FILEVER);
66
67 /* Empty line = end of header */
68 putc('\n', file);
69
70 /* Write file format version */
71 putint(PMAP_FILEVER, sizeof(PMAP_FILEVER), file);
72
73 /* Write number of photons */
74 putint(pmap -> heapSize, sizeof(pmap -> heapSize), file);
75
76 /* Write average photon flux */
77 for (j = 0; j < 3; j++)
78 putflt(pmap -> photonFlux [j], file);
79
80 /* Write max and min photon positions */
81 for (j = 0; j < 3; j++) {
82 putflt(pmap -> minPos [j], file);
83 putflt(pmap -> maxPos [j], file);
84 }
85
86 /* Write centre of gravity */
87 for (j = 0; j < 3; j++)
88 putflt(pmap -> CoG [j], file);
89
90 /* Write avg distance to centre of gravity */
91 putflt(pmap -> CoGdist, file);
92
93 for (i = 0, p = pmap -> heap; i < pmap -> heapSize; i++, p++) {
94 /* Write photon attributes */
95 for (j = 0; j < 3; j++)
96 putflt(p -> pos [j], file);
97
98 /* Bytewise dump otherwise we have portability probs */
99 for (j = 0; j < 3; j++)
100 putint(p -> norm [j], 1, file);
101
102 #ifdef PMAP_FLOAT_FLUX
103 for (j = 0; j < 3; j++)
104 putflt(p -> flux [j], file);
105 #else
106 for (j = 0; j < 4; j++)
107 putint(p -> flux [j], 1, file);
108 #endif
109
110 putint(p -> primary, sizeof(p -> primary), file);
111 putint(p -> flags, 1, file);
112
113 if (ferror(file)) {
114 sprintf(errmsg, "error writing photon map file %s", fname);
115 error(SYSTEM, errmsg);
116 }
117 }
118
119 /* Write out primary photon rays (or just zero count if none) */
120 if (pmap -> primary) {
121 /* primaryEnd points to last primary ray in array, so increment for
122 * number of entries */
123 putint(pmap -> primaryEnd + 1, sizeof(pmap -> primaryEnd), file);
124
125 for (i = 0; i <= pmap -> primaryEnd; i++) {
126 PhotonPrimary *prim = pmap -> primary + i;
127
128 putint(prim -> srcIdx, sizeof(prim -> srcIdx), file);
129
130 putint(prim -> dir, sizeof(prim -> dir), file);
131
132 for (j = 0; j < 3; j++)
133 putflt(prim -> pos [j], file);
134
135 if (ferror(file))
136 error(SYSTEM, "error writing primary photon rays");
137 }
138 }
139 else putint(0, sizeof(pmap -> primaryEnd), file);
140
141 fclose(file);
142 }
143
144
145
146 PhotonMapType loadPhotonMap (PhotonMap *pmap, const char *fname)
147 {
148 Photon* p;
149 PhotonMapType ptype = PMAP_TYPE_NONE;
150 char format [128];
151 unsigned long i, j;
152 FILE *file;
153
154 if (!pmap)
155 return PMAP_TYPE_NONE;
156
157 if ((file = fopen(fname, "rb")) == NULL) {
158 sprintf(errmsg, "can't open photon map file %s", fname);
159 error(SYSTEM, errmsg);
160 }
161
162 /* Get format string */
163 strcpy(format, PMAP_FORMAT_GLOB);
164 if (checkheader(file, format, NULL) != 1) {
165 sprintf(errmsg, "photon map file %s has unknown format %s",
166 fname, format);
167 error(USER, errmsg);
168 }
169
170 /* Identify photon map type from format string */
171 for (ptype = 0;
172 strcmp(pmapFormat [ptype], format) && ptype < NUM_PMAP_TYPES;
173 ptype++);
174
175 if (!validPmapType(ptype)) {
176 sprintf(errmsg, "file %s contains an unknown photon map type", fname);
177 error(USER, errmsg);
178 }
179
180 initPhotonMap(pmap, ptype);
181
182 /* Get file format version and check for compatibility */
183 if (getint(sizeof(PMAP_FILEVER), file) != PMAP_FILEVER)
184 error(USER, "incompatible photon map file format");
185
186 /* Get number of photons */
187 pmap -> heapSize = pmap -> heapEnd =
188 getint(sizeof(pmap -> heapSize), file);
189 pmap -> heap = (Photon *)malloc(pmap -> heapSize * sizeof(Photon));
190 if (!pmap -> heap)
191 error(INTERNAL, "can't allocate photon heap from file");
192
193 /* Get average photon flux */
194 for (j = 0; j < 3; j++)
195 pmap -> photonFlux [j] = getflt(file);
196
197 /* Get max and min photon positions */
198 for (j = 0; j < 3; j++) {
199 pmap -> minPos [j] = getflt(file);
200 pmap -> maxPos [j] = getflt(file);
201 }
202
203 /* Get centre of gravity */
204 for (j = 0; j < 3; j++)
205 pmap -> CoG [j] = getflt(file);
206
207 /* Get avg distance to centre of gravity */
208 pmap -> CoGdist = getflt(file);
209
210 /* Get photon attributes */
211 for (i = 0, p = pmap -> heap; i < pmap -> heapSize; i++, p++) {
212 for (j = 0; j < 3; j++)
213 p -> pos [j] = getflt(file);
214
215 /* Bytewise grab otherwise we have portability probs */
216 for (j = 0; j < 3; j++)
217 p -> norm [j] = getint(1, file);
218
219 #ifdef PMAP_FLOAT_FLUX
220 for (j = 0; j < 3; j++)
221 p -> flux [j] = getflt(file);
222 #else
223 for (j = 0; j < 4; j++)
224 p -> flux [j] = getint(1, file);
225 #endif
226
227 p -> primary = getint(sizeof(p -> primary), file);
228 p -> flags = getint(1, file);
229
230 if (feof(file)) {
231 sprintf(errmsg, "error reading photon map file %s", fname);
232 error(SYSTEM, errmsg);
233 }
234 }
235
236 /* Get primary photon rays */
237 pmap -> primarySize = getint(sizeof(pmap -> primarySize), file);
238
239 if (pmap -> primarySize) {
240 pmap -> primaryEnd = pmap -> primarySize - 1;
241 pmap -> primary = (PhotonPrimary*)malloc(pmap -> primarySize *
242 sizeof(PhotonPrimary));
243 if (!pmap -> primary)
244 error(INTERNAL, "can't allocate primary photon rays");
245
246 for (i = 0; i < pmap -> primarySize; i++) {
247 PhotonPrimary *prim = pmap -> primary + i;
248
249 prim -> srcIdx = getint(sizeof(prim -> srcIdx), file);
250
251 prim -> dir = getint(sizeof(prim -> dir), file);
252
253 for (j = 0; j < 3; j++)
254 prim -> pos [j] = getflt(file);
255
256 if (feof(file))
257 error(SYSTEM, "error reading primary photon rays");
258 }
259 }
260
261 fclose(file);
262
263 return ptype;
264 }
